Old 01-18-2007, 01:58 PM   #1
t . b o z
t . b o z's Avatar
Default *WRITEUP* 90-93 Integra cruise control fix
For those who have cruise on their 90-93 integras, Ive figured out a way to remedy a very common problem.
Since I bought my car, my cruise hasn't worked. It worked for the previous owner, but when I got it, it didnt.
The cruise button light came on, however the light on the cluster never appeared, nor did any of the steering wheel buttons work.
My horn button, and my brake lights worked when I hit the brake, so it wasn't a fuse problem. (they are all on the same fuse).
So I narrowed it down to a clutch switch problem. DOH! I should've known that these cars have a problem with that. There is a rubber insert that goes on the clutch pedal assembly that strikes the switch. Over time, it dries up, and it eventually just brakes off. Very typical of a 16 year old car.
All I did, was simply take a short 10mm bolt, wrapped it in teflon tape to make sure it fits SNUGGLY in the hole. Then you take the corresponding nut and thread it on the other side. If you dont have a bolt short enough to keep the clutch pedal from being stuck too far down, just pile on some washers on the side closest to the firewall.
With that said, the bolt now strikes the switch, and cruise works perfectly!
Make sure you wrap it with some sort of tape to make sure it fits firm, or if you're lucky, youll have a bolt that fits the hole perfect.
'00 BR Pontiac Trans Am Ws6
Just some bolt-ons...its slow
t . b o z is offline   Reply With Quote
Old 01-20-2007, 03:40 PM   #2
SYNSEI
SYNSEI's Avatar
Default Re: *WRITEUP* 90-93 Integra cruise control fix (t . b o z)
Cool. Mine doesnt work but I never cared enough about it to fix it. I'll look this thread up again when need something to fix. Click the image to open in full size.
LSVTEC build
SYNSEI is offline   Reply With Quote
Old 01-20-2007, 05:02 PM   #3
BacardiBreezer
I think I have had this problem with both of my DAs. Is this like the brake pedal crayon-looking thing that tends to break off? I fixed mine with a penny...lol. I'll have to go do this. I don't ever use cruise, but it would be nice to know it actually works.
BacardiBreezer is offline   Reply With Quote
Old 01-20-2007, 05:33 PM   #4
DraginTeg93
DraginTeg93's Avatar
Send a message via ICQ to DraginTeg93 Send a message via AIM to DraginTeg93
pictures ???
DraginTeg93 is offline   Reply With Quote
Old 01-24-2007, 04:40 PM   #5
t . b o z
t . b o z's Avatar
Default Re: *WRITEUP* 90-93 Integra cruise control fix (BacardiBreezer)
yup, its the same thing, but its on the clutch.
Originally Posted by DraginTeg93
pictures ???
As for pictures..its not really hard to figure out.
Stick your head underneath the drive side dash, look where the bracket on the clutch pedal strikes the clutch switch. Notice how there is nothing there to hit the swtich.
As for the rest...you can fix it my way, or figure out something either more simple, or more retarded. Take your pic.
Old 07-10-2009, 10:57 AM   #6
gotgohan
=( I thought this was what was wrong with my cruise control so I went outside JUST NOW and I think I know what your talking about but really I hope I am wrong because I want my cruise. ANYWAY
Theres this button that the clutch hits when its in. Is this what sets the cruise?
Otherwise I can see that the clutch almost hits this rusted piece on the other side but its not touching
gotgohan is offline   Reply With Quote
Old 07-11-2009, 06:28 AM   #7
VerbalVenom
VerbalVenom's Avatar
Send a message via AIM to VerbalVenom
^Yes that's what disables cruise control when you push in the clutch . If you get under the car and push on your clutch, you'll see where the plunger should be contacting the switch. In my case, that plunger was missing, as is the case with many G2 owners. I got rid of my cruise control some time ago but if it were working I wouldn't have ever removed it in the first place. Kinda sucks knowing all I needed was a bolt to actuate that switch.
VerbalVenom is offline   Reply With Quote
Old 07-11-2009, 06:31 AM   #8
gotgohan
Well that freaking sucks. I got those plungers on both break and clutch still in tact... not that its good news BECAUSE MY cruise still doesn't work. Does that tach have to be working for the cruise to work or something?
