#1 | |||||
Life's simple, you make choices and you don't look back. Who you choose to be around you lets you know who you are. |
#2 |
so What does everyone think?
or
#3 |
i would have used different pads tho
ddphoto-canon |
#4 |
Good write up. Is the grease necessary? I've done brakes on all my cars and have never greased them. Just wondering if I have been missing something wrong? Also, if the rotor is really rusted on the hub, don't be afraid to get out the propane torch and heat the up the area between the rotor and the hub. Just don't get the flame near the wheel bearing cover or brake line. I've had to do that due to my accord being parked for so long outdoors.
94 Accord Coupe 160k miles Daily 85 Mr2 138k miles Project/Summer Cars just don't have character until they have over 100k miles on them. |
#5 |
Ive always used it because if you dont it can cause squeaking noises and such...its just a good idea to do it
#6 |
Thanks for the pics and tips.
Noted the Lisle rear piston retract tool worked. Will order one for future use. |
#7 |
anytime man...and yes the piston tool works..only thing you have to do is loosen the bleeder screw a bit to let all the pressure off of it...then you may want to consider bleeding the rear brake calipers!
#8 |
Thanks for the good write up
Was wondering what kinda flathead screw-driver is that big enough to screw the rear disc piston back in since we can't compress it Didn't know that brake piston tool exists haha
People I've bought from: Snail EG, egb18turbo, CiViC KiD, jonyb, Knigtnam, Shongku, HONDA-2NR, Shocka1998LX, ian, Surfer_Sandman, Duece, cycocivic, kadburry, 3 3 3, XX Boosted Si XX, IntegraXTR, Hybrid Performance, delsolcutie, crank, sporkcrx, slowhatch92, hybrid89, sauceja, b20vrex, SOHCejcivic http://images.honda-tech.com/set1/smile/emthup.gif Sold to : Integra N Civic, KND, ff_terror, Chester Rumble, That4drGSR, Mr. B in Az http://images.honda-tech.com/set1/smile/emthup.gif |
#9 |
yes the brake piston tool is awesome..the first time I did rear brake pads I tried a pair of needle nose pliers..didnt work at all haha
#10 |
H-T Order of Merit
instead of loosening the bleeder screw to relieve pressure and make it easier to turn, just take the cap off the brake fluid reservoir. It'll make turning the rear caliper piston much easier and you won't have to worry about bleeding the rear brakes because of loosening the bleeder screw.
#11 |
Where did you get the brake piston socket?
#12 |
H-T Order of Merit
you mean the brake piston tool to turn the caliper piston back in?
you can get it at most parts stores for about $8-12 IIRC. I was about to buy one years ago at AutoZone I believe but then a friend gave me one they didn't need anymore. |
#13 |
I want to get some aftermarket brakes but don't want to spend all that money for the labor of a mechanic to put them on. I just recently had to get all new brakes put on. The cost came to $2,000 and most of that went to the labor. So this write up should help me in the future when i get some nice brakes.
1995 Honda Accord EX 5 Speed - Sold 10/5/2007 1997 Mitsubishi Eclipse GSX 5 Speed |
#14 |
Good steps. I'm sure it will help the people that need the information. Well explained. BTW your car looks clean! Got any more plans for it?
I'm Persian http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emsmile.gif http://images.honda-tech.com/set1/smile/emsad.gif http://images.honda-tech.com/set1/smile/emsmilep.gif http://images.honda-tech.com/set1/smile/emdgust.gif http://images.honda-tech.com/set1/smile/emsmileo.gif http://images.honda-tech.com/set1/smile/emwink.gif http://images.honda-tech.com/set1//smile/emcrook.gif I <3 Individual Throttle Body's! http://images.honda-tech.com/set1/smile/emthup.gif I <3 my job! (American Discount Tire's) http://images.honda-tech.com/set1/smile/emsmilep.gif "Clean & Simple is the way to GO" http://images.honda-tech.com/set1/smile/emthup.gif ENJOY |
#15 |
Thanks for all the input guys..and yes you can remove the cap to relieve pressure..I Just didnt think of that for some reason..thanks touring accord..and yes you can get the brake piston tool at any parts store..i think mine was 4.99 at advance..I cant remember Ive had it forever...and yes I have a ton of plans for my car..first off I want to tint the windows just a smidge..get some better springs, lip kit painted the same as my car, JDM stanley yellow fog lights(very rare), Shave the side moldings off( I ment to do this when I painted my car
...), Upgraded brake system..iim not sure what I want yet, its an auto so this summer IM planning on doing the 5 speed conversion and then I want to buy an h22 and set it in my basement for a while so I can rebuild it and then drop it in and turbo it..nothing to fancy and im not lookin for outragious HP numbers just something to give a good kick..im getting my interior redone also..im thinking black and red maybe? like the ITRs....I think thats about it im not sure..im sure as I go along things will change and I will come up with new ideas..ill try to keep everyone posted! BTW this is what my car used to look like with ebay coilovers on it and gay chrome shit...altezzas andeverything..I dont know what I was thinking..I guess you live and you learn lol
| Bookmarks |
| Tags |
| 2002, accord, bake, brake, brakes, change, changing, honda, jack, pads, put, rear, replace, rotors, tire |
