#1 | |||||
Tom Downes 1991 CRX Si Wicked Innovation New England's only Authorized NepTuner and Dealer |
#2 |
No ideas anyone? Anything else I should check?
#3 |
I tried a stethoscope on the motor, it seems the noise is coming from cylinder #4. It's still inconsistent, but it seems to be loudest just above the engine code plaque. It's also pretty loud in the left-most valve cover bolt (passenger side).
#4 |
do you have good oil pressure? Before it gets any worse, take the oil pan off and pop the rod caps off. Seems weird that there is no trace of bearing material though.
http://www.synapsemotorsport.com 12.4@109 all motor street car w/stock cams. Curiosity is the mother of creativity. |
#5 |
Yes, oil pressure is fine... I thought that was weird too not seeing bearing material in there. I mean, I don't expect to spin one so quickly, but I have no other explaination for the noise.
#6 |
I just realised you're in Albany, where at?
#7 |
I actually live in scotia, and work at synapse. Also a fellow ef owner
#8 | |
#9 |
I didnt go to the meets, been working on the car and its out getting paint at the moment. I'd like to check out the setup and maybe help find out what the noise is. not sure exactly whats going on this weekend just yet. I'll pm you.
#10 |
That would be great, I was half joking but I'd really appreciate someone else taking a look too. I'm going to pull the pan and take a look at the #4 rod bearing today. Tuning is put back a little, so I have some time, but I want to get it straightened out... it's really hard to not have the CRX on a beautiful day like today!
#11 |
Pulled the oil pan... looks like the #4 rod bearing is cooked. It's not welded to the crank yet, but I have a spare crank so I'll be pulling the motor again soon.
#12 |
I know you already figured it out but I wanted to write about a good method to determine what is causing a knock.
If the engine is making a knock, pull each spark plug wire and ground it. If the knock decreases in intensity it most likely has excessive rod bearing clearance. If the noise is a high frequency rattling sound, and it decreases intensity when pulling a plug wire it is most likely pin noise. If the noise is a deep metallic thud, mostly under load, it is probably excessive main bearing clearance.
My favorite molecule is 2,2,4-trimethyl pentane. |
#13 |
I was all set to order my rod bearings through Honda tonight, but I can't figure out the colour codes. I got the letters/numbers off my crank and rods, and I found how to figure out what "colour" bearings I need. The problem is, Honda's online thing only lists the letters, A-G. Do I just order the letter of the bearing I need? Does it not matter? The differences between the colour codes for each letter is 0.0002"-0.0003", and the tolerance in the manual is 0.0007". I know I should know this, but I've always used ACL bearings, which are one size, and until now they've always worked. I want to get the proper bearings because the OEM ones SHOULD be better if they are matched, since the ACL are not.
For what it's worth, my rods are all "3", and the crank is C3, B3, B3, C3. I really want to get this stuff ASAP, it would be great if someone could help me out. I re-read that and I think it might be a little confusing (not the main problem about sizing, but what I meant about the tolerances). To clarify: Each combination has a letter and number, together they correspond to a colour/size. For example: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> "A" 1= red 2= pink 3= yellow 4= green "B" 1= pink 2= yellow 3= green 4= brown "C" 1=yellow 2= green 3= brown 4= black "D" 1= green 2= brown 3= black 4= blue </TD></TR></TABLE> What I meant was that the differences between all the numbers in each letter is a total of 0.0003" or 0.0004" (ie, blue to green, black to yellow etc); I didn't mean between each different colour. The total difference between the largest and smallest (blue and red) is 0.0007", which happens to be the tolerance in the manual.
| Bookmarks |
