88-91 CRX Spring Rates *STICKY*
Old 03-06-2007, 12:38 PM
gringo7718's Avatar
Default 88-91 CRX Spring Rates *STICKY*
Over the past month I have been researching different springs for the CRX and collecting the specs directly from the manufacturers. The information was gathered directly from the manufactures and is accurate. Here are the spring rates that i have found in Kg/mm and also in Lbs./in
I was dissapointed to learn that H&R sports specs were never released because they are well liked by many people. I was also dissapointed to learn that Eibach sportlines and pro-kit uses exactly the same spring rates????
(* represents a progressive measurement)
<U>TEIN S-TECH</U>
Drop: front: 1.6"
rear: 1.5"
front: 4.8 Kg/mm / 268 Lbs/in
rear: 2.2 Kg/mm / 123 Lbs/in
<U>PROGRESS B-SERIES SPRINGS</U>
Drop: 2.0"
front: 6.4 Kg/mm / 360 Lbs/in
rear: 3.5 Kg/mm / 200 Lbs/in
<U>TANABE GF210</U> (orange)
Drop: 1.3"
front: 6.0 Kg/mm / 336 Lbs/in
rear: 2.7 Kg/mm / 152 Lbs/in
<U>ESPELIR</U> (SUPER ACTIVE DOWN)
Drop: 1.57" front
1.77" rear
Front: 4.8 Kg/mm / 268.8 Lbs/in
Rear: 3.6 Kg/mm / 201.6 Lbs/in
<U>EIBACH PRO-KIT </U> (black)
Drop: 1.2" front
1.0" rear
front: 4.9 Kg/mm / 274 Lbs/in
rear: / 97/228* Lbs/in
<U>EIBACH SPORTLINES</U> (red)
Drop: 1.7" front
1.5" rear
<U>NEUSPEED SPORT</U> (green)
Drop: 2.0" front
1.8" rear
front: 4.9 Kg/mm / 275 Lbs/in
rear: 4.0 Kg/mm / 225 Lbs/in
<U>NEUSPEED RACE</U> (yellow)
Drop: 2.25" front
2.0" rear
front: 10.2 Kg/mm / 575 Lbs/in
rear: 9.6 Kg/mm / 540 Lbs/in
<U>RS*R DOWN SPRINGS</U>
Drop: 2.2" front
1.6" rear
Front: 5.0 Kg/mm / 279 Lbs/in
Rear: 3.9 Kg/mm / 218 Lbs/in
<U>RS*R RACE SPRINGS</U>
Drop: 1.6" front
1.6" rear
Front: 6.1 Kg/mm / 341 Lbs/in
Rear: 4.2 Kg/mm / 235 Lbs/in
<U>SKUNK 2 SPRINGS</U> (red)
Drop: 2.5" front
2.25" rear
front: / 257/559* Lbs/in
rear: / 112/485* Lbs/in
<U>H&R RACE</U> (red)
Drop: 2.25" front
2.0" rear
front: 8.4 Kg/mm / 470 Lbs/in
rear: 6.4 Kg/mm / 360 Lbs/in
<U>H&R SPORTS</U> (black)
SPRING RATES HAVE NEVER
BEEN RELEASED BY THE MANUFACTURER
(Call them yourself)
Drop: 1.9" front
1.8" rear
<U>GROUND CONTROL COILOVER</U>
( Off the shelf spring rates)
Front: 6.3 Kg/mm / 350 lbs/in
Rear: 4.5 Kg/mm / 250 lbsin
<U>K SPORT COILOVERS </U> (Sport version)
Front: 10.0 Kg/mm / 560 lbs/in
rear: 6.0 Kg/mm / 336 lbs/in
<U>PIC COILOVERS</U> (CRX version has raised top hats)
Front: 8.0 Kg/mm / 448 lbs/in
<U>OMNI POWER COILOVERS</U> (street version)
Rear: 8.0 Kg/mm / 448 lbs/in
<U>OMNI POWER COILOVERS</U> (sport version)
Front: 12.0 Kg/mm / 670 lbs/in
Rear: 10.0 Kg/mm / 560 lbs/in
<U>EIBACH PROSTREET-S COILOVERS</U> (#4007.711)
Front: 6.1 Kg/mm / 342 lbs/in
Rear: not available when i called
<U>D2 COILOVERS</U> (purple)
custom spring rates: 3.5, 7, 9, 11, 13, 15, 18, 22. Kg/mm
<U>FUNCTION 2 FORM COILOVERS</U> (black/red)
custom spring rates: 6.0 - 13.0 Kg/mm
available at additional cost: 6.0 - 24 Kg/mm
Modified by gringo7718 at 5:19 AM 3/8/2007
Old 03-06-2007, 12:57 PM
crxpwr1's Avatar
Default Re: 88-91 CRX Spring Rates *STICKY* (gringo7718)
