Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2006 - Current)
Old 01-30-2007, 08:06 AM   #1
06 Habanero-NaVi
06 Habanero-NaVi's Avatar
Default Advantage/Disadvantage of vented disc brakes??
I don't know much about them...I guess I would do it more so for the look of them...but of course I know that Honda's brakes are gonna be the best...but how much of a difference would I notice in like stopping power...or braking distance?? Recommend or NOT Recommend??
06 Habanero SI w/Navi
18" Black wheels
12k HID's
DC Sports Exhaust
Tein Springs 1.3' 1.4'
AEM Cold Air Intake
OEM Foglights
Then That's It!!! I'm Broke!!
[url="http://www.myspace.com/BigSexynessRyan"]http://www.myspace.com/BigSexynessRyan[/url]
06 Habanero-NaVi is offline   Reply With Quote
Old 01-30-2007, 08:10 AM   #2
cnyej1
cnyej1's Avatar
Default Re: Advantage/Disadvantage of vented disc brakes?? (06 Habanero-NaVi)
You mean cross drilled or slotted? If so the brakes are able to get rid of heat more quickly, thus reducing the feeling of brake fade under heavy braking conditions.
ironchef25 - I thought god was always looking at you, so fapping was a big no no.. now i fap mostly every day and aim for his eyes
09 Legacy..... NA lol 1993 Mazda NA6C
cnyej1 is offline   Reply With Quote
Old 01-30-2007, 08:55 AM   #3
IT GUY
IT GUY's Avatar
Get slotted, especially on a street car. Drilled is usually cheaper, but can mess with the structural integrity of the rotor (since it basically is full of holes)
Also, in addition to getting rid of heat; the holes or slots allow for expanding gases released by the pad material to escape. Getting rid of the gases lets the pad make complete contact with the rotor without a "pillow" of air (so to speak) between them.
Upgrade is worth it, especially with quality pads (not autozone) and SS brake lines. Click the image to open in full size.
I like all of my pedals to be more responsive, not just the throttle Click the image to open in full size.
Modified by IT GUY at 1:08 PM 1/30/2007
IT GUY is offline   Reply With Quote
Old 01-30-2007, 09:42 AM   #4
SYTFU Tommy.
SYTFU Tommy.'s Avatar
Default Re: Advantage/Disadvantage of vented disc brakes?? (IT GUY)
i feel that there is no point in it. just asking for a cracked rotor FTL Click the image to open in full size. . blanks are the way to go on the street
SYTFU Tommy. is offline   Reply With Quote
Old 01-30-2007, 09:49 AM   #5
tone*def
tone*def's Avatar
Default Re: Advantage/Disadvantage of vented disc brakes?? (SYTFU Tommy.)
I say if you go road racing alot or track(curcuits) it's worth getting em.~!!! Click the image to open in full size.
tone*def is offline   Reply With Quote
Old 01-30-2007, 10:06 AM   #6
bps2799
bps2799's Avatar
Honda's brakes aren't the best, but it is very easy to buy something worse. Brembo is always a good choice, as are Centric. If you must go slotted, just do the front rotors; the rears are already kinda thin and the need to "scrub" the pads with slots is minimal. There will be no noticeable performance benefit 90% of the time, but they may help in wet weather or if you've started to glaze the pads.
bps2799 is offline   Reply With Quote
Old 01-30-2007, 12:10 PM   #7
Nohawk
Nohawk's Avatar
I like all of my pedals to be more responsive, not just the throttle Modified by IT GUY at 1:08 PM 1/30/2007
Also, slotted rotors help keep dirt and grime off your pads. This helps your pads last longer and and give you better performance.
93 Civic EX Coupe - EJ1
[b]06 Si HRP - <FONT COLOR="red">Retired</FONT>
<FONT COLOR="blue">FG Squad #3
</FONT>
Nohawk is offline   Reply With Quote
Old 01-30-2007, 12:34 PM   #8
bps2799
bps2799's Avatar
Default Re: Advantage/Disadvantage of vented disc brakes?? (Si 4 Life)
It doesn't help the pads last longer, but rather it wears them sooner as it scrubs the surface of the pad. It MAY help performance if you've glazed the surface or it is wet.
Old 01-30-2007, 04:05 PM   #9
HondaF1Fanatic
HondaF1Fanatic's Avatar
Blanks are the best except on the most extreme big brake and racing kits because they retain the most thermal mass to dissipate heat. If you want to improve cooling get rotors with directional vanes. Finally, if your pads are getting so hot that they are gassing you need to choose new pads or quit driving like a hooligan on the stock ones. Your fluid will also generally boil before your pads gas, especially if you are using the stock fluid.
Jon
Current Vehicles:
2005 Honda Accord EX-L 4-Cyl 5at (78,000+ miles)
2003 Honda Civic Si (72,000+miles)
HondaF1Fanatic is offline   Reply With Quote
04, accord, advantage, advantages, brake, brakes, cross, disadvantage, disadvantages, disc, discs, disk, drilled, induction, rotors, slotted, vented
