Power Lock Buzzing Noise
Old 03-04-2007, 08:04 AM
5G_Vtec's Avatar
Default Power Lock Buzzing Noise
I have a 1995 Accord EX and all of the sudden my passenger door looks have begun to make a buzzing noise when the auto lock kicks in after ignition or when I manually lock the doors (also when I engage the alarm system). I know there are other Accords out there that have the same problem because I have heard it happen. I am just getting sick of hearing this buzzing noise. Does anyone know anyway to fix this problem?
Old 03-04-2007, 08:47 AM
loup05's Avatar
Default Re: Power Lock Buzzing Noise (95_VTEC)
disconect it. thats what i did i just got tired of hearing it and besides no one usually rides in the back (4dr)
Old 03-04-2007, 09:15 AM
5G_Vtec's Avatar
Default Re: Power Lock Buzzing Noise (loup05)
Yeah but that was your rear passenger door. I have a 4 door also, but this is happening with my front passenger door and that door is used pretty frequently. I mean I know I can remove it and just pop up the lock when needed, but I'd rather have all of my doors power locks working.
Old 03-04-2007, 09:23 AM
Slunk's Avatar
I was about to disconnect mine a while back then they stopped doing it. As far as fixing the problem I was told that you need to replace the actuator (sp?) which is $100 part.
Old 03-04-2007, 09:30 AM
5G_Vtec's Avatar
Default Re: Power Lock Buzzing Noise (Slunk)
Yeah I read about that actator, but I wasnt sure if it was that because what I read was that on a 1996 Honda Accord, the <U>front driver's</U> side door was making the same sound, but the locks were not locking. So, I didn't know if infact it was the actuator or not. I went to the junkyard around here last night seeing if i could possible get one, but it was too hard to get and I don't know if I was looking in the right spot for it. I guess I'll have to go back because there's a ton of Accords there ranging from 1993-1997. I also saw that the actuator was $100 part and I'd rather not spend $100 on a small part like that and just go to a junkyard and possible find one.
Old 03-04-2007, 05:21 PM
Slunk's Avatar
Default Re: Power Lock Buzzing Noise (mustbeballiin)
Yeah my 97 was making a little different type of noise so we could have different problems. When I would lock my door is would just sound like it just kept trying to lock. Made me a little nervious to walk away.
Old 03-05-2007, 05:41 PM
5G_Vtec's Avatar
Yeah, I definitely don't want to leave any of my doors unlocked because of the expensive stuff I have inside of the car .
But, I will definitely try the actuator once I can figure out where exactally it is and how to get it off and out from the middle of the door. I wish there were some type of instructions on how to take it out, but I can't seem to find anything.
Old 03-05-2007, 05:59 PM
Mr Yamada's Avatar
Hondadude told someone in another post/thread how to fix those door lock actuators.
I read it not to long ago
Old 03-05-2007, 06:06 PM
5G_Vtec's Avatar
Default Re: Power Lock Buzzing Noise (Mr Yamada)
Oh really? Do you happen to have the link to that thread?
Old 03-06-2007, 12:27 PM
NeKe1point0's Avatar
i have had this prob before and it just started on my passanger side now its an easy fix...its the door actuator as u have noted above but u can buy one off ebay for about $10.83 shipped !!! just got just got mine installed nore more buzzing !!
Old 03-06-2007, 12:42 PM
5G_Vtec's Avatar
Default Re: Power Lock Buzzing Noise (NeKe1point0)
Yeah a lot of Accords have this problem from what I have seen and heard. If I can't get a good actuator from the junkyard off an Accord, I'll do what you did, order one off Ebay. Did you install the actuator yourself? Or did you have someone else, like a mechanic do it? I have no idea how to take it off nor install it and I don't want to spend money just to have that installed when I know I can do it myself with some instructions. I just have no idea where to get instructions on how to take it out and install it on my car. Any suggestions where I can find some instructions or do you have some by any chance?
Old 03-02-2009, 09:45 AM
elpiar's Avatar
I have exactly the same problem. any instructions?
Old 03-02-2009, 11:40 AM
redbull-1's Avatar
Here are instructions:
https://honda-tech.com/forums/honda-accord-1990-2002-2/94-97-accord-d-s-lock-actuator-microswitch-repair-reset-2465699/
Old 03-06-2009, 09:28 AM
ttcheung97's Avatar
loooks gooood.
i know they're (the actuators) are different for each door, but would the location be relatively the same?
the buzzing's come to a point where it startles the baby, can't let that continue on any longer.
evacdevice
12-11-2005 08:45 PM
eppoh
07-16-2005 08:11 PM
phuc
09-21-2004 02:18 PM
fe519
11-03-2002 08:31 PM
TypeR0207
06-10-2002 12:58 PM
Quick Reply: Power Lock Buzzing Noise
