Engine flooded with gasoline.... Why???
Old 04-05-2007, 08:21 AM
EG_Type-R's Avatar
Default Engine flooded with gasoline.... Why???
I did an engine swap on my 95 EG CX, jdm b16a sir2... When I turn the ignition ON all 4 injectors start pumping gas into the engine and the engine gets flooded... I try changing the MAP sensor but still... I have no idea where to start checking... Any ideas guys???
Old 04-05-2007, 01:16 PM
Perfectionist's Avatar
Default Re: Engine flooded with gasoline.... Why??? (EG_Type-R)
The ECU grounds the injector circuits to pulse them. Maybe you shorted them to ground or have them on the wrong pins on the ECU?
Old 04-05-2007, 02:16 PM
EG_Type-R's Avatar
Default Re: Engine flooded with gasoline.... Why??? (Perfectionist)
I think I shorted them to ground, what can I do to fix this???
Old 04-05-2007, 05:36 PM
arc_55's Avatar
check all wiring from the P2 injector plug to the ecu. The computer controls injector pluse width on the ground side to the ecu. The reason this is done is because of voltage spikes and also if there was ever a short to ground before the injector the injector would be inoperative and throw a code. Unfortunely it sounds like you have a short to ground on the controlled side. I would check your ground side of the injector plug first.
Old 05-19-2008, 11:07 PM
riddlinkid1986's Avatar
Default Re: (arc_55)
bump! same issue! how to fix it yo!
Old 03-08-2009, 11:45 AM
alacard's Avatar
I realize this is an old post. But it never had a resolution. So for those of you searching...this problem (for me at least) was caused by a fried ecu. I switched out the ecu and it fixed the problem. I am, however, still dealing with the effects of a flooded engine.
Old 01-24-2011, 07:35 PM
buckner2009's Avatar
ya bumb have a 97 dx switched ecu switched cold start map engine harness' its spitting sputterering at idle rev it up fine but rich as hell! done cam sensor coil every normal thing think off cleaned injectors everything stumped dd! need it running (normal)
carlos8
12-19-2016 07:11 PM
B_Swapped93
04-24-2013 08:44 PM
fasteddief23
07-06-2011 01:31 PM
HondacivDX
09-10-2010 04:12 PM
BfromSD
01-24-2008 05:50 PM
Quick Reply: Engine flooded with gasoline.... Why???
