Old 02-03-2007, 08:26 PM   #1
LABachlr
LABachlr's Avatar
Default How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH?
I want to replace the fuel filter on my Accord EX 2.2 VTECH. Anyone have a link to a tutorial with pictures, or anyone want to post one here?
TIA
LABachlr is offline   Reply With Quote
Old 02-04-2007, 08:26 AM   #2
hondadude
hondadude's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (LABachlr)
here ya go;
http://members.troublecodes.ne...r.htm
Year and model Helps get better info
My crystal ball is out of service,and
I failed Clairvoyance 101 class
hondadude is offline   Reply With Quote
Old 02-04-2007, 08:45 AM   #3
iam7head
iam7head's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (hondadude)
dont try it unless you are good with car, i spent like three hours getting the bit-h bolt off the top with a vise and a wrench Click the image to open in full size.
Honda s2000 Ap1 00' Silverstone(153lb-ft of torqueless wonders)
Mazda Miata Mx-5 90' BMWjetblack(116hp of ball-less fury)
iam7head is offline   Reply With Quote
Old 02-04-2007, 08:56 AM   #4
hapexamendios 2.0
R.I.P.
2002 Lamborghini Gallardo
hapexamendios 2.0's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (iam7head)
ditto, pain in the ***, be careful not to bend the fuel lines Click the image to open in full size.
“Life is like a movie, if you've sat through more than half of it and it’s sucked every second so far... No one should blame you for walking out early.”
hapexamendios 2.0 is offline   Reply With Quote
Old 02-04-2007, 09:20 AM   #5
iam7head
iam7head's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (hapexamendios 1)
fat hands for the lose Click the image to open in full size.
yeah, don't drop the washer thing too, if you forget the put in the brass washer or forgot to take out the worn washer it will spray you with gasoline upon fire up Click the image to open in full size.
Old 02-04-2007, 11:39 AM   #6
LABachlr
LABachlr's Avatar
Thanks for the link and advice. I think I'll pass on this one and have the mechanic do it. BTW, at what mileage should it be replaced? Have about 84,000 on it right now.
Old 02-04-2007, 06:37 PM   #7
hondadude
hondadude's Avatar
It is not in the service schedule anymore; But by 90k it should have some junk in it. The official change time, is when you lose fuel pressure from blockage.
Old 02-04-2007, 06:44 PM   #8
iam7head
iam7head's Avatar
we changed our around 140k and there's not much "stuff" in it, the same can't be said for my acura legend filter, it was caked with yellow dust
Old 02-04-2007, 06:54 PM   #9
hondadude
hondadude's Avatar
Well almost all gas pumps have filter systems nowadays, So there is a lot less chance of getting junk in the gas tank.
Old 02-04-2007, 07:03 PM   #10
SuShiBoiiii
SuShiBoiiii's Avatar
Send a message via AIM to SuShiBoiiii
when do you know its time to change or should i just change when i get to like 150k?
ALL*STAR*DETAIL
SuShiBoiiii is offline   Reply With Quote
Old 02-04-2007, 10:50 PM   #11
jli18
jli18's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (SuShiBoiiii)
whats the use of changing the fuel filter? i never changed mine, and my car has 140k miles on it right now
oem > jdm
96 accord ex sedan 5spd (RIP)
jli18 is offline   Reply With Quote
Old 02-04-2007, 11:00 PM   #12
iam7head
iam7head's Avatar
around 100k, but your 6th gen doesn't have a real filter.
Old 02-04-2007, 11:03 PM   #13
iam7head
iam7head's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (jli18)
filter: a device(fuel filter) that remove something(junk from the pump gas) from whatever pass thru it
pretty much the same idea for oil filter, air filter, a/c filter, light filter, atf filter, etc
change it if you haven't already, the legend/civic/teg filter is right by the firewall, which took less than 10 seond to remove Click the image to open in full size.
the accord 5th gen filter is between the steeringrack/crossmember and the loop of brake hoses, a royal paining **** to work on. the same go for DSM eslipse, it's mounted by the firewall under abunch of crap. Gas just leaks to your arm pit when you work on it Click the image to open in full size.
Old 02-06-2007, 06:41 AM   #14
LABachlr
LABachlr's Avatar
The reason why I want to change the filter is to improve the gas mileage. I'm getting around 17mpg around town, and should be getting around 23 according to my car's stats.
I've already done the following:
replaced and gapped the spark plugs
poured fuel system cleaner into the gas tank
replaced the air filter
replaced the spark plug wires
replaced two tires (other two are almost new) and gave them all 36psi
I still plan on replacing the distributor cap and rotor, and of course the fuel filter.
Is there anything else I can do to improve the gas mileage?
Modified by LABachlr at 7:56 AM 2/6/2007
Old 02-06-2007, 06:51 AM   #15
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Maybe try cleaning your EGR ports.
Check the FAQ for a How-To on cleaning the EGR ports, it's located in the Engine section.
TouringAccord is offline   Reply With Quote
Old 02-06-2007, 06:58 AM   #16
LABachlr
LABachlr's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (TouringAccord)
OK. Thanks. The FAQ section of what? Don't see any FAQ section on this site.
Old 02-06-2007, 07:07 AM   #17
TouringAccord
H-T Order of Merit
are you joking?
It's stickied at the top of the Accord forum. Called Accord FAQ
Old 02-06-2007, 08:05 AM   #18
LABachlr
LABachlr's Avatar
Ah. A sticky. I was looking for a complete FAQ forum. My bad. Thanks.
Modified by LABachlr at 9:33 AM 2/6/2007
Old 02-06-2007, 08:21 AM   #19
TouringAccord
H-T Order of Merit
yep, no problem.
Remember to look in there and search when your looking for something, chances are you'll find it between the two. If you find a good how-to or a good thread that you feel should belong in there, send a PM to a mod (myself or -RedneckDave-) and we can read it and add it if needed.
Old 02-06-2007, 08:33 AM   #20
LABachlr
LABachlr's Avatar
Cool. Will do.
Old 02-06-2007, 09:15 AM   #21
fleetmack
fleetmack's Avatar
what can one expect to pay a mechanic to replace a fuel filter?
I still get decent gas mileage and am on my original at 216K .... thinking I'm overdue, but this sounds like a pain in the *** that i'll gladly pay someone to do Click the image to open in full size.
"You're rather attractive for a beautiful girl with a great body."
--Ty Webb, on Caddyshack
fleetmack is offline   Reply With Quote
Old 02-06-2007, 10:10 AM   #22
TouringAccord
H-T Order of Merit
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (fleetmack)
It's not as hard as it seems with the proper tools. Crowfeet make the job much easier.
Old 02-06-2007, 11:41 AM   #23
fleetmack
fleetmack's Avatar
i'm very ignorant, what are crowfeet?
Old 02-06-2007, 03:41 PM   #24
TouringAccord
H-T Order of Merit
You can see them in the link at the beginning and how to use them in this situation.
Old 02-06-2007, 04:51 PM   #25
iam7head
iam7head's Avatar
overrated Click the image to open in full size.
i was doing it with 99cents vise grip in one hand and wrench in the other, make sure you tape the tools and use a rubber band to wrap around your hand, you will drop it couple of time on the removal Click the image to open in full size.
1995, 22, 95, accord, bolt, change, ex, filter, fuel, fule, honda, location, pump, replace, replacing
