| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
I would like a LS motor in my dunebuggy(because I had an Integra before). I would like to pick your guys' brain on exactly what I would need and if this is the best engine for my application. I would like at least 130-140 hp minimum the less wiring I need to make it run, the better. I want a stock engine, minus intake and exhaust which will be very basic (only muffler and about a foot of pipe). The lighter and smaller the engine the better (it replaces a vw aircooled engine and weight is a factor for off-road). Availibility to inexpensive parts would be a plus because of it intended use (lots of high rpms). Is a 1.8LS motor the way to go, or is there something else out there that would do better? I know I will need a computer, radiator, and a bigger fuel pump. What sensors do I have to leave in, and can I use just a high pressure fuel pump or do I need a return line also.
#2 |
This is a little extreme, but here is my 2.2l b-series w/b16a head. Let me know how much your looking to spend and I can give you some help/hints/tips on what to look for. I have some spare blocks too that may be of interest to you.
Kyle http://www.honda-tech.com/zerothread?id=1006776
aedynamix.com |
#3 |
You'l need a return line, thats how these fuel systems are designed, unless you re-do ofcourse.
#4 |
get an adapter plate and use the vw bus trans, i'm building a turbo b20 vtec sandrail right now for a customer.
89 crx HF H22A deck plate motor with stock H22 trans Stock head (except valvetrain (ret & springs) "Steve" Custom Header BBK dual 52mm throttle bodies custom manifold adapter. Skunk 2 cams Titanium retainers valve springs 272 WHP 218 Torque |
#5 |
Getting the hardware and drivetrain isn't really my question. I know about the adapters, My engine is 160hp now and the trans is made for this motor and will hold all the motor I want. I just don't want a carb or vw maintenance and honda motors kick *** and are lightwieght. My question is about wiring and what it will take to run. What components do I need. Is there a year or engine that is easier/better for my application.
Thanks for the replies so far. |
#6 |
you can run a standalone like DFI, thats what my customer has. just runs the necessary items. he's going with the b20 instead of the LS block for more displacement and they run really strong with a b16 vtec head , and turbo. nice setup.
#7 |
yep u need a radiator, ebay has the 92-95 civic aluminum radiators CHEAP... that will be more than enough and also is small so you can mount it easily, and an electric slimfan will work great. just wire the fan to a switch, not too complicated.
#8 |
Just curious , where can I find info on adapter plates ?
#9 | |
#10 | |
#11 |
1994 Honda Civic |
![]() Heres an early pic of a d16z6 buggy that a buddy and I are building. Its all Honda parts and metal stock, with some piping. The front end is just a VW front rail end and we've rigged up a rack and pinion steering setup for it...it'll be nice. Basically, we've tried to make the smallest possible budget. After the rear suspension is fabricated, and the motor is mounted right, the rest can basically be purchased and "bolted on" from any buggy place (bugsandbuggies.com for instance). Haven't worked up fuel or brakes, but thats all that it lacks. |
#12 |
OMFGWTF your gonna end up killin ur self HAAH
Fit is Go-GD Squad # 121 Love my BBP Fit, but wants a PY Type RRRR! "[i]Married[/i]", to Jdmhead - 06/21/08 [img]http://images.honda-tech.com/set1/smile/emsmile.gif[/img] [img]http://images.honda-tech.com/set1/smile/emcocktl.gif[/img] |
| Tags |
| 9295, adapter, buggy, civic, complete, crx, dune, engine, harness, honda, install, ls, motor, rail, sandrail, turbo |
