Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 02-20-2007, 02:26 PM   #1
Splat
Collector-o-Guns and Drinker
Splat's Avatar
Default How long does it take to charge a completely flat car battery?
Left Boxy's lights on the other day. Dead as a doornail Click the image to open in full size.
I currently have it hooked up to the Turbo Pig via jumper cables, Pig is running. How long is this going to take? Click the image to open in full size.
Pat http://images.honda-tech.com/set1/smile/emdgust.gif
'99 S70 T5M (1 of 197), '02 S40 1.9T, '83 245DL Wagon, 244GL Sedan (busted), '76 IH Scout II
I believe she's going down,
I believe we're gonna die die die!
Splat is offline   Reply With Quote
Old 02-20-2007, 02:26 PM   #2
Rednas
Rednas's Avatar
Default Re: How long does it take to charge a completely flat car battery? (Splat)
like 20 minutes, then go for a long drive.
Rednas is offline   Reply With Quote
Old 02-20-2007, 02:28 PM   #3
Splat
Splat's Avatar
Default Re: How long does it take to charge a completely flat car battery? (Rednas)
Damn. Guess five minutes wasn't enough? Click the image to open in full size.
Don't feel like driving, I just need to get Boxy to the point where it will be quick/easy to jump in the morning. I guess I'll let it run for a bit this evening once I get her started.
Old 02-20-2007, 02:40 PM   #4
Jonesy69
Jonesy69's Avatar
My Camry just got its 6 month startup. Took a half hour or so hooked up to the Altima to get it to turn over. The cables almost melted, but thats what I get for buying $5 jumpers. lol
ahhh ha, hush that fuss
http://www.ryanljones.name
Jonesy69 is offline   Reply With Quote
Old 02-20-2007, 03:19 PM   #5
Splat
Splat's Avatar
Default Re: How long does it take to charge a completely flat car battery? (Jonesy69)
Melted? Damn... I've got some nice ones, no issues.
But it's actually a good thing the battery went flat. After 15-20 minutes I tried starting Boxy. Cranked just fine, but wouldn't fire. I let it charge a bit longer just in case, but same result.
I got to checking under the hood, and found that the main 30-amp fuse that feeds, er, something related to the engine running was loose in its mount. So it was just a matter of time before it would have vibrated loose and left me stuck in who knows what kind of situation.
Secured the fuse and she fired right up Click the image to open in full size.
Old 02-20-2007, 03:36 PM   #6
Mark sans
Mark sans's Avatar
Yeah -- usually a car with cable on it shoudl start toot sweet! (30 seconds).
(as my Miata did Thursday when I Click the image to open in full size. left the headlights "up" Click the image to open in full size. during a snow/ice storm -- thinking it would keep them from freezing closed, but really just allowing enough snice to get into the bucket to keep them from going down and causing the down motor to run all day while it was parked. Did I mention Click the image to open in full size.
Enough.
Mark sans is offline   Reply With Quote
Old 02-20-2007, 03:38 PM   #7
rico91stang
Clown Prince of GDD
2009 Aston Martin DBS
rico91stang's Avatar
Are you from england? Battery flat?
It all depends on the type of battery charger. Some batterys will not re-charge. Check the voltage and the amount of fluid in the cells. If it is below 11.5 volts typically it won't hold a charge. If the fluid had gone below the cells, call it quits.
Originally Posted by Cole D View Post
This is my first time in GDD and I don't think I'm coming back.
Free Brice 2014 <- This gets in enough signatures we will make it happen. For the people of course. -IB
rico91stang is offline   Reply With Quote
Old 02-20-2007, 03:39 PM   #8
rico91stang
Clown Prince of GDD
Driving the car has little effect when it comes to charging a battery back up.
Old 02-20-2007, 03:42 PM   #9
Splat
Splat's Avatar
Default Re: How long does it take to charge a completely flat car battery? (rico91stang)
No, I'm not from England. But for whatever reason, I use that term. I'll call it a dead battery, but say that my battery is flat. Meh.
The battery itself was fine, I just left the lights on and ran it down. It charged fine and allowed me to discover my fuse issue.
accord, battery, car, cars, charge, charged, charging, completely, dead, die, doest, dose, drive, flat, honda, light, long
