> Honda Accord (1990 - 2002)
Old 02-04-2007, 11:05 AM   #1
standbackimapro
standbackimapro's Avatar
Send a message via AIM to standbackimapro
Default Ever wanted to know why your car whines in reverse?
Well Ive seen a few people ask WHY, there fwd cars whine when going in reverse, Some people Think its a transmission problem, so they bring it to my shop and i just tell them
On Transmissions The reverse gear has a Spur gear,which has straight teeth so when you put it into reverse and start going, the whining noise you hear is the teeth of the spur gear slapping together,
the reason you dont hear the noise in any other gear is because the other gears are called helical gears, which have like angle/beveled gears
SPUR
HELICAL
20 Years old From Brick, Nj
ASE: A1, A2, A3, A4,A6, A8, L1, X1
MECP BASIC
standbackimapro is offline Report Post   Reply With Quote
Old 02-04-2007, 11:18 AM   #2
sony224422
sony224422's Avatar
Default Re: Ever wanted to know why your car whines in reverse? (standbackimapro)
interesting. i've wondered that myself
96 accord lx- converted into 5spd ex http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
93 civic CX (project car)- Sold
1997 dodge ram 1500 sport 4x4 extended cab
360 magnum
sony224422 is offline Report Post   Reply With Quote
Old 02-04-2007, 12:46 PM   #3
K24xCM5
K24xCM5's Avatar
Send a message via AIM to K24xCM5
interesting indeed.
Honda Accord Ex Coupe 2003
K24xCM5 is offline Report Post   Reply With Quote
Old 02-04-2007, 12:48 PM   #4
02 accord
02 accord's Avatar
Send a message via AIM to 02 accord
Default Re: Ever wanted to know why your car whines in reverse? (K24A4 EX)
I knew that already. Howstuffworks.com is great for stuff like this.
2002 Accord SE 5 speed
Originally Posted by phootbag
You took the engine out to check a leak?
02 accord is offline Report Post   Reply With Quote
Old 02-04-2007, 04:59 PM   #5
The-Kid
The-Kid's Avatar
Send a message via AIM to The-Kid
Default Re: Ever wanted to know why your car whines in reverse? (02 accord)
cool. ADMIN= Add this to the Accord FAQ. =P looks good.
-96 Honda Accord EX Coupe(AEM CAI, Front Strut bar)
-01 Honda Accord LX Sedan(K&N OEM Air Filter, SHINY!)
-02 Acura RSX Base(K&N SRI, Tanabe Strut bar, Strup Headers)
The-Kid is offline Report Post   Reply With Quote
Old 02-04-2007, 05:07 PM   #6
gianinline
gianinline's Avatar
I actually like that sound!!
But yeah, it is interesting to see how little things.... can make different results of sound, performance and such.
CD squad #016
"it is dangerous to be right when the government is wrong" (Voltaire)
gianinline is offline Report Post   Reply With Quote
Old 02-04-2007, 05:35 PM   #7
Centripital
Centripital's Avatar
Yea, and add the reason why reverse grinds is because there isnt a syncro on it. That is why some people feel like they need to shift it into first or second before shifting it into reverse.
Centripital is offline Report Post   Reply With Quote
Old 02-04-2007, 07:23 PM   #8
HondaAccordTdR
HondaAccordTdR's Avatar
Default Re: Ever wanted to know why your car whines in reverse? (Burg)
You must read car and driver. Good info.
1983 CM450E
1991 GSXR 1100
1995 Accord EX
HondaAccordTdR is offline Report Post   Reply With Quote
Old 02-04-2007, 07:54 PM   #9
iam7head
iam7head's Avatar
Default Re: Ever wanted to know why your car whines in reverse? (HondaAccordTdR)
striaght cut gear=whine
Honda s2000 Ap1 00' Silverstone(153lb-ft of torqueless wonders)
Mazda Miata Mx-5 90' BMWjetblack(116hp of ball-less fury)
iam7head is offline Report Post   Reply With Quote
Old 02-04-2007, 09:11 PM   #10
htekken
htekken's Avatar
good info, didnt know.
htekken is offline Report Post   Reply With Quote
Old 02-04-2007, 09:20 PM   #11
02 accord
02 accord's Avatar
Default Re: (htekken)
Now you know.
Old 02-04-2007, 10:00 PM   #12
02 accord
02 accord's Avatar
Default Re: (Blamm!!)
Nope. Look at worm gears. A 60:1 reduction is easy, and they don't whine. It whines because it's a spur gear. The reduction has nothing to do with it. And reverse is not THAT much lower than first. I top out in first around 35 mph, while in reverse, I can probably do 30. Not that much of a difference.
Old 02-05-2007, 08:45 AM   #13
JimBlake
JimBlake's Avatar
Default Re: (02 accord)
They're all spur gears. All that means is the gears mesh when the shafts are parallel to each other. The other kinds are bevel gears (in the differential), and planetary gears (really spur gears except for the ring) which are found in old-school auto trannys.
Spur gears can be straight cut or helical. Helical gears is what you're trying to describe, the teeth are 'twisted' instead of going straight across the gear. Helical gears don't whine so much since there's always some point on the gear face that's engaged with the other gear. (I know that's a sorta simplified description, so some other engineer can maybe think of a better way to describe it.)
Then there's hypoid gears which are even more sophisticated in the details of the tooth shape. They are directional, so they make more noise when going backwards. You don't have hypoid gears, they're in some RWD final-drive gearsets because of the offset shaft centerlines.
edit...
