Need Help! Can loose intake manifold cause car not to start?
Hello everyone! I Need Help! Can a loose intake manifold cause my car not to start? Im waiting for the rest of my bolts from honda to arrive but in the mean time i have tried to start my car in the mean time but it doesn't start. I have fuel and Spark. Any suggestions? Thanks!!
Re: Need Help! Can loose intake manifold cause car not to start? (mafia)
Yep it cranks. Could there be a lose of air flow that causes the engine to not start?
Re: Need Help! Can loose intake manifold cause car not to start? (CSHornet60)
I dono, i had something like that on a 94 integra, and idle was at 4k Rpms.. (it had all nuts on, but some were loose.) But it started. Any gas leak from I/M?
Got any ground wires going to the IM bolts? Normally you shouldn't.
Got any other loose bolts like on your thermostat housing where your engine harness ground is located?
Re: Need Help! Can loose intake manifold cause car not to start? (sql_civic)
a loose intake manifold should not cause you not to start, your idle is going to be off and may even jump up and down.
like sql_civic said, check to make sure that your grounds are connected. check to see if you have spark and fuel (turn the motor over w/o the spark plugs in to see if you see a mist of fuel coming out from the spark plug holes). then start looking for blown fuses.
Re: Need Help! Can loose intake manifold cause car not to start? (medside)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by medside »</TD></TR><TR><TD CLASS="quote">a loose intake manifold should not cause you not to start, your idle is going to be off and may even jump up and down. </TD></TR></TABLE>
Ya it will sound like your IACV.
Bulldogg83
10-19-2003 05:49 PM
Bulldogg83
10-18-2003 12:18 PM
