2001 transmission fluid
Old 01-02-2007, 12:42 PM
assman25's Avatar
Default 2001 honda civic 5spd transmission fluid
how much do i need for a fill and drain
Old 01-02-2007, 02:39 PM
yz125rider21's Avatar
3 quarts roughly....just check the stick after 3 and go from there
Old 01-02-2007, 03:03 PM
ct991's Avatar
Default Re: 2001 honda civic 5spd transmission fluid (assman25)
I just replaced mine and it's 1.8 quarts. I bought 3 on the advice of the guys that worked at the parts place but I took one back since I didn't need it.
Also, there is no stick to check the manual transmission fluid level, you fill it until it's up to the level of the filling hole. Be sure to have the car level when filling.
Old 01-02-2007, 05:14 PM
douhhh...I misread the topic I was speaking for auto's!
Old 01-03-2007, 06:42 AM
civ05se's Avatar
Default Re: (yz125rider21)
how often should i drain n fill with new trans fluid?
Old 01-03-2007, 11:03 AM
ct991's Avatar
Default Re: (civ05se)
Well Honda recommends (for 5spd) a seemingly long time between tranny fluid changes...10 years or 192,000 km (~ 120,000 mi) under "normal" conditions. For "severe" conditions they recommend half of that. I've had my EX for 5 years and I just replaced it for the first time. The fluid I took out didn't look too bad.
Depending on how and where you drive you may want to adjust that interval accordingly, but I think every 4-5 years is reasonable if you're using the specified MTL fluid (not engine oil).
Old 01-03-2007, 07:01 PM
fventura03's Avatar
just did this today, 1.8quarts is right.
Old 09-13-2008, 11:13 AM
Ben850's Avatar
Default Re: (fventura03)
So how are you guys filling it back up on level ground? Are you actually crawling under, or are you using a long tube? I guess you'd still need to crawl under it to close it back up... I'm 6'7'' 300 pounds
Old 09-13-2008, 11:35 AM
Plead da Fif
It Wasn't Me's Avatar
The Owner's Manual says:
Capacity (including differential): 1.6 quarts - a tad extra (.2 qt) probably won't hurt it any.
To fill mine on level ground, I made this contraption. Parts needed: One gutted ballpoint pen with a slant-cut tip, one bendy straw, one MTF bottle cap.
Make a hole in the cap just big enough for the straw to pass through, the empty pen will slip over the straw and telescope to reach the bottom of the bottle. Put the tip of the straw in the transmission fill hole, squeeze bottle until empty, change cap to new bottle, repeat until trans is full. Voila.
Old 09-13-2008, 12:16 PM
Ben850's Avatar
Default Re: (It Wasn't Me)
lol, that is badass
Old 08-12-2009, 08:44 AM
TLP_IS350's Avatar
Default Re: 2001 transmission fluid
lol i agree
Old 08-12-2009, 09:20 AM
theineffable's Avatar
some gear oils come with a tapered cap that can be attached to a hose....i usually save the spare caps because some oils don't come with that...the tapered cap usually fits on most 1L oil bottles...
Old 08-12-2009, 11:50 AM
Sanji
toyomatt84's Avatar
Originally Posted by TLP_IS350
lol i agree
You bumped a year old thread for that?
Old 08-12-2009, 12:36 PM
pgpbubble's Avatar
I guess everyone is too lazy to remove the bolt that holds in the VSS and fill it that way?
Old 08-12-2009, 03:07 PM
Alan-em2's Avatar
i have an 05 ex coupe and was thinking of changing it this weekend but not sure its time????
Old 08-12-2009, 05:31 PM
Plead da Fif
How is removing the fill plug, which is inches from the drain plug, the "lazy" way of filling the manual transmission with new fluid? Diff'rent strokes, I guess.
Check the FAQs for the Maintenance Schedules
greenquark
08-05-2014 03:50 PM
bmclean1
02-24-2011 08:03 PM
bc_psychocivic
09-04-2003 10:32 PM
Y2KGreenGSR
09-28-2001 12:11 PM
GeeSeeR
08-06-2001 04:07 PM
Quick Reply: 2001 transmission fluid
