problem revving past 5000rpm on B18C, like fuel cut off, tach bounces
Old 11-18-2011, 05:40 AM
tronic's Avatar
Default problem revving past 5000rpm on B18C, like fuel cut off, tach bounces
The problem happened at some point when I was doing a track day last Saturday. Nothing dramatic happened, it took me a couple turns to figure out what was going on then I limped home. Drove it 300 miles this week, seems pretty normal until 5000+ rpms when it gets a little sluggish and then 6500ish when it runs out of steam and flounders.
I put in a bottle of Redline fuel system cleaner, a new OEM fuel filter; didn't help.
I'm running a Phearable.net chipped OBD1 ECU in an OBD2B car. Engine is a B18C engine that should rev to 8800. Not getting any CEL.
any ideas?
Here's a vid of the tachometer when it happens:
youtu.be/89FH1wtTMU
http://youtu.be/89FH1wtTMU
Old 11-18-2011, 06:45 AM
houghton's Avatar
Default Re: problem revving past 5000rpm on B18C, like fuel cut off, tach bounces
Had the same problem with my set up about 1 month ago. My ECU had a lot of corrosion and build up from moisture and so did my cable from ECU to my Hondatta s200. Replaced the corroded cable and cleaned the ECU. Also needed a retune for other reasons, hasn't happened again yet. I have launch control and it was stuck on that 4500 RPM instead of my 8800 limit. I would recommend opening your ECU and checking for any kind of crap that may be in there.
Hows your fuel mileage been?? I was also dumping fuel at the time.
Old 11-18-2011, 05:03 PM
haphazard's Avatar
just a guess but maybe a distributor
Old 11-19-2011, 06:50 PM
tronic's Avatar
just checked the dizzy: rotor set screw came loose! caused some damage in the inner cover. so the rotor was loose the whole time, causing the ignition to be wacky. I can see why at 5000+ rpms it was causing that behavior.
TheEGmad
10-17-2017 03:22 PM
KiLLa CaM 06
12-13-2011 03:17 PM
JasonST
01-07-2007 07:17 AM
spock_rocker
26
04-11-2006 03:26 PM
Quick Reply: problem revving past 5000rpm on B18C, like fuel cut off, tach bounces
