Old 03-23-2007, 04:33 AM   #1
trans_ponder
trans_ponder's Avatar
Default accord 02 idle adjustment
I read that there is a screw for the idle adj. but I can't seem to find it. Does anyone know if accord 02 still has it, since the newer models don't.
Thanks.
trans_ponder is offline   Reply With Quote
Old 03-28-2007, 12:21 AM   #2
trans_ponder
Default Re: accord 02 idle adjustment (trans_ponder)
Any idea ????
Old 03-28-2007, 06:57 AM   #3
JimBlake
JimBlake's Avatar
Can you count how many spark plugs you have so I know which engine to look up?
Or better yet, go to hondaautomotiveparts.com, put in your car's info, and look at the 'throttlebody' picture.
JimBlake
'03 Accord & '07 Civic
'01 Saab 9 & '05 9x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline   Reply With Quote
Old 03-30-2007, 12:32 AM   #4
trans_ponder
Default Re: accord 02 idle adjustment (JimBlake)
Thanks!
It's a 2.3L, 4 cyl. LX AUTO 2002. I've seen the throttle picture but can't figure it out.
Old 03-30-2007, 04:40 AM   #5
JimBlake
JimBlake's Avatar
#1 is the idle adjust screw. Follow the line from that; it points into a hole above the TB bore, positioned at about 11 oclock.
ps... The procedure for adjusting the "BASE" idle:
First, the mechanical stop for the actual throttle plate should only just barely prevent the throttle from wedging stuck closed.
Engine warmed up with all electrical loads turned off.
Unplug the IACV (#9). (idle will drop down to 'base' idle)
Adjust idle to 600?? rpm. (look it up, some years are different)
Turn it off & reset the ECU. (pull #13 fuse in box near right-front door hinge)
Let it cool down. Plug th IACV back in.
Start & idle for 10 minutes WITHOUT TOUCHING THE GAS PEDAL AT ALL.
edit-oops: I forgot a step...
Modified by JimBlake at 12:17 PM 3/30/2007
JimBlake
'01 Saab 9 & '05 9x
Old 03-30-2007, 06:14 AM   #6
trans_ponder
Thanks a lot sir!
02, 1990, 1992, 2000, accord, acura, adjust, adjustment, civic, honda, idle, idling, integra, picture, screw, set
