> Honda Accord (1990 - 2002)
Old 03-25-2007, 05:02 PM   #1
jsquared22
jsquared22's Avatar
Default 03 Accord Center Console Door Will Not Stay Closed
My '03 Accord has a problem with the front center console door not staying closed. I can close it but it will not latch and stay shut.
Before I start digging into the issue, has anyone encountered this before? Any suggestions / recommendations are certainly appreciated.
Thanks in advance!
jsquared22 is offline   Reply With Quote
Old 03-26-2007, 02:07 PM   #2
Winjury
Winjury's Avatar
Default Re: 03 Accord Center Console Door Will Not Stay Closed (jsquared22)
take it to the dealer. they have a simple solution to your problem.
Winjury is offline   Reply With Quote
Old 03-29-2007, 02:01 PM   #3
jsquared22
jsquared22's Avatar
Default Re: 03 Accord Center Console Door Will Not Stay Closed (Winjury)
Thanks for the response.... but the dealer wants $175 for a replacement compartment door.
Just to clarify, this is the compartment located just below the radio.
Old 03-29-2007, 02:32 PM   #4
Loco-B
Loco-B's Avatar
Yeah. They want $175 because of the labor that goes into putting that thing in. In fact if you feel confident enough, buy the part and do it youself. There are quite a few pieces of dash that have to come off in order to get that box out of the car!
2008 Civic SI RR Coupe
Project: 2G DSM Eclipse, 6-Bolt swap, 341hp / 258lbs/tq on 18psi mild street tune.
Loco-B is offline   Reply With Quote
Old 03-29-2007, 07:30 PM   #5
jsquared22
jsquared22's Avatar
Default Re: 03 Accord Center Console Door Will Not Stay Closed (accordcd_7)
This was the retail price from the parts department at the dealer. This did not include labor.
Old 03-30-2007, 04:45 AM   #6
tech8
tech8's Avatar
Go call around to different dealers to see if they can fix it. I believe Honda had a Technical Service Bulletin (TSB) # 02067 regarding the Center Assembly Pocket on the 2003 Accord. (Doesn't mean they won't charge you for the fix though . )
tech8 is offline   Reply With Quote
Old 04-03-2007, 06:32 PM   #7
killa rex
2006 Honda Motorcycle
My Garage
killa rex's Avatar
i've fix these b4..it's just a piece of metal that's bend a bit..
MotoGP 2009 Teams
killa rex is offline   Reply With Quote
Old 04-22-2007, 12:02 PM   #8
jsquared22
jsquared22's Avatar
Thanks for the reply killa rex. I’ve tried to confirm they piece of metal you were referring to but cannot find it. Also, it seems as if the entire car was built around this dash compartment. ;-) I've removed a few panel / pieces and it's not completely intuitive on how to get this compartment removed so I can see what's actually broken. Any additional advice is appreciated.
2004, 2005, 2006, accord, center, close, compartment, console, door, fix, fixing, honda, latch, pocket, replacement
