#26 | |||||
1996 Honda Accord LX Sedan |
#27 |
slick post!
#28 | |
H-T Order of Merit
If you look in this thread, there are multiple pictures of the VTEC solenoid in the first post... http://www.accordinglydone.com...11176 for reference, the VTEC solenoid is part #9 in the following diagram... ![]() Hope that helps you. |
#29 |
H-T Order of Merit
ok, now... A sponsor from here on H-T read the write-up and said they are going to be adding a Tech Section to their website and would like to include this article if I was interested. Sounds good to me, so my guestion to you guys is...
Are there any other suggestions before I finalize the PDF and send it to them so they can host it on their site? I will add a tool list as previously suggested, just wondering if anyone else has any other suggestions. Once they have it hosted (probably a couple weeks away, making other changes to their site) they will send me a link to which I will then add to the opening post of this thread. |
#30 |
Ah, thanks! And again, really great writeup!
#31 |
H-T Order of Merit
yep, no problem.
Thanks
#32 | |
Technically the VTEC solenoid is #11. #9 is the entire VTEC spool valve (including the solenoid).
JimBlake '03 Accord & '07 Civic '01 Saab 9³ & '05 9²x TECHNICAL(?) quote... Quote:
#33 |
H-T Order of Merit
ah, thanks for clarifying
either way, he needs to make sure he gets the whole assemblyalso, back on topic
#34 |
H-T Order of Merit
any other suggestions?
I'm thinking about taking some additional pictures of a few things on my F22B1 in the garage. Like a picture of the water pump bolts and that, just to add a little more detail to the write-up before I send the PDF to be hosted. If anyone has anymore suggestions, let me know. I'm hoping to finish the additional changes and have it email to them by the end of the weekend. |
#35 |
H-T Order of Merit
ok, I took some additional pictures on my F22B1, added a general tool list and moved the parts list to the top.
Let me know what you think. I'm currently working on getting the PDF finished so I can send it to be hosted. I'll look pretty much just like this write-up. So if anyone has any suggestions, now is the time.
#36 |
H-T Order of Merit
ok, the PDF is now hosted thanks to Farina Motorsports
It can be found in the Tech section of their website and I've also added a direct link to the first page of this thread. F22B1 Timing Belt How-To **If I've already sent this to anyone earlier, please download this one, I have made changes and added pictures** |
#37 |
1. why do u have to stick a screwdriver or a bolt into the mantaince hole for the rear shaft.. what does the rear shaft do...
2. the one bolt that has the waterpump with the spring loaded.. do u have to take off the spring loaded for the tensioner off or no.. and if no how does that bolt come off if the spring is in the way 3. does the front shaft run to timing belt or balance belt... 4. so the front shaft is what runs the oil pump? 5. how does the balancer work does it sit under the crank and when the crank spin it absorbs the vibration 5. what hapens if u don't align the oil pump housing? 6. the crankshaft seal is it hard 2 change? do u need to really take the whole IM off and headers off to get to it? 7. if balance belt goes bad will it shake the engine so bad it will feels like an earthquake? thanks if u can answer this.. me and a buddy wants to do it this weekend..
Vouches : Frank_2.0L |
#38 |
H-T Order of Merit
1. That aligns the rear shaft to the correct position. It's not what the rear shaft alone does, it's what the front and rear balance shafts do. http://en.wikipedia.org/wiki/Balance_shaft
2. Yes, just remove the spring from the bolt and then remove the bolt with a deep socket or an open end wrench. 3. The front balance shaft is run off the timing balance shaft belt. The timing balance shaft belt is driven off the crank shaft and runs both the front and rear balance shafts. 4. I'm not completely familiar with the oil pump, but I'm pretty sure it's driven off the crank shaft. If I'm wrong, someone please correct me. 5a. http://en.wikipedia.org/wiki/Balance_shaft 5b. I'm not sure what your asking here. Are you asking what happens if you don't align the timing belt drive pulley mark with the mark on the oil pump housing? 6. I can't remember if the oil seals were replaced or not. I know we didn't remove the intake manifold or the exhaust manifold for what it's worth. But I can't remember if the oil seals were replaced or not, there were also 3 of us working on the car. 7. If the timing balance shaft belt breaks you will most likely experience more than usual vibrations, how much though I'm not sure. Maybe someone that has eliminated the balance shafts can add as to how much vibrations were added. |
#39 |
ate my pixel
What is the purpose of the three marks on the crank pulley?
01 BB6 /// 00 CBR600F4 |
#40 |
H-T Order of Merit
For use with a timing light to set ignition timing.
#41 |
ate my pixel
Thanks touring. I used them for that but I couldn't remember if I actually set the timing with them when I replaced the belts. I guess I must have since it runs like a champ.
#42 |
H-T Order of Merit
haha
#43 |
I love it.
AFAccord, I'd like to see a write up for the 6th gen f23a :-) |
#44 |
So I just did this on my 2001 Accord EX f23a4 5speed manual, and have a few comments/notes/suggestions:
1. Step 11 should include removal of the cast iron motor mount from the block (held on by 3 bolts) after removing the lower cover. This is necessary to get to the water pump later. 2. Step 38 should include installing the cast iron motor mount back onto the block before installing the lower cover. Also, a note to make sure the 6mm bolt is removed (the one holding the timing belt tensioner in place) would be nice. 3. For step 30, I used a 3inch drywall screw, just another option. A helpful tip is to stick the scew/whatever into the slot and rotate the rear balance shaft until the screw goes all the way in. 4. For step 10, I could not obtain this holder device, so I removed the starter and shoved a screwdriver with a rag into the flywheel to make sure the engine did not spin. My impact wrench didnt work, so I ended up getting a swing bar & 10" & 6" extensions with a 5' pipe. 5. I used white out to mark a tooth on the crankshaft gear & the camshaft gear and the timing belt, and then transferred the marks over to the new belt to ensure it lined up. Did the same thing with the balance belt. Just another thing to ensure you're doing things right. 6. I downloaded the electronic service manual and there are 3 pages on the installation that help out a bit. I'd recommend downloading them, or I can email somebody pdf's if somebody would host them. casualties: 3/8" extension, 1/2 to 3/8" converter (stanley), 3/8 to 1/4 converter, 19mm impact socket (pittburgh). I will replace these with craftsman goods now :-) Modified by steedums at 1:26 PM 6/3/2007 Modified by steedums at 8:38 PM 6/4/2007 Modified by steedums at 11:49 AM 6/10/2007 |
#45 | |||||
H-T Order of Merit
first of all, thanks for the suggestions
There was a BIG discussion about this years ago here in the Accord forum on why you shouldn't use this method. There was a link I posted with pictures of a damaged tranny housing but I can't find that discussion or the thread with pictures of the damaged tranny housing. Quote:
#46 |
I know about step 37, now :-p. although I didn't until i found out I was a cover bolt short...
I can agree that putting the screwdriver into the flywheel isnt the best solution, but its what I did. If I did it again, I would buy that "special" tool. I'm glad my notes will help somebody in the future :-) |
#47 |
steedums, how strong was ur impact gun that did not work?
#48 | ||
H-T Order of Merit
#49 | |
I was putting almost all my weight (im 160lbs) on the breaker bar at 5 ft, so I'm estimating it was over 700ft/lbs to break the bolt loose.
#50 |
Mine took 1200 psi from a 1" drive gun. It sounded like a 50 cal. machine gun trying to break loose that bolt.
| Bookmarks |
| Tags |
| 1990, 2002, accord, belt, civic, clearance, f22b1, honda, install, kit, replace, replacing, steel, support, timing, valve |
