> Honda Civic (2001- 2005)
Old 10-20-2009, 06:07 PM   #151
CivcaIh
Default Re: THE TURBO THREAD - Boost for Noobies!
Looked at injectors rsx 310 cc's 350 of ebay set of four((
RDX injectors 410 part number?? Links. will they direct fit or I need to do something to make them fit?
about AEM EMS standalone on an auto any more information will be helpful
CivcaIh is offline Report Post   Reply With Quote
Old 10-23-2009, 11:26 PM   #152
omgk20a
Icon3 Re: THE TURBO THREAD - Boost for Noobies!
Similar to the pcv valve. There is a check valve to the brake vacuum booster. Should this device be upgraded?.... i.e. on a turbo civic using dsm check valve? I've heard of "pressurized" vacuum brake booster...and you have no power brakes when it happens especially on the freeway boosting at over 20psi.
omgk20a is offline Report Post   Reply With Quote
Old 10-24-2009, 02:39 PM   #153
supafil25
supafil25's Avatar
the only thing you have to do to make those injectors fit is to take out the fuel rail studs and head over to you hardware store and get longer ones or just long bolts. other then that they are plug and play.
you will have problems running an auto with aem ems. you can prolly do it if you get a stand alone tranny controller.
imo its pointless. the auto trans cant handle more then 200 hp. mine failed the second day i was boosted.
Buy My Shit!
Full D17 manual swap $900, D17 motor $350, Eagle H Beams D17 $350
http://www.hondamarketplace.com/show....php?t=2668519
supafil25 is offline Report Post   Reply With Quote
Old 10-24-2009, 06:11 PM   #154
orlandoEM2
orlandoEM2's Avatar
Default turbo manifold
is their a turbo manifold for a d17 engine to where i can keep my ac? if so what kind and where can i get it thanks
orlandoEM2 is offline Report Post   Reply With Quote
Old 10-25-2009, 03:47 PM   #155
supafil25
supafil25's Avatar
Default Re: turbo manifold
dezod hks and you can used the obx if you run your piping the other way.
Buy My Shit!
Old 10-26-2009, 10:36 AM   #156
kenbo21
kenbo21's Avatar
Send a message via AIM to kenbo21
Obx mani will not work with a/c...unless u get a really small turbo like a 13g or something...my t3/t4 .63 ap would hit the a/c housing...tried turning the turbo around the other way and it would hit the block....
But you can get the Dezod mani its a/c and p/s comp.....go to dezod.com
kenbo21 is offline Report Post   Reply With Quote
Old 11-05-2009, 07:03 PM   #157
FamousLad254
Default Honda Civic 03 Turbo?
I have a 03 civic ex i want to turbo. Its automatic. If you know any sites that can get me a d17 turbo kit just post back. Thanks. Also will i need to make it manual?
FamousLad254 is offline Report Post   Reply With Quote
Old 11-05-2009, 07:09 PM   #158
SergEK
Default Re: Honda Civic 03 Turbo?
Unless level 10 makes a better converter for your trans I wouldnt waste my time going turbo on that thing...leave it a nice DD and build a project car
Automotive Photographers PM for opportunity $$$$
XBL = SergEK9
SergEK is offline Report Post   Reply With Quote
Old 11-05-2009, 08:40 PM   #159
slowassd17
boosting a auto tranny is possible, just dont boost to an extreme amount, keep it at around 5 or 6 psi and your should be fine, just dont drive like an animal
slowassd17 is offline Report Post   Reply With Quote
Bookmarks
adapter, civic, d17, d17a2, garrett, gt25, homemade, internals, oil, psi, restrictor, stock, t2516g, t28, t3t4, tuned, turbo, valve
