#1 | |||||||
Moderator
http://people.clemson.edu/~ABense |
#2 |
1998 Acura IntegraJoin Date: Apr 2003
M12 x 1.25 - rear inner seat rail bolt
インテグラ タイプR 98-0425 |
#3 |
I have no clue about any of the bolts, considering this is my first Honda, and I've only had it about 2 months. However this could come in real handy, sticky please?
#4 |
D-series head stud thread: M10x1.25
B-series head stud thread: M11x1.5
MR EJ7 / LS Vtec 190whp / 123wtq 13.4@101 Blundell Tuned |
#5 |
Moderator
#6 |
Moderator
rad
#7 |
i don't know if this thread is relevant to what you're trying to accomplish, but it's definitely some info that might help some people looking for
a few TURBO thread pitches http://www.honda-tech.com/zerothread?id=373905 |
#8 |
HT White Ops
Common:
M10x1.5 - Shifter (for all you poor saps that need a locknut for your Type-R knob)
Jason -- 97 VSM del Sol <2WAYPARADISE> Proclivity to Hatership [ Flickr. ][ anti|hero ][ dSoc ] |
#9 |
Moderator
up for more
#10 |
bense...your correct....oil pan 14X1.5
#11 |
anyone know the thread pitch of the bolts that hold down the cam caps on a b-series?
Poormans R- EJ8 EJ8 Squad #261 |
#12 |
Actually the most common 10mm bolt is 6mm thread pitch.
On a 92-95 anyway. I use that size chaser the most.
SOHC-T Fun Times Come join us at Crunk Times!! http://crunktimes.com/ct/index.php?referrerid=116 |
#13 | |
Moderator
I believe that most of our M8-1.25 bolts are what we use the 12mm sockets for. However most of the nuts/bolts that we buy in conventional hardware stores that are M8-1.25 use 13mm heads. I just need to verify that 1.25 is the common thread pitch.
#14 |
Moderator
keep em coming guys
#15 |
#16 |
Moderator
m8-1.25 is our common honda bolt with the 12mm head
#17 |
I cant remember them off the top of my head and dont have the time right now but when i get home from class ill look some up. Cause there are "custom" ones for special things (like LS/VTEC, oil spuirters, etc). Those use a NPT thread to cover or tap. But when i get home ill check it.
Also i believe the crank pully is the M16 x .5 pitch and the flywheels are 14 x .5 But dont quote me just yet ill be back for for sures if no one checked it.
93 B18C-<FONT COLOR="red">T</FONT> DX coupe <FONT SIZE="2"><FONT COLOR="red">Janer Performance</FONT></FONT> <FONT COLOR="blue">-Engine Building-</FONT> -Turbo Install- <FONT COLOR="green">-General Mechanic-</FONT> -We Sell BDL http://images.honda-tech.com/set1/smile/emthup.gif - PM for good deals. http://images.honda-tech.com/set1/smile/emthup.gif Vouch Custom Clutch Lines RIP Earl Laskey 12.1.06 You will be missed! http://images.honda-tech.com/set1/smile/emsad.gif |
#18 |
Moderator
thanks Luserkid
#19 |
Sorry i lagged but schools been killer. Heres some not so common thread pitches that hondas have and if you ever screw them up is hard to find, so it better to have the correct pitch numbers then send out a stripped bolt asking "can you figure out the thread pitch"
Flywheel bolts (B and D the same, dont know about H and K): M12 x 1.0 Pressure Plate bolts (same b and d dont know about h and k): M8 x 1.25 Oil pan/Trans drain plug: M14 x 1.5 Trans case bolts that hold that little ball bearing in place with spring: M12 x 1.0 (oddly enough this is a hard tap to find, and timesert hasnt even made an insert for it yet so dont screw this one up) Oil Pressure Sensor (back of block): 1/8 - 28BSP Bumper screw/bolts: M6 x 1.0 Crank Bolt: M14 x 1.25 14mm Allen Bolt: M28 x 1.5 10mm Allen Bolt: M20 x 1.0 19mm bolt that connects rear trans bracket to trans: M14 x 1.5 If theres any other bolts that people would like to know let me know and ill get you the pitch.
#20 |
Moderator
thanks for the post Luserkid
#21 |
m16 is for the thermoswitch, under the water pipe. i never tried a crank pulley bolt to see if it fits.
Engine Combo & EFI Tuning http://www.jdmsci.com/ | VOUCHES: ilsimsli, 91EFHatch, Bbasso, freezyfreeky, vha27, honduhh, xxxhonda20, jdmwhore, thelate1, ixislikixi, hybrid98, AMLS4dr200whp, toekneevwj, JDMFreak_DC2, HondaGuy02, jmm96gsr |
#22 |
sticky this
#23 |
Guest
Posts: n/a
Would anyone happen to know the specs on the hood hinge bolts? Im going to be machining up a few hood spacers, and would like to know this. Thanks!
#24 | |
M8-1.25 (common) (probably most of our 12mm head bolts) |
#25 |
exhaust header/ cat studs... i cant remember M12x 1.25?
eh2: |
| Bookmarks |
| Tags |
| 94, arp, bellhousing, bolt, civic, crank, find, head, honda, hood, pitch, pulley, size, studs, thread |
