skunk2 LCA and blox adj. endlinks help 95 civic hatch
Old 10-13-2007, 07:13 PM
HKSuperSi's Avatar
Default skunk2 LCA and blox adj. endlinks help 95 civic hatch
does anybody have this combo. the hardware that came w/ the blox seems like it would not fit the skunk2 lca. can anybody help?
Old 10-13-2007, 09:03 PM
HKSuperSi's Avatar
anybody.
Old 10-13-2007, 09:55 PM
HKSuperSi's Avatar
i'll try and get pics, maybe that will help.
Old 10-15-2007, 02:28 PM
spAdam's Avatar
Default Re: (HKSuperSi)
yup. get a pic up. Its kinda hard to make sure youre installing them correctly otherwise... After that I'll see what I can do.
Old 10-15-2007, 11:09 PM
HKSuperSi's Avatar
its cool i gave skunk2 a call and they helped me out. it turns out i had to use oem endlinks, but i'm gonna try and find smaller size scres for the blox endlinks.
i'll post pics once i'm done or if i get it done.
Old 10-17-2007, 02:00 PM
spAdam's Avatar
Good to know. Guess that knocks skunk2 off my list of possible lca's. Pretty sure I'm more than likely gonna go with mfactory, need to get ahold of them and find out if they'll work with the blox endlinks.
Make sure you put a sleeve around that smaller bolt where goes through the ball end or you're gonna create one rattling s.o.b. and some serious extra stresses...
Old 10-17-2007, 05:25 PM
HKSuperSi's Avatar
i'm pertty sure u still can use the blox endlinks its just for the part that goes in the LCA that you would need 1 size smaller bolt and you'll have no prob. but w/ the skunk2 LCA all you need to do is screw the endlinks halfway or 3/4 of the way and no nut at the end. that is why they threaded it.
Old 10-22-2007, 03:22 PM
white bubble's Avatar
does anybody know what size the screw is that goes into the skunk2 sway bar hole??
Old 10-22-2007, 03:23 PM
HKSuperSi's Avatar
just go to acura and tell them to look up the screw for the integra lca and it should be the same. thats what i did and it fit.
Old 11-23-2007, 05:54 PM
6SPD_EK's Avatar
I take it F7 endlinks have the same issue as blox w/skunk2 lca? or no?
does anyone make spherical endlinks with 10mm lower bolt for LCA's?
OR
does anyone know the thread size of blox or F7? i found these in 10mm thread & 10mm ID for the bearing which is what we would need
Modified by 6SPD_EK at 10:55 PM 11/23/2007
Modified by 6SPD_EK at 10:56 PM 11/23/2007
Old 12-11-2007, 08:28 AM
k20zno2's Avatar
Default Re: (6SPD_EK)
pic's
Nordy
Suspension & Brakes
01-16-2008 10:08 AM
EFRue57
08-20-2005 02:35 PM
DAmn
08-19-2005 12:35 AM
Quick Reply: skunk2 LCA and blox adj. endlinks help 95 civic hatch