Old 07-11-2009, 07:54 AM   #9
baller status
baller status's Avatar
I had this same exact problem. But why not fix it the right way? Nearly all Hondas and Acuras have that little tab in there on both the brake and clutch pedals. Just go to the junkyard and rob the newest car you can find.
My motor doesn't exist.
It's 10PM. Do you know where your Honda is?
http://www.civic-eg.com/causeforalarm
baller status is offline   Reply With Quote
Old 07-12-2009, 01:16 AM   #10
gotgohan
I have them though =(
Old 07-12-2009, 09:38 AM   #11
gotgohan
which wire do I hook it up to at the strut tower?
Old 08-16-2009, 07:44 PM   #12
tibbs420
tibbs420's Avatar
Send a message via AIM to tibbs420
Icon3 Re: *WRITEUP* 90-93 Integra cruise control fix
ok so i fixed it with a bolt but the light on the cluster doesn't come on. do you have to be in 5th gear and over like 55 mph or something. when you fixed it did the buttons on the steering wheel work and when you push the cruse button dose the light come on the cluster? or tell me when it comes on. i didn't drive on a freeway cuz i have no license at the moment so im scared to test it
TiBBS
93 Acura Integra LS
tibbs420 is offline   Reply With Quote
Old 08-24-2009, 08:33 PM   #13
tibbs420
tibbs420's Avatar
hello?
TiBBS
93 Acura Integra LS
Old 08-24-2009, 09:43 PM   #14
Brice.Hayden
Make your own title.
2012 Acura TSX
My Garage
Brice.Hayden's Avatar
iTrader Rating: (9)
no you dont have to be in 5th gear.
Originally Posted by 2LEM1 View Post
Ben is making sock puppet accounts to vote for himself
Brice.Hayden is offline   Reply With Quote
Old 11-01-2009, 09:17 AM   #15
punsteg1990
punsteg1990's Avatar
Send a message via AIM to punsteg1990
I fixed mine with a ratchet and a socket, 3 bolts hold the unit under the hood, and a small clip at the back of the gas pedal. if you need cruise control, buy a toyota camry
punsteg1990 is offline   Reply With Quote
Old 06-27-2012, 07:59 AM   #16
ThoKMo
im so glad i found this just in time ! used a bolt and nut and worked perfectly from seattle to san diego thank you t . boz
ThoKMo is offline   Reply With Quote
Old 03-15-2013, 09:16 AM   #17
nickdamartin
thank you for the write up. i have to see if it is the switch tonight. if it is i dont even want to think about how much you saved me in shop bills.
nickdamartin is offline   Reply With Quote
Old 03-15-2013, 01:16 PM   #18
KILLAB17VTEC
KILLAB17VTEC's Avatar
I hate asshoe.!!if u 1 of them wat u lookin at?
post pic.. I'm tryin to figure mine out I got no cruise rite now.
Evo Project /Stolen--93 Gs-r Turbo///fullybuilt@ Trap 143mph@9.49
KILLAB17VTEC is offline   Reply With Quote
Old 04-20-2013, 03:58 AM   #19
civiceagle2
civiceagle2's Avatar
iTrader Rating: (1)
pics would help my dumbass, will post picture of mine, something seems sketchyy sketchyy.
civiceagle2 is offline   Reply With Quote
Old 06-17-2013, 11:22 PM   #20
hb420
1990 Acura Integra
hb420's Avatar
iTrader Rating: (1)
http://www.facebook.com/?ref=home#!/profile.php?id=100000625617425&sk=info
Send a message via AIM to hb420
Glad i came across this thread, fixed my cruise control also before a long road trip next week
hb420 is offline   Reply With Quote
1993, 1995, 9093, 92, button, control, cruise, crusie, fix, honda, integra, integras, pic, tech, works
Similar Threads
1990-1993 Integra automatic to manual transmission conversion elmalouno Acura Integra 64 06-25-2014 09:35 AM
How to: Auto to 5spd Swap **lots of pics** s.cali alan Honda Accord (1990 - 2002) 147 06-13-2014 01:37 PM
Honda Civic 92-95 EG/EH/EJ OEM Cruise Control Install Guide Manual Transmission deschlong Honda Civic/Del Sol (1992 - 2000) 45 09-25-2013 05:17 PM
DIY S2k button start /w cruise control harness Solscud007 Acura Integra 33 05-31-2013 06:01 AM
Cruise Control in and out zmss56 Honda Civic (2001 - 2005) 6 12-13-2012 06:32 PM
