How can i tell if my car has jumped timing?
Old 12-22-2006, 10:34 AM
SpOoLiNg CiViC's Avatar
Default How can i tell if my car has jumped timing?
ok... just trying to see how i can tell if it has?
i posted about how i messed my car up already. but here is a refresher.... going around 50ish was going into 3rd. slipped into 1st... car reved high.... put clutch back in... was limping home... got to stoplight... car died. went off the road... car will turn over but not crank......
took distro cap off... no fire from any spark plug wire. and no spark from coil.... but car will turn over.....
dont know about bent valves yet or if i jumped time either.
Old 12-22-2006, 10:38 AM
poison's Avatar
Default Re: How can i tell if my car has jumped timing? (SpOoLiNg CiViC)
Check the timing by taking off the valve cover and upper timing cover. Put #1 cylinder to TDC with on the cam saying "UP". Then look at the crank pulley. The white mark should be lined up with the arrow on the lower timing cover.
From there trouble shoot timing.
HTH.
londoncrx
03-06-2011 06:30 PM
Adj
07-14-2009 11:07 AM
Fighterinsnatch
07-11-2006 05:36 PM
90crxmike
10
03-21-2005 09:52 AM
Lord Quaalard
04-03-2003 10:33 AM
Quick Reply: How can i tell if my car has jumped timing?
