A b16 VTEC head on a b20 block.. help??
Old 05-29-2002, 05:14 AM
Okay20's Avatar
Default A b16 VTEC head on a b20 block.. help??
Hey guys, I've heard of Frank engines (short for Frankenstien engines) where you swap the heads and blocks of diffent engines in the Honda B series to create your own custom ****.. I just ran by an engine and I wanted to know if it's a good idea.. it's a b16 VTEC head on a b20 block (from a CRV). I wanna drop this into my CRX but I don't know if it's a good idea.. also do ya'll recommend putting a DRAG Gen 3 Turbo kit on it when it's complete.. any info on this swap or the turbo would be great.. thanks in advance
Old 05-29-2002, 05:19 AM
FOrSfEd's Avatar
Default Re: A b16 VTEC head on a b20 block.. help?? (LegallyBrown786)
That will be a great idea, I'm also doing this in the coming months, but for more info check out www.crvtec.com . Place for good info on the swap.
Lee
Old 05-29-2002, 06:08 AM
SpeedMonkeyRacing's Avatar
make sure you build the block and not half *** on it. Those swaps are AWESOME..but it can go bad easily if you don't build it properly
I'm building a b20/vtec for my crx to compete in honda-challenge as well
Jeff-
Old 05-29-2002, 10:56 AM
big pete's Avatar
Default Re: A b16 VTEC head on a b20 block.. help?? (VolcomR)
yah...build it good....you'll regret it if you dont
Old 05-29-2002, 08:06 PM
90_Civic_Hatch's Avatar
Default Re: A b16 VTEC head on a b20 block.. help?? (big pete)
Is it just me? or do the links on the CRVTEC.com site not work??
Old 05-29-2002, 08:57 PM
wickedxboi's Avatar
Default Re: A b16 VTEC head on a b20 block.. help?? (90_Civic_Hatch)
those motors make some good power, but it all depends on how its built. getting it built right will cost you some $$$.
Old 05-29-2002, 10:32 PM
The Boot
Smokinsax's Avatar
Default Re: A b16 VTEC head on a b20 block.. help?? (wickedxboi)
Here's another site that should help. http://www.c-speedracing.com/howto.html (just scroll down a little bit) Also are you going to be building the engine or buying an engine already put together? Build your own or buy from a reputable shop and get it done right the first time. hth
Old 05-29-2002, 11:56 PM
Trickturn's Avatar
My suggestion... worry about getting the b20 W/OUT vtec into your car. Get it all straightened out & then go w/ a turbo. When you have all that under your belt & settled... then worry about a vtec head.
Going from 112 hp to 330 hp is insane if you have never dealt w/ it before.
Good luck,
Pete
Old 05-30-2002, 12:36 AM
REX VT's Avatar
Here you go:
B20z/type R with 11:1 CR pushing 900kg of CRX
Bhp? 230-240 (still running P30)
Torque? Shitloads of them
Fast? No doubt, kills 300bhp E36 M3
[Modified by REX VT, 9:37 AM 5/30/2002]
Old 05-30-2002, 10:16 AM
Okay20's Avatar
Default Re: A b16 VTEC head on a b20 block.. help?? (pest)
what do you mean 112hp to 330?? A b20/b16 head is only 112hp? Are you sure? I'm confused.. someone help please.. I don't know too much bout this swap..
Old 05-30-2002, 11:52 AM
Jeff C's Avatar
here are some b20vtec dynos, along with a bunch of others. keep in mind though that they did not just simply put a vtec head on crv block.
http://www.importreview.com/d_2.0.html
spens 91 Ef
10-29-2009 11:40 AM
Turbo_y8
02-20-2005 09:09 PM
b20vtechatch
10-04-2004 06:33 AM
bonestock92si
04-03-2004 05:58 AM
photec2
25
01-22-2004 12:12 PM
Quick Reply: A b16 VTEC head on a b20 block.. help??
