WTF: EG clutch pedal gets stuck on the floor
okay so i went too start my EG HB(B16) and i press on the clutch pedal and bam! it gets stuck at the bottom feels like theres no clutch lol.... i pop the hood and i see all the clutch fluid leaking little drops from the slave cylinder from the nut closest too the headers? its leaking it really fast! so fill it up and bleed it and then it works great i drove it for 10 min then parked it and it leaked it all out again through the same spot WTF!!! do i need a new slave cylinder? LMK
Re: WTF: EG clutch pedal gets stuck on the floor (-HONDA-)
That would make sense....
The damn thing is leaking fluid and killing all your clutch pressure.
Re: WTF: EG clutch pedal gets stuck on the floor (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Try tightening the screw but you probably need a new slave cylinder. </TD></TR></TABLE>
Agreed (lucky you, it's cheap & easy!)
Re: (-HONDA-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- »</TD></TR><TR><TD CLASS="quote">munchos gracias you guys lol... how much you think they are?</TD></TR></TABLE>
http://www.thehondapartsstore....ch=no
this is just to get an idea, atleast from the dealer.
Re: (-HONDA-)
BTW replace the clutch master cylinder at the same time. They work together so the same number of cycles are on both. If one has failed the other is not far behind.
HT White Ops
Re: (-HONDA-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- »</TD></TR><TR><TD CLASS="quote">how much is a clutch master cylinder?</TD></TR></TABLE>
You might try calling a parts store or a Honda dealership.
Just a thought.
Just a thought.
707EF8
07-29-2006 08:32 PM
