2k accord crankshaft position sensor location
Old 01-03-2007, 12:43 PM
BigGreenAuto's Avatar
Default 2k accord crankshaft position sensor location
can anyone tell me where the crankshaft position sensor is located? thanks
Old 01-03-2007, 05:40 PM
Patman's Avatar
Is yours showing up as disconnected too? Its under the lower timing belt cover, pickup a haynes for pictures. My 98 accord has the same problem and somtimes just won't even start, major wtf. 100k on mine and this happens, time bomb, anybody know of a fix?
Old 01-04-2007, 02:18 PM
Default Re: (Patman)
my odbiII showed up a code for my crankshaft position sensor so i am trying to find it so i can change it out. my car is at a little over 100k. thanks for the post.
Old 01-04-2007, 03:34 PM
smokin151's Avatar
CKP/TDC Sensors Replacement
Remove the balancer belt.
Remove the balancer belt drive pulley.
Disconnect the CKP/TDC sensors connector (A), then remove the CKP/TDC sensors (B).
Install the CKP/TDC sensors in reverse order of removal.
Install the balancer belt.
Old 01-05-2007, 04:07 AM
Patman's Avatar
i erased my p1359 code two days ago, car is still running ok, anybody think its weird these sensors go to crap after 100k? right after
Old 01-05-2007, 05:16 AM
notoriousB's Avatar
those sensors shouldn't "go bad" - they're simple magnets. I'd check the wiring first.
Old 01-05-2007, 06:58 AM
Patman's Avatar
I'm thinking mine might be from moisture or maybe even oil come to think of it, I have been loosing some, about 1/4 quart every 1000 i think its getting worse, maybe its leaking out the side there and running all over the wiring?
MacMade
09-14-2020 12:09 PM
guildmaster
06-02-2019 04:52 PM
RWSStudios
Engine Management and Tuning
04-06-2014 12:08 PM
partialresponse
05-20-2010 02:08 PM
Quick Reply: 2k accord crankshaft position sensor location
