| Welcome to Honda-Tech! | ||
#1 |
my air conditioner stopped blowing cold so i bought some 134a refrigerant and i want to ask how do i put it in, this is kind of a stupid question but i dont know **** about a/c's. please help.
#2 |
save yourself a headache and have a professional do it for you.... overcharging your system can lead to failure and or loss of cooling performance as the system cycles on and off due to high pressure cut out.
#3 |
Not to mention the chance of losing your hand when the can of refrigerant frags on you.
2003 PWP RSX-type S "Need Help" or "Quick Question" = NO CLICK "I may not always be right, BUT I'm never wrong." |
#4 | |
#5 |
lol
Yea mechanics use some **** and then they check the pressure, and stuff... I also didnt try :D
"Yeeeyyaaa" [img]http://images.honda-tech.com/set1/smile/emwink.gif[/img] [url="http://www.myspace.com/unknownbelow"]http://www.myspace.com/unknownbelow[/url] |
#6 |
Your 92 accord used R12 frm the factory. Yayyy!
You need to do a R134A retrofit before you can put that R134A refrigerant. I don't think you are equipped to do that.
2001 Civic Coupe EX 5-speed, 195k miles 1993 964 C2 2011 Silverado 5.3L |
#7 | |
#8 |
If the valve on the charge hose fits, it has been retrofitted. If it is not, then it will not. Retrofit involves removing all of the R-12 with a recovery machine (or releasing it and making an ozone hole), replacing the dryer, vacuuming the system to remove the moisture, and charging with a POE oil charge and 80% (of the factory R-12 charge in lbs) of R-134a. You MUST add POE oil or the compressor will fail because R-134a will not carry the mineral oil in a R-12 system, and PAG oil (the factory R-134a type oil) does not get along with R-12 retrofits.
| Tags |
| 16, 1991, 1993, 2001, accord, honda, oil, pag, put, r134a, refridgerant, refrigerant, rsx, type, types, valve |
