> Honda Accord (1990 - 2002)
Old 01-18-2007, 11:02 AM   #1
xluben
xluben's Avatar
Default DIY headlight haze removal (PICS)
here's the kit i bought:
comes with sandpaper (1000, 1500, 2000, 2500), cloth, rubber gloves, polishing compound, and instructions:
here's the good headlight:
and here's the bad one:
close up:
here's after (it started snowing, i'll take a better pic some other day):
close up:
it is quite a bit better, but still not like the other one
here is a scan of the instructions (big image, so it's readable):
i basically just did exactly as it says to do.
cleaned the headlight
soaked the sandpaper
started with 1000 grit (i had no deep scratches, but A LOT of buildup)
side to side, then up and down for the next one, etc.
then circular with the polish
i probably did at least half a dozen runs with the polish and used nearly the whole bottle
a drill with polisher would have helped a ton for the last step(i have one but couldn't find it)
make sure to clean the headlight between each grit level and between each application of the polish
overall it was quite a bit of work, but does look a lot better than before.
also, the reflective area inside this headlight is damaged
(lost much of its luster due to previously having dirt inside the headlight),
so even if the cover was perfectly clear it wouldn't look at shiny as the other one.
Modified by xluben at 11:59 AM 1/18/2007
My CarDomain Page
xluben is offline Report Post   Reply With Quote
Old 01-18-2007, 11:09 AM   #2
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: DIY headlight haze removal (xluben)
do you think you could take pictures showing the process? Or if you already did, post them showing and explaining each step? Pretty much making a write-up on how to clear the haze from your headlights. Then we could add it to the FAQ, I'm sure some people may find it useful.
On a side note, I've also read of others using plastic polish to remove the haze.
TouringAccord is offline Report Post   Reply With Quote
Old 01-18-2007, 11:12 AM   #3
shibbywhitedude
shibbywhitedude's Avatar
I think it looks ALOT better than it did before and I'm loving the painted stocks... I'm going to attempt that when it warms up... not diggin my Ebay projectors... but I like them better than fogged up headlights so let me know if they start foggin up when it warms up.
98 Accord LX sedan 4 cylinder
Stock except for a stereo system and some projector lights.
Eibach Pro Kit and Pro Dampers
shibbywhitedude is offline Report Post   Reply With Quote
Old 01-18-2007, 11:48 AM   #4
egyolk
egyolk's Avatar
Default Re: (shibbywhitedude)
nice results
<FONT COLOR="blue"> Club 14s</FONT>_v<FONT COLOR="red">1.6 </FONT> - #002
38+ Vouches
egyolk is offline Report Post   Reply With Quote
Old 01-18-2007, 11:48 AM   #5
khunt0012
Meat Robot Invisible
khunt0012's Avatar
Default Re: DIY headlight haze removal (TouringAccord)
Meguiars PlastX works really well with a low grit wet-sand paper. I didn't know this kit existed, but it looks very good.
94 Honda Accord - H22
khunt0012 is offline Report Post   Reply With Quote
Old 01-18-2007, 11:49 AM   #6
iam7head
iam7head's Avatar
i think you need to be warm before doing this.
there's a protective coating on the surface, sanding it down or using aggressive buffing compound on the coating will pretty much put it out of service.
with the coating you will get the white haze after a while, most people put wax on it to keep it glossy for few months
Honda s2000 Ap1 00' Silverstone(153lb-ft of torqueless wonders)
Mazda Miata Mx-5 90' BMWjetblack(116hp of ball-less fury)
iam7head is offline Report Post   Reply With Quote
Old 01-18-2007, 12:03 PM   #7
xluben
xluben's Avatar
added to the original post, including the actual instructions the kit comes with.
here's where i got the idea, they used a 3M cleaner/polish made for plastics.
http://www.6thgenaccord.com/fo...=2167
i went to o'reilly's and this is what they had, so i got it
thanks, it does look much better than before (especially in person).
My CarDomain Page
Old 01-18-2007, 12:11 PM   #8
TouringAccord
H-T Order of Merit
Default Re: (xluben)
Old 02-17-2007, 07:21 AM   #9
AFAccord
AFAccord's Avatar
Default Re: (TouringAccord)
Just the write-up I was lookin for. What's this kit cost?
I Torque. 2000 CG3. eCtune'd F23
Originally Posted by OVRTEC View Post
on road, you dont need torque un less you are one of those street racers. lol.
AFAccord is offline Report Post   Reply With Quote
Old 02-17-2007, 08:31 AM   #10
xluben
xluben's Avatar
Default Re: (AFAccord)
i don't quite remember, $5-10 i think.
My CarDomain Page
Old 02-17-2007, 08:51 AM   #11
standbackimapro
standbackimapro's Avatar
Send a message via AIM to standbackimapro
When i had my 1g talon, the headlights were like yellow basically, i couldnt find a kit like that around... so i ended up buying this maguires plastx stuff, it worked pretty damn good
20 Years old From Brick, Nj
ASE: A1, A2, A3, A4,A6, A8, L1, X1
MECP BASIC
standbackimapro is offline Report Post   Reply With Quote
Old 08-12-2007, 10:13 PM   #12
tsiah
tsiah's Avatar
Send a message via AIM to tsiah
I hate that permatex shit...never works how they say.
tsiah is offline Report Post   Reply With Quote
Old 09-24-2007, 08:55 AM   #13
mac_24_seven
1994 Acura Integra
mac_24_seven's Avatar
Default Re: DIY headlight haze removal (tsiah)
Another, easier way.
Before:
Duringdid the outside lens)
After:
Product used:
$4.00-$5.00 at any parts store/Walmart. 5-10 mins with this and a rag + a lil elbow grease can save you a good bit of $$$.
Enj0y!
94' GSR "Aeris":Turbo, shaved bay, wire tucked and more. Over 50 DIY's!
336,000 views! ITR header skid plate:$40 shipped
Precision SC34 Turbo 7lbs ---- Built, not $bought$.
mac_24_seven is offline Report Post   Reply With Quote
Old 09-24-2007, 11:01 AM   #14
Tyte-S
Tyte-S's Avatar
Send a message via AIM to Tyte-S
Good Post the left headlight on my 6th gen accord is a lil cloudy also and i was wondering what i could do to get it looking a lil better
1994 Civic Sedan, 1998 Chevy S10, 2002 Acura Rsx Type S
RIP #21 4/9/09
http://www.myspace.com/wades2000accord
Tyte-S is offline Report Post   Reply With Quote
Old 09-24-2007, 12:17 PM   #15
scabbs
scabbs's Avatar
Default Re: DIY headlight haze removal (Tyte-S)
I've used sum stuff like that but after they go wet it all came back... like it washed everything off... should I wet sand it first before using that stuff??? cause I've spent lots of time trying to figure out what to do I almost bought new headlights just to get rid of the haze.
1998 accord slammed on tein ss, 17" gunmetal sub-zero nock offs, shaved emblems, type r style lip, diy black housing headlights and an H22A4 to top it off. http://images.honda-tech.com/set1/smile/emthup.gif
got any questions jus pm me.
scabbs is offline Report Post   Reply With Quote
Bookmarks
cloudy, diy, haze, hazing, headlight, honda, lens, removal, remover, rsx, s2000, scratches, sheadlight, type, walmart, works