nice.....very nice
Old 03-06-2007, 01:00 PM
Themadone's Avatar
nice i had the h&r sports on my sedan those things are soft as hell to me
Old 03-06-2007, 01:03 PM
Lucky-13's Avatar
Default Re: 88-91 CRX Spring Rates *STICKY* (Themadone)
Old 03-06-2007, 01:35 PM
solorex's Avatar
Default Re: 88-91 CRX Spring Rates *STICKY* (YouvGotMail)
Just one thing: All the springs listed here look to be progressive rate springs, so even though it states that Neuspeed Race is 575lb/in front and 540 lb/in rear I am assuming that this is at full compression? I would imagine they are a fair amount softer than that at initial compression. Reason I say this is that I used to run Neuspeed Race and went to Eibach ERS on Ground Controls. A 500 lb/in linear rate spring is stiffer than the 540 lb/in Neuspeed.
Old 03-06-2007, 01:50 PM
89efDUSTY's Avatar
Default Re: 88-91 CRX Spring Rates *STICKY* (solorex)
Old 03-06-2007, 02:19 PM
PACT man's Avatar
Default Re: 88-91 CRX Spring Rates *STICKY* (89efDUSTY)
Maybe expand to add the hatch's also??? Wouldn't mind seeing the K-sports' either, as I'm interested in those.
Old 03-06-2007, 02:32 PM
RACINTWEEK's Avatar
Default Re: 88-91 CRX Spring Rates *STICKY* (PACT man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man &raquo;</TD></TR><TR><TD CLASS="quote">Maybe expand to add the hatch's also??? Wouldn't mind seeing the K-sports' either, as I'm interested in those.</TD></TR></TABLE>
all Ed's are the same.
its too bad all the harder springs drop too much, i live in the mountains and scrape going places w/ just a 1.5" drop
at least the softer rates help on dirt roads
Old 03-06-2007, 02:33 PM
Bevenue's Avatar
anybody know the rate for the sprint race and the sprint sports for the crx?
Old 03-06-2007, 07:21 PM
92civicfreak's Avatar
i dont wanna sound like a dick, but shouldn't it be lbs/inch since thats how much weight it takes to compress the spring to 1 inch?
Old 03-06-2007, 10:10 PM
Tyson's Avatar
Default Re: (92civicfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak &raquo;</TD></TR><TR><TD CLASS="quote">i dont wanna sound like a dick, but shouldn't it be lbs/inch since thats how much weight it takes to compress the spring to 1 inch?</TD></TR></TABLE>
rofl
Old 03-06-2007, 10:35 PM
djphonics's Avatar
I will add one to the list:
Ground Control Coilovers -&gt; Spring rate = whatever you want!
Old 03-07-2007, 05:35 AM
driveahonda's Avatar
How about generic coilover rates. They should be right around s2 correct?
Old 03-07-2007, 07:33 AM
88 rex's Avatar
Default Re: (djphonics)
Buy linear and pick your own rates and lengths.
Old 03-07-2007, 09:09 AM
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
rofl</TD></TR></TABLE>
idk if ur laughing at me or him cuz if u notice his #'s are way off
TEIN S-TECH
Drop: 1.5"
front: 4.8 Kg/mm / 269 In/Lbs
rear: 2.2 Kg/mm / 123 In/Lbs
Kg = measurment of weight / mm = measurment of distance
In = measurment of distance / Lbs = measurment of weight
whats right?
