Serpentine belt
Old 02-04-2007, 08:50 PM
soon2bdropped's Avatar
Default Serpertine belt
how to change it on a 95 honda accord.. i already searched nothing.. i don't have a manual on hand and need this changed pretty soon... help me please.. any DIY with pics any how tos.. thanks
Old 02-04-2007, 08:56 PM
sony224422's Avatar
Default Re: Serpertine belt (soon2bdropped)
its not an easy task if you've never done it. and its gunna be even harder if you don't have the tools or manual. plus i have 119k on mine. yeah yeah, i should get it done, but eh, i'll do it when i have the time.
Old 02-04-2007, 08:58 PM
Default Re: Serpertine belt (sony224422)
okay well anybody?
Old 02-04-2007, 09:11 PM
hondaccord's Avatar
just look at it, you got one v belt, and one serp. the vbelt goes around the crank, and the power steering pump. then the serp goes around the crank, the a/c compressor, and alternator. there are adjustment bolts on the power steering pump, and the alternator. loosen up those, and the mounting bolts, match up the replacement belts, then replace them. you are going to want to tighten up the adjusters till you can only push the belt in/out about 1/2" in about a 6" span.
Old 02-04-2007, 09:44 PM
sony224422's Avatar
Default Re: Serpertine belt (hondaccord)
ahh shiz sorry, i was thinking timing belt for some reason.
yeah actually it shouldn't be that hard. make sure to get the right length belt/belts. sorry again.
but if i were you, i'd get a manual and then have at it. i'd say it'd take you 3-4 hours if that.
Old 02-07-2007, 08:58 PM
bump
Old 02-08-2007, 07:42 PM
hondaccord's Avatar
dude if you NEED pics that bad, go spend the 20 bucks, and get a Haynes manual. It will be well worth it to walk you threw, and give you the DIY ofor a lot more projects then just that. Also 3-4 hours to change a whole of two belts? that would be pothetic, sorry, but 1/2 hour at most of actual work for a novice. as long as you know what a wrentch is, and how to use a bigger or smaller one. also rember, righty tighy, lefty loosey. good luck
GSR_96814
04-25-2006 08:53 PM
luderollin
02-25-2005 12:07 PM
RUBZERK
06-13-2004 03:46 PM
NSTY Z33
05-09-2004 06:46 AM
sidewayz
14
06-05-2002 11:48 AM
Quick Reply: Serpentine belt
