Tires Size's... someone explain
New User
I dont know jack shiznile about tires and tire sizes i was hopin someone could explain and break it down, i hadnt seen or found a post about it and thought it might be helpfull. 195-60-15 the only number i get is the 15 which is the rim/wheel size other than that i duno.
~Sab.
~Sab.
Re: Tires Size's... someone explain (Sabastian)
Rim Width:
The width between the flanges of the wheel (the part the bead of the tire touches).
Section Width:
The linear distance between the outside of the sidewalls of an inflated tire without any load on it (this does not include any sidewall decorations).
Section Height:
This is also known as the Aspect Ratio. This is figured on a percentage of the section width. A tire size of 205/60R15 would have a section width of 205 millimeters and a section height of 60 percent of 205 millimeters.
205-50-15 is what I would opt to for better performance. Looks better IMO because it decreases side wall size and increases (in most cases) contact patch. Have a good holdiday.
-MB
-MB
Re: Tires Size's... someone explain (Crazy Bovine)
-MB
-MB
[Modified by 01GSR, 2:27 PM 5/27/2002]
Re: Tires Size's... someone explain (01GSR)
I have 205/50/15 w/ a ~1.3" drop and my car looks fine. You can't really tell a difference between a 205/50 and a 205/55. My speedo is even off the same mph between the 2 tires.
your car looks cold..
Re: Tires Size's... someone explain (94Accord)
I remember that day. Nothing like scraping ice off the windshield before hitting the track! Danville *sigh* ...
theineffable
Honda Civic (2001 - 2005)
11-25-2009 12:58 PM
