My SRS light is on (Honda Civic 1996 DX 2Dr) What could be wrong?
Old 02-11-2007, 07:45 PM
spaceman00's Avatar
Default My SRS light is on (Honda Civic 1996 DX 2Dr) What could be wrong?
My SRS has been on for over 2 months now, never really bothered to check what the problem could be.
Can anyone help me?
Where can I get this fixed? How much would it cost?
Can I do it myself?
Old 02-11-2007, 07:49 PM
LIKKLEbit's Avatar
Default Re: My SRS light is on (Honda Civic 1996 DX 2Dr) What could be wrong? (spaceman00)
I cant tell you what you may have done to set it off,
but heres how to fix it, found in the FAQ; which is located 3rd from top of the civic/del sol board: https://honda-tech.com/zerothread?id=264288
Old 02-11-2007, 10:28 PM
usmcpab's Avatar
Most of the common things are the seat belt buckle or the air bag. If its the buckle then you could get that fixed at any Honda dealer for free since the part of the srs components are under a lifetime warranty. And the models of 96-97 also have an extended warranty to 150,000 miles. So if ur cat was jacked up they would replace for free under warranty. Oh btw I work for Honda. So just go to ur local Honda dealer and see what is still covers. But I know that even checking the SRS light is under the lifetime warranty of the SRS, doesnt matter how many miles. But once more not all SRS components are covered by the warranty. Oh and the car colud not have been in an accident either for the SRS warranty to apply.
Old 02-11-2007, 10:30 PM
muhaMan's Avatar
hmmm... mines been on so long that i thought it was normal for it to be on 24/7... what does SRS stand for??
Old 02-11-2007, 11:05 PM
SirRevvs's Avatar
Default Re: (muhaMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muhaMan &raquo;</TD></TR><TR><TD CLASS="quote">hmmm... mines been on so long that i thought it was normal for it to be on 24/7... what does SRS stand for??</TD></TR></TABLE>
SRS stands for Supplemental Restraint Sytem. Sometimes the SRS control unit can be tripped by a over or under load in your electrical system (even by jump starting the vehicle) use the DIY a couple posts up to reset your srs control unit first. If that doesn't fix the problem then you can spen the 65-100 dollars it will take to diag the problem at your local Honda dealer.
datkins2
02-24-2019 08:24 AM
danir
09-20-2018 03:24 PM
drummerman2008
Honda Civic (2001 - 2005)
11-17-2012 07:32 PM
musicmaster
07-15-2009 08:58 AM
Quick Reply: My SRS light is on (Honda Civic 1996 DX 2Dr) What could be wrong?
