Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 01-28-2007, 06:52 AM   #1
cbmprelude
* B A N N E D *
Default What is the difference between carb cleaner and brake cleaner?
What is the difference between carb cleaner and brake cleaner? Is there any?
cbmprelude is offline   Reply With Quote
Old 01-28-2007, 07:00 AM   #2
Shakes
space cadet
Shakes's Avatar
Default Re: What is the difference between carb cleaner and brake cleaner? (cbmprelude)
one is stronger then the other.
-Doug
SMOKE FREE SINCE 10-31-04
01 Subaru Impreza RSTi
Shakes is offline   Reply With Quote
Old 01-28-2007, 07:10 AM   #3
cbmprelude
* B A N N E D *
Default Re: What is the difference between carb cleaner and brake cleaner? (Shakes)
can carb cleaner be used to get grease off new brake rotors?
Old 01-28-2007, 07:19 AM   #4
Shakes
space cadet
Shakes's Avatar
Yeah. Not sure if its bad for the brakes though but I doubt it.
I think the order of strength goes
Starter fluid
Carb Cleaner
Brake cleaner
-Doug
Old 01-28-2007, 07:39 AM   #5
ImprtTunr
Send a message via AIM to ImprtTunr
Brake cleaner is better because it does not leave any residue behind/ any type of film. On something as important as the brakes I would go spend a couple bucks and get a can of brake cleaner.
06 CRF450
ImprtTunr is offline   Reply With Quote
Old 01-28-2007, 07:41 AM   #6
2point2
2point2's Avatar
that's a really good question!
Do you have any engine parts laying around? Spray some brake cleaner on some carbon build-up and see what happens.
Turbocharged CRX w/Stock H22
10.73 @ 137mph
Pics and Info
2point2 is offline   Reply With Quote
Old 01-28-2007, 08:08 AM   #7
Stew Pidasso
2009 Honda Accord
Stew Pidasso's Avatar
Send a message via AIM to Stew Pidasso
Default Re: (2point2)
Carb cleaner sometimes leaves a residual lubricant (oily film) to lube moving parts of a carb (see label) . Also, never use carb cleaner in a throttle body..only use throttle body cleaner and if it's a Ford, make sure the throttle body cleaner is compatible with the lining.
2009 Accord EXL V6 Sedan-Traded in on
2010 Accord EXL V6 Sedan with Navi
2014 Accord Touring Sedan
Stew Pidasso is offline   Reply With Quote
Old 01-28-2007, 08:58 AM   #8
shinobijesus
shinobijesus's Avatar
Default Re: (Stew Pidasso)
the best thing to do is mix them together whenever you buy either into one huge spray bottle. then you have twice as much cleaner and its 1.5x stronger. Click the image to open in full size.
Originally Posted by MF Doom
its the LAPD they dont care how many people they kill
Otaku Squad Member #007
shinobijesus is offline   Reply With Quote
accord, body, brake, carb, carburetor, civic, cleaner, differance, difference, fluid, honda, lubricate, mix, starter, throttle
