Old 12-29-2006, 04:52 PM   #1
Sweetsystem
Sweetsystem's Avatar
Default How to remove Rear engine mount?
Guys I need some detailed info on how to remove the rear engine mount. I searched and everyone is vague. Do I have to remove my intake Manifold? Power steering rack?
Ultimately im trying to remove the engine. got everything else off except the mounts and intake mani.
Thanks
1994 Beluga Black GS-R
2008 NBPearl CR-V
Sweetsystem is offline   Reply With Quote
Old 12-29-2006, 04:56 PM   #2
Fat Chick Magnet
good luck. its a bitch to take it out.......took 3 guys to take my rear mount out and replace it with innovative. one guy jacking the motor up another guy watching from the top removing the bolt and another guy under the car trying to pull the mount out.
oh and it was our first time. Click the image to open in full size.
Loi-built.
Fat Chick Magnet is offline   Reply With Quote
Old 12-29-2006, 05:15 PM   #3
GRAF-FITI
* B A N N E D *
Send a message via AIM to GRAF-FITI
Default Re: (dc2rtek)
removing the intake maifold is the easiest way to go about it, then the mounting bracket for the motor mount, then the mount itself
here's a good write up on it: http://www.team-integra.net/fo...age=2
GRAF-FITI is offline   Reply With Quote
Old 12-29-2006, 05:16 PM   #4
Fat Chick Magnet
i just took my intake off and it was easy to get to it.
Loi-built.
Old 12-29-2006, 05:25 PM   #5
jdm_bones
jdm_bones's Avatar
iTrader Rating: (5)
Send a message via AIM to jdm_bones
Default Re: How to remove Rear engine mount? (Sweetsystem)
Put your car on jack stands, come from under the car and hit with an impact gun. Make sure that you have a jack at the tranny ever so slightly pushing up on it and make sure that the crane is well attached to the engine...
jdm_bones is offline   Reply With Quote
Old 12-30-2006, 03:16 AM   #6
dc4teggiehatch
dc4teggiehatch's Avatar
took off tranny mount and left torque mount, loosend rear moutn bracket as well, jack stands on car and jack under motor, slowly raised/dropped til had enuff room (play) to wiggle out the rear mount. the hardest part is putting the bolts back in tight. you need alot of tools.
dc4teggiehatch is offline   Reply With Quote
Old 12-30-2006, 05:57 AM   #7
qfast817
qfast817's Avatar
Default Re: (96teggiehatch)
its easyer when you remove the breather box, take out the rear l bracket
qfast817 is offline   Reply With Quote
Old 12-30-2006, 08:25 AM   #8
PrinceAli132
PrinceAli132's Avatar
Send a message via AIM to PrinceAli132
x2
Ali
Bought From/Sold To: DC4Kid, 98BlackTeg, honduhh, Neo_, ludex360, imola-red dc2, jdmnivek, norice, yellow blur, jp8900, C8V6C, infulleffect, 6ghatch, exies, BlueR, 117
<FONT COLOR="blue">Expo 8 </FONT>
PrinceAli132 is offline   Reply With Quote
Old 01-02-2007, 12:13 PM   #9
Sweetsystem
Thanks Guys. Completed all Maint. T Belt, Clutch, Tranny Fluid, Axles, front torque mounts, polyurethane engine mount inserts, All belts and hoses, Valve cover gasket, and Cam plug. Runs like brand new!
Side note: The Urethane inserts really firm up the engine, almost too much for my comfort level. I might be taking the two front ones out and just keeping the rear one in.
2008 NBPearl CR-V
94, accord, acura, bracket, car, change, engine, honda, integra, motor, mount, mounts, moutn, rear, remove, removing, teamintegra
