How To: JDM ITR SRS Steering Wheel Install
Old 07-17-2008, 01:44 PM
  #76
rocketkev's Avatar
Default Re: How To: JDM ITR SRS Steering Wheel Install (team_hirev)
Beacause you get rid of theese 2 small black clips to install the jdm steering wheel, can you still go back to the stock one and intall it properly? Thanks!
Modified by rocketkev at 3:56 PM 7/17/2008
Old 06-21-2009, 12:59 PM
  #77
JL_DC2's Avatar
I know this thread is old. I just installed my jdm itr steering wheel on my teg, the srs light stays on? Did I plug it in wrong? & damaged it??? What should I redo to correct this? And did anyone relocate the cruise control?? If so please help with pics would even better. Thanks
Old 06-22-2009, 04:30 AM
  #78
JL_DC2's Avatar
bump for help anyone?
Old 02-20-2011, 09:45 PM
  #79
01ITR1319's Avatar
I'm a bit late to the party, but I just used this today and it was very helpful. Thank you to the OP!
Old 03-29-2011, 08:29 AM
  #80
natman316's Avatar
guys the airbag on my JDM steering wheel seems to slide out without having to remove any bolts. Is there something wrong? the air bag holder is still on the steering wheel obviously because it is bolted down but the airbag itself isnt attached to that.
could I get just any bolt to bolt it down?
thanks
Old 03-29-2011, 02:11 PM
  #81
Stopsign32v's Avatar
Where do you get the ITR SRS steering wheel? I think it looks a lot better than the non SRS one.
Old 03-29-2011, 08:41 PM
  #82
natman316's Avatar
I bought it when I was in Thailand hahaha but I'm sure if you look around here you can find one
Old 03-29-2011, 08:45 PM
  #83
natman316's Avatar
Oh hey I have another question guys. This one obviously didnt come with the airbag inflator, I was wondering if I could take the USDM one and attach it to mine? Doesnt look like it will fit but I'm not sure.
Old 03-30-2011, 10:57 AM
  #84
LIs300's Avatar
wow nice walk through very helpful
http://www.facebook.com/event.php?eid=209062192442927
Old 03-30-2011, 10:32 PM
  #85
natman316's Avatar
anyone?
Old 04-06-2011, 09:13 PM
  #86
jdmdomo's Avatar
yeap ,post some more info.
please .
also .
i wana try to put my dc5 steering wheel on my 94 dc2..
if somebody as some ideas let me know..
thanks
h.t.
Old 10-23-2011, 07:29 PM
  #87
d16y8tuner's Avatar
Great thread. Really helpfull during the install proccess. Thanks!
Old 04-02-2012, 10:30 AM
  #88
dcarey's Avatar
I just reolaced the steering wheel on my 96 Honda Accord EX. I didn't have much problems. The only difference was the fact the the bolt on the steering wheel you had on this post was a 19mm, mine was a 10mm. I got a used one in good condition on Ebay for $40. The new steering wheel was discontinued for my car, but the used one looks great!
Old 09-07-2012, 09:58 PM
  #89
yeedub's Avatar
Can someone explain part 11 in more detail? The part about clipping something..
Thanks!
Old 07-08-2013, 11:25 PM
  #90
kevvvinooo's Avatar
I know this is a old thread but does anyone know if the cruise control delete cover on a usmd itr steering wheel just pops off also? I've been trying to pull it off but i dont think it pops off. I don't want to break it
Old 10-19-2013, 04:56 PM
  #91
stallion15's Avatar
The two t-30 airbag bolts are super easy to take out if you put a t-30 bit on the end of a ratchet and use a 3" socket extension. Super easy, just push it in as hard as you can so you get a good bite in the bolt then proceed to turn the ratchet. This extends the lever arm thus providing the needed torque and pushing it in hard prevents stripping the bolt. Wish I had figured it out on my first teg. This is far superior to using a long t-30 screwdriver. That doesn't extend the lever arm at all.
Old 02-26-2014, 07:31 AM
  #92
361 accord's Avatar
i am doing this right now, but upgrading from plain wheel to usdm leather wrapped so thanks for the write up
the torx screws would not budge with my screwdriver so i put the bit in my 1/2" electric impact with some adapters and they came right off :D
Old 07-30-2015, 01:34 PM
  #93
SegaCD's Avatar
I know this is an old thread, but I made this account just to post some rather important information regarding this wheel (which answers a couple of the questions people had above). Nobody seems to have this info so I hope this will help someone.
These wheels are hard to find with the inflators (for obvious reasons). When I imported mine from Japan, it was missing the inflator. I unfortunately found out that the USDM steering wheel's inflator is too large to fit...which led to me getting roped into buying a $150 airbag (which had the inflator) on eBay which was an unnecessary expense...but I want my SRS functionality, you know?
Well, when I received the airbag, I saw the inflator has the following model number on it: BAM-PT-0593. Wouldn't you know it, 98-00 Honda CRV airbags use these exact inflators (along with a few other non-Honda car models, I believe). The CRV airbags typically sell for $60 or less...and could easily be sourced from junkyards. Remove four nuts, pop the inflator to the JDM SRS wheel and bam, you'll have your SRS functionality back.
Hope this helps!
Old 04-23-2016, 08:53 PM
  #94
dave7's Avatar
Thanks!
I'm about to install this steering wheel, and that is the only part I don't understand in the instructions.
garaged_Si
08-05-2006 10:21 AM
Jdmdc4ls
04-24-2006 12:15 PM
dt4life
04-08-2006 02:42 AM
civicb16
12
11-10-2004 04:23 PM
mack
11-15-2001 07:12 PM
Quick Reply: How To: JDM ITR SRS Steering Wheel Install