Old 03-07-2007, 09:43 AM
Tyson's Avatar
im laughin at the op. its obvious its a mistake.
Old 03-07-2007, 10:35 AM
gringo7718's Avatar
Default Re: (Tyson)
I FIXED THE MEASUREMENTS TO CORRECT MYSELF Lbs./In.
Now, you say that my #s are off ---- Well here are the websites and manufacturer contact info so everyone can see that my #s are right. Besides I am just trying to provide some info that some people might find useful and contribute to the knowledge base. If all you can contribute to this post, is to point out a typo and say my info is incorrect without any information to back it up. 92civicfreak
<U>TEIN</U>
http://www.tein.com/stech.html
<U>PROGRESS</U>
http://progressauto.com/store/...d=263
TANABE
http://www.tanabe-usa.com/spri...?id=3
<U>H&R</U>
http://www.hrsprings.com/site/index.html
H&R Special Springs, LP
3815 Bakerview Spur #7
Bellingham, WA 98226
USA
phone 888 827.8881
fax 360 738.8889
<U>NEUSPEED</U>
http://www.neuspeed.com/contac...mport
800-423-3623 (Continental U.S. only, except California)
805-388-7171 (Alaska, Hawaii, California & international residents)
Monday - Thursday 7:00 AM - 5:00 PM Pacific Standard Time
Friday 8:00 AM - 5:00 PM Pacific Standard Time
Saturday & Sunday - Closed
<U>EIBACH</U>
http://eibach.com/cgi-bin/html...32316
1(800)-507-2338
<U>ESPELIR SUPER ACTIVE DOWN</U>
http://www.mackinindustries.co...s.pdf
<U>SKUNK 2 RACING</U>
http://www.skunk2.com/contact.html
Tel: 888.276.3399
http://www.rs-r.com/store/pc/v...ct=44
http://www.rs-r.com/store/pc/v...ct=66
<U>K-SPORT</U>
http://www.ksportusa.com/produ....html
<U>FUNCTION & FORM COILOVERS</U>
http://www.f2autolife.com/stor...id=30
Modified by gringo7718 at 7:52 PM 3/7/2007
Modified by gringo7718 at 5:17 AM 3/8/2007
Old 03-07-2007, 10:36 AM
1hgej1's Avatar
Default Re: (Tyson)
my skunk2's are soft as hell. i would've never guessed they were 257lbs in the front, and 112lbs in the back when not compressed in a turn. god damn they get stiff in a turn though according to the chart.
Old 03-07-2007, 01:47 PM
Default Re: (gringo7718)
i dont mean ur #'s sry i know it was the poor choice of words, its ur ratio's
kgf/mm,lbs/in kgf/mm,lbs/in mm
inch mm
inch
thats right off of tein's site so right back at u
Old 03-07-2007, 05:13 PM
dr_latino999's Avatar
Here's the conversion from kg/mm to lbs/in (I don't speak metric that well) --&gt;
1 kilogram / millimeter = 55.9974146 pounds / in
Old 03-07-2007, 06:00 PM
STREETWERKZ's Avatar
Default Re: (dr_latino999)
STICKY.
Old 03-07-2007, 11:51 PM
Tyson's Avatar
Default Re: (STREETWERKZ)
added to the faq.
this is not sticky worthy, imo.
Old 03-22-2007, 06:10 PM
ComeOnKip's Avatar
Location: Where the wild things are in, NY, United States of America
I was incredibly disappointed with my H+R Race springs. too low, too soft. I don't mind a jouncy ride, but there was no response.
Old 03-22-2007, 06:30 PM
Lucky-13's Avatar
Default Re: (ComeOnKip)
Ouch my tenzo springs arent up there. LoL.
Old 03-27-2007, 02:02 PM
ComeOnKip's Avatar
Now that I have my eibach sportlines on order (to raise the car up until my order for zeals comes in) I will be using the Quantum Spring Rater this friday to actually measure what these springs are, not just what the factory says they're rated at. My moneys that the H+Rs are wildly off and the eibachs are fairly on point, just my .02.
Quick Reply: 88-91 CRX Spring Rates *STICKY*
