DISABLE door chime!
Old 05-26-2002, 11:42 AM
LudemanDan's Avatar
Default DISABLE door chime!
ludemandan's roommate here. i bought the car, i want to disable the door chime. on my 88 jetta it was easy, just pull a relay, it looks like its gonna be harder on this one. any ideas? hopefully it will be the same for dan's 4'th gen prelude right? i'm also swapping out the stock stereo today if anyone cares.
-josh (94 ex coupe vtec 5spd)
Old 05-26-2002, 12:16 PM
I didn't ask for a dime.
Johnny Gasparini's Avatar
Default Re: DISABLE door chime! (LudemanDan)
Correct me if I am wrong... I thought Hondas didn't have door chimes. The only chimes i am familiar with are the haedlights left ona nd the key in the ignition.
Old 05-26-2002, 02:05 PM
Nick H's Avatar
Default Re: DISABLE door chime! (JSM)
when you open the door with the key still in the ignition is when the door chime happens...
Old 05-26-2002, 07:25 PM
Gennady's Avatar
There are two chimes. One is when lights are on and door is open while key is out. The other is door is open while key in the accessory position. I'd like to remove this one.
Old 05-26-2002, 08:18 PM
Default Re: DISABLE door chime! (Wont be beat)
Technically, there is no chime for the door alone. If the door opens, it chimes in conjunction with the key in the assessory position and/or if you have left your headlights on (which we have establish).
So, this may not be as accessable as an '88 Jetta
Old 05-27-2002, 03:01 AM
LudemanDan's Avatar
yes, there are several different chimes that happen at differents times. the one that i most want to disable is the key warning. i always chill in my car with the stereo on and the door open. if its not amazingly difficult i want to disable both of them, but i'll take what i can get. any more knowledge? thanx guys!
Old 05-27-2002, 08:35 AM
briq4's Avatar
Doesn't a car alarm rely on the light circuit to be open to "sense" when the door is opened? Wouldn't disabling the switch that does that kill the alarm?
Old 05-27-2002, 09:19 AM
I can't see why you would want to disable the chime for the simple pleasure of chillin' in your ride while listening to Reo Speedwagon. (j/k) You may want to contact your local Honda dealership and ask the service department or consult the owners manual and locate the fuse and yank it out.
Old 05-27-2002, 12:06 PM
H23 Power's Avatar
just get a service manual for the car and look at the wiring diagrams...should be as easy as splicing one wire into another so that the circuit doesn't make it to the ignition switch
Old 05-27-2002, 02:03 PM
4doorH22's Avatar
Default Re: DISABLE door chime! (01GSR)
Dude, when I want to chill with the stereo playing and the door open i just jam a toothpick into the door sensor switch to make it think the door is closed
Old 05-27-2002, 06:10 PM
Kazmans94cord's Avatar
Default Re: DISABLE door chime! (4doorH22)
why not just roll the windows down???
Old 05-27-2002, 06:30 PM
gringo7718's Avatar
Default Re: DISABLE door chime! (kazmans94cord)
hey man i feel your pain, its hot as a **** in miami!!!!! i had a similar problem with my seatbelt chime. it kept going off until one day it drove me crazy, i disconnected the small computer under the pass seat. pry open the computer and you will see a little black cylinder on the board that says TDK. personally, took a screwdriver to it on my jalopi and ive been very satisfied. i know thats not exactly what you want but maybe itll help
Old 05-27-2002, 08:59 PM
Jago's Avatar
There is a very easy way to do this, although it turns off the dome and door lights
to. Go into the fuse box diagram and find the fuse labeled 7.5 A Interior light and pull it out. The door chim is also wired on this circut. This worked perfectly on my 94 accord.
Jago
DTMkarnage
06-15-2010 01:02 AM
nateb22
05-06-2009 11:00 PM
suhteevin
01-06-2009 09:04 PM
pstanger
08-22-2007 08:58 AM
itsmedavid
08-09-2007 03:19 PM
Quick Reply: DISABLE door chime!
