How To: JDM ITR SRS Steering Wheel Install
#27
Re: (Swiftstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swiftstar »</TD></TR><TR><TD CLASS="quote">just posting on this tread so i can find it later. im thinking of getting the non airbag JDM wheel.
oh and....nice Write up </TD></TR></TABLE>
Nice that is what i use to have. Now I rock my $40 Si-VTEC wheel
Oh yeah my NON-SRS ITR wheel is for sale
#28
Re: How To: JDM ITR SRS Steering Wheel Install (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">very nice write up.</TD></TR></TABLE>
#35
Re: (BLacK FirE)
in step 11... "2 black clips inside the brass need to be clipped" what happens if you don't?
also, it seems my steering wheel needs to be turned to 11 o'clock in order to go straight, where did i mess up?
#36
Re: (DopeSilver_97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DopeSilver_97 »</TD></TR><TR><TD CLASS="quote">in step 11... "2 black clips inside the brass need to be clipped" what happens if you don't?
also, it seems my steering wheel needs to be turned to 11 o'clock in order to go straight, where did i mess up?</TD></TR></TABLE>
you didnt put your steering wheel on straight. take it off and put it back on.
#37
Re: (DopeSilver_97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 »</TD></TR><TR><TD CLASS="quote">
you didnt put your steering wheel on straight. take it off and put it back on.</TD></TR></TABLE>
Yep the brass portion moved on you, or you didnt have the wheels/steering wheel straight when you began. If you don't clip the black clips, then the openings on the brass part won't be at 9 and 3 and you risk snapping the cable reel.
#38
Uhmm... This really came in handle until i got the steering wheel off. I have a 95 integra. and im installing an aftermartket steering wheel. Afte ri took off the steering wheel theres like a stock hub? and i need to put my new hub on but i cant seem to do that any help?? asap?? my car is jsut sitting in the drive way and it needs to be move and i dont wanan move it until i jhave the new steering wheel on
#40
Re: (classy)
you mean this hub?
remove the upper and lower covers and there are three black screws you need to remove in order to remove that srs hub. then follow that harness and remove it. now you can remove it completely and unbolt the 19mm bolt and voila you can install your aftermarket hub
#42
Re: (94allmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94allmotor »</TD></TR><TR><TD CLASS="quote">nice write up comes in handy</TD></TR></TABLE> Nice
#43
Re: (gsR_Ace20)
I still have my Non-srs JDM wheel for sell...
https://honda-tech.com/zerothread?id=1779768
Modified by Nataku at 11:56 PM 2/6/2007
