Old 02-27-2007, 07:00 AM   #1
Keedo98
Keedo98's Avatar
Default 1995 Accord - odometer not working
My odometer stopped working - any idea? Is there a fuse or module for this?
It worked for a while, then it would stop and start - it finally just stopped all together.
Any help would be appreciated?
Keedo98 is offline   Reply With Quote
Old 02-27-2007, 07:55 AM   #2
Twixle
ate my pixel
Twixle's Avatar
Default Re: 1995 Accord - odometer not working (Keedo98)
Is your speedo also working intermittently?, or just the odometer?
08 FA Si Mugen
Originally Posted by George Knighton View Post
Well, how about **** YOU, you conceited bitch.
Twixle is offline   Reply With Quote
Old 02-27-2007, 08:19 AM   #3
Keedo98
Keedo98's Avatar
Default Re: 1995 Accord - odometer not working (accord2021)
Just the odometer - it was weird - it would work for say 100 miles and when it was gonna turn (000), it would stop....then it might start working again -but for the last 4-5 months it just does not work
Old 02-27-2007, 03:51 PM   #4
hondadude
hondadude's Avatar
The people you bought it from broke it when they went in there and rolled back the miles before they sold the car to you.
Year and model Helps get better info
My crystal ball is out of service,and
I failed Clairvoyance 101 class
hondadude is offline   Reply With Quote
Old 02-27-2007, 04:44 PM   #5
Twixle
ate my pixel
Twixle's Avatar
Default Re: 1995 Accord - odometer not working (hondadude)
Maybe. I've taken out gauge sets where the speedo was broke and tried to see if I could roll the odometer back to zero, and it would be very very hard to roll back the odometer and then reassemble the cluster so that it would function again. It could just be that it got stuck, sometimes the gears can bind up, especially if a bunch of numbers are turning at once, like 99999 to 100000. What's the odometer currently reading?
08 FA Si Mugen
Old 02-27-2007, 05:19 PM   #6
Loco-B
Loco-B's Avatar
Hey look at it this way. If it isnt rolling up, your car isnt getting any older! Click the image to open in full size.
2008 Civic SI RR Coupe
Project: 2G DSM Eclipse, 6-Bolt swap, 341hp / 258lbs/tq on 18psi mild street tune.
Loco-B is offline   Reply With Quote
Old 02-27-2007, 05:34 PM   #7
Twixle
ate my pixel
Twixle's Avatar
Default Re: 1995 Accord - odometer not working (accordcd_7)
I'm issuing you an idiocy citation.
and then you can't keep track of your maintenance schedule Click the image to open in full size. and can't legally sell the car unless you check "actual mileage not known Click the image to open in full size. and you have to disclose that to the buyer of the car Click the image to open in full size.
It's really a bad deal all around, why do you think they put odometers in cars in the first place?
08 FA Si Mugen
Old 02-27-2007, 06:32 PM   #8
professorman
try pushing the key into the maintenance indicator reset slot in the speedometer. I had reset mine one day, and I was driving a 300 mile trip and half way up, the odometer stopped working. Finally I remembered that I had pushed the key into the maintenance indicator reset, so I pushed the key in and really shoved it in. It started working after that. Apparently, it was not pushed in properly.
94 5spd Accord -270k | 99 Accord Auto -120k | 00 BMW 528i | 03 Suzuki GSX-R1000 | 04 Honda Aquatrax Jet Ski
RoopsPhoto.com | facebook.com/RoopsPhotography
professorman is offline   Reply With Quote
Old 02-27-2007, 06:34 PM   #9
95AccordSC
95AccordSC's Avatar
http://www.facebook.com/Viehweg13
I had the same problem, i just pushed the reset button on the odometer, maybe 5 or 6 times really hard and it started working again, i havnt any problems from it since. It prob. just got stuck or jammed or something.
Modified by 95AccordSC at 7:50 PM 2/27/2007
95AccordSC is offline   Reply With Quote
Old 02-27-2007, 07:50 PM   #10
as_fast_as_u
as_fast_as_u's Avatar
get ur dash out, unplug all the plugs.....on the biggest plug, i think a middle there is blue wire with a little white line running on its side, thats the wire most people put a switch on to turn miles back on and off, mayby when the sold u it they did not reconnect that wire back correctly...trace it down a bit till u find a cut, and see if its loose, if it is, just retapa and connect better...that should do the job...most cars with prior milage "tap in" have this problem....the rpms and light on odometer work, but the speed gage nor miles are moving, so do that first...its literally a 5 min job
BTW im hee in detroit area, so if u need more help, i candef help, i used to do this kind of stuff on our accords, so i would be able to do this right....pm me....gl....ALEX
"In time we hate that which we often fear..." William Shakespeare
Wisdom is the reward you get for a lifetime of listening, when you'd have preferred to talk.
"In a battle between David and Goliath, nobody ever roots for Goliath..." Charles Barkley
[B]2000 accord...GUDE: ported/milled head,tb,manifold,cam(lift 400 dur.262)DC sports header,APEXi WSII exhaust,AEM cold air,walboro fuel pump,SKUNK2 cam gear, e-manage [/B]
as_fast_as_u is offline   Reply With Quote
Old 02-28-2007, 05:33 AM   #11
Keedo98
Keedo98's Avatar
Nah- I have owned the car since it had 30K on it - now it has 115K - so I doubt that is the case - but thanks for your concern
Old 02-28-2007, 05:34 AM   #12
Keedo98
Keedo98's Avatar
Default Re: 1995 Accord - odometer not working (95AccordSC)
I tied this and it worked!!!
Thanks - funny, anyone want to buy a Honda Accord with 115K miles give'r take 10K?!?!?!?! Just kidding - thx again to all!!!!
Modified by Keedo98 at 1:55 PM 2/28/2007
1995, 1996, 96, 99999, accord, bought, car, honda, indicator, mileage, odometer, odometr, stopped, stuck, work, working
