Life Expectancy to Change Timing Belt
Old 01-08-2007, 06:44 AM
Damon Reeves's Avatar
Default Life Expectancy to Change Timing Belt
Just bought another integra with approximately 130k miles...wanted to know what th expectancy is to change the timing belt and a complete tune-up?
Old 01-08-2007, 10:26 AM
nonsense's Avatar
Default Re: Life Expectancy to Change Timing Belt (My DC2)
If you don't know when it was done before, assume is hasn't been done and do it now. Replace the water pump and TB tensioner while you're at it.
Old 01-26-2007, 06:46 AM
Default Re: Life Expectancy to Change Timing Belt (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">If you don't know when it was done before, assume is hasn't been done and do it now. Replace the water pump and TB tensioner while you're at it.
Thanks
Old 01-26-2007, 06:38 PM
WalkerGSR1's Avatar
Also depends how you and the previous owner drove the car. If you dont know the other owner change it along with water pump, oil pump and tensioiner.
Old 01-27-2007, 07:41 PM
Moderator in Chief
Muckman's Avatar
Dont forget to change the oil, oil filter, fuel filter, air filter and do a valve job. Bam, instant 10hp. lol
Old 01-28-2007, 08:06 PM
PrettyLude's Avatar
don't forget to change the crank and cam seal
Old 02-01-2007, 03:23 PM
1995accordace's Avatar
Pardon me for asking. What is meant by valve job ans TB tensioner? How much does it cost? Thanks.
Old 02-02-2007, 05:44 AM
Default Re: (1995accordace)
you are not pardoned.
Old 02-02-2007, 11:46 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995accordace &raquo;</TD></TR><TR><TD CLASS="quote">Pardon me for asking. What is meant by valve job ans TB tensioner? How much does it cost? Thanks.</TD></TR></TABLE>
TB Tensioner = timing belt tensioner
it's #14 in this pic and #16 is the spring which is so cheap you shouldn't think about not replacing it (yay for double negatives)
As for the "valve job" I'm really not sure what Muckman was getting at. To me a valve job is when you remove the head, replace the valve guides and seats and refinish or replace the valves. It's only needed when it's needed (i.e. it's not an interval maintenance thing)
He may have meant a valve adjustment, which is where the valve lash is adjusted to within spec, and is a good idea to do when you have it all apart to do the timing belt anyway.
guero2craze
02-06-2007 10:56 AM
EGCivicChicago
17
01-21-2007 06:45 AM
attest53
03-05-2006 08:56 AM
Intercooler
23
10-21-2005 03:36 PM
IntEGNYC
12-05-2002 09:16 AM
Quick Reply: Life Expectancy to Change Timing Belt
