Wheel Bearing Replacement '02 Accord Coupe
Any idea if there's a DIY or How-To on replacing the front wheel bearings? I think I have one on its way out...
Re: Wheel Bearing Replacement '02 Accord Coupe (B18C_EJ8)
I've got one in my chiltons.
You're going to need a press to get those wheel bearings out.
I removed the whole piece that holds the wheel bearings and brought them to a NAPA, they usually have a machinest of some sort, he replaced the bearings quickly, I reinstalled everything and I was done.
Really? The bearing is built into the hub assembly?
As stated in my cheap-*** Haynes manual, the bearing needs to be pressed out, but # 3 definitely doesn't look like it gets pressed anywhere since it's got screwholes...
H-T Order of Merit
Re: Wheel Bearing Replacement '02 Accord Coupe (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1928887</TD></TR></TABLE>
OUTSTANDING!!
OUTSTANDING!!
z6hatchboy
02-06-2009 06:31 PM