Hmmm, I just read that in howstuffworks, but I don't think they're using using the term correctly. Look at their wording under bevel gears. They talk about straight bevel gears vs. helical bevel gears. Same thing for straight spur gears vs. helical spur gears.
Modified by JimBlake at 3:07 PM 2/5/2007
JimBlake
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline Report Post   Reply With Quote
Old 02-05-2007, 08:59 AM   #14
Stealthman80
Stealthman80's Avatar
Default Re: (JimBlake)
I call my car the ECHTO MOBILE, its funny as hell it sounds like a crank siren
1993 Accord SE
Stealthman80 is offline Report Post   Reply With Quote
Old 02-05-2007, 09:19 AM   #15
kulrevon
2003 Acura CL
kulrevon's Avatar
Send a message via AIM to kulrevon
Originally Posted by Blamm!!
you guys have no idea!! reverse whines because it is as much LOWER gear than than first! and is a different style gear. But mainly because it is lower gear!
holy smokes!!
You are absolutely wrong. And I hate people who are so confident with their wrong information. If you want to prove a point. Do some research. It whines because of the straight cut gears. not because of the low gearing.
Originally Posted by Howstuffworks.com
Spur gears are used in many devices that you can see all over HowStuffWorks. But you won't find many in your car.
This is because the spur gear can be really loud. Each time a gear tooth engages a tooth on the other gear, the teeth collide, and this impact makes a noise. It also increases the stress on the gear teeth.
To reduce the noise and stress in the gears, most of the gears in your car are helical .
The new whip 3.2 cls 6spd lsd. stock 14.42@96.76mph compltely stock.
Looking for 5th gen prelude body parts grey/silver (B83M). Let me know what you have.
http://honda-tech.com/showpost.php?p...0&postcount=28
kulrevon is offline Report Post   Reply With Quote
Old 12-25-2007, 09:37 AM   #16
g0at357
g0at357's Avatar
Send a message via AIM to g0at357
Something good to know.......appreciate the info...
g0aT3.5.7
g0at357 is offline Report Post   Reply With Quote
Old 12-25-2007, 03:35 PM   #17
sir4doorking
sir4doorking's Avatar
cool thanx for the input. but I like that noise men.
sir4doorking is offline Report Post   Reply With Quote
Old 12-25-2007, 04:13 PM   #18
YeuEmMaiMai
i got a chuckle for christmas!
YeuEmMaiMai's Avatar
that's funny becasue the only cars that I have had that make that whine in reverse are I4 hondas
my V6 accord didn't do it
my CL type S does not do it
None of my american FWD cars did it
Sable
Cutlass
HT common sense krew member #2...The plane WILL FLY club member #3...Jesus is Salvation...Whatever you can think of that is utterly nasty, I can find something that is way worse....and that is true on the Internet
YeuEmMaiMai is offline Report Post   Reply With Quote
Old 12-26-2007, 09:27 AM   #19
hurleyint
hurleyint's Avatar
Default Re: (YeuEmMaiMai)
Congrats on having quiet cars, but to say only I4 honda's whine in reverse is a bit much. I know for a fact I have heard toyota's, VW's, and nissans all make the same whining noise.
I read about this a few years ago, you guys are way behind.
ddphoto-canon
hurleyint is offline Report Post   Reply With Quote
Old 12-26-2007, 10:24 AM   #20
GhostAccord
GhostAccord's Avatar
All of my "Manual" transmission cars have had the reverse wine to them. GM, Ford, Honda & Mazda. My 1 automatic did not make any different noise. Could that be the difference maybe????
Yeah this post was brought back to life from the FAQ's. It was a February thread.
CD5 "Ghost" F22B2 ITB Blog
My H-T Build Thread
Cheers!
GhostAccord is offline Report Post   Reply With Quote
Old 03-20-2008, 08:07 AM   #21
jamie2002
jamie2002's Avatar
Does anyone know how to get rid of the whine sound? Does this mean i need to get a new transmission or something? That sounds expensive
jamie2002 is offline Report Post   Reply With Quote
Old 03-20-2008, 08:51 AM   #22
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: Ever wanted to know why your car whines in reverse? (jamie2002)
no, thats just how it is, nothing is wrong.
TouringAccord is offline Report Post   Reply With Quote
Old 03-20-2008, 09:24 AM   #23
jamie2002
jamie2002's Avatar
Default Re: Ever wanted to know why your car whines in reverse? (TouringAccord)
Ok awesome! Thanks I hope it's not that loud on the outside! I like to try and not draw attention towards myself!
Old 03-20-2008, 11:23 AM   #24
not-a-stang
not-a-stang's Avatar
holy smokes!!
haha! keep trying buddy. its the straight cut on the reverse gear.
Have you guys ever heard of the Muncie "rock-crusher" M22 4 speed manual? Its an old school 4-speed that came on Chevelles, camaros, etc.. that had the first three forward gears cut straight instead of the usual helical cut, man those babies whine! Sounds like a supercharger!
'95 Accord EX : s-l-o-w
not-a-stang is offline Report Post   Reply With Quote
Old 09-10-2008, 04:31 PM   #25
Tiff_Tiff420
Tiff_Tiff420's Avatar
Send a message via AIM to Tiff_Tiff420
ohhh
Tiff_Tiff420 is offline Report Post   Reply With Quote
Bookmarks
2000, accord, acura, car, honda, loud, noise, put, reverse, sound, tl, transmission, whine, whines, whining
