Broken Bolt on Rear Shock......NEED HELP ASAP!!!!
I was taking the bolt off the rear shock and it snapped, does anyone know how to get the bolt out of the lower control arm because the head of the bolt broke the rest of the bolt is still in between the shock and the control arm,
Re: Broken Bolt on Rear Shock......NEED HELP ASAP!!!! (irideslammed5021)
cut the nut off the lower shock "fork", hammer out the bolt and replace it with a nut of the same size/pitch and grade and get a new bolt from honda
Re: Broken Bolt on Rear Shock......NEED HELP ASAP!!!! (SkoundrelUSA)
alright i cut off the nut but now i cant bang out the rest of the bolt it is stuck in the bushing i tried pounding it out it just doesnt want to budge
this problem is very common. most likely ur gonna have to change out the lower control arm.
Re: (vtecftw)
noooooooo, haha alright thanks guys but im going to go keep trying need to save as much as possible, if anyone knows any other ways possible just leave a post, thanks late
Re: (irideslammed5021)
there's on other way of doing it -- if you want you could blow out the bushing and bolt all together with a blow torch
however you will need to press in new bushing
Re: (DeadEnd9009)
I had that exact problem, just take an impact hammer and pound the rest of the bolt out... (from an air compressor) I tried using a sledge hammer and that wasn't enough force, so the impact hammer isthe only way
Re: Broken Bolt on Rear Shock......NEED HELP ASAP!!!! (sicones)
sometims taking a drill bit (1/2 the size of the bolt) and using a drill will help. it will break the bond loose betwwen the bolt and metal. a left handed drill bit works best but most dont have them.
Re: Broken Bolt on Rear Shock......NEED HELP ASAP!!!! (philliman69)
now that you have both ends of the bolt off , you can spread the fork of the strut open enough to get it out and straighten it out again when its out. once the strut is out of the way , youl be able to beat on the bolt better.
mikehawkBUiLT
15
05-13-2004 03:17 PM
