> Honda Accord (1990 - 2002)
Old 04-12-2007, 01:21 PM   #26
Twixle
ate my pixel
Twixle's Avatar
Default Re: Cleaning IACV, FITV and TB (Shay91Racer)
I'd use a toothbrush and some starting fluid, then dry it out with a rag.
OP, thanks for the great write-up, did this and wah-lah my idle was fixed.
01 BB6 /// 00 CBR600F4
Twixle is offline Report Post   Reply With Quote
Old 04-12-2007, 01:43 PM   #27
GhostAccord
GhostAccord's Avatar
Default Re: (TouringAccord)
Originally Posted by TouringAccord
IACV = Intake Air Control Valve
FITV = Fast Idle Thermo Valve
TB = Throttle Body
Not that I'm perfect buy any streatch of the imagination or anything but the
IAC valve or IACV = Idle Air Control Valve
Not meaning to be nit picky TA....sorry!
One more point to this regular maintenance tip for cleaning the FITV, IACV, and TB. If you find that you are doing this more frequently than you think you should be and it finally doesn't work, 9 times out of 10 it is actually the Throttle body ports that are clogged with carbon or oil from the intake manifold side. I wish I had pics of the last TB I cleaned it was gummed up really bad so bad neither the IAC valve or the FIT valve were working. So if this happens to anyone here there is one more step that you can add to the end of the above proceedure and that is to remove your TB and give it a good soaking in TB cleaner/Carb cleaner it's only another 4 nuts and it's off, just make sure to have a replacement TB gasket before you do this, or have a roll of Felpro Karropak .035 on hand to make your own as I do.
Just a few pics to show what I am talking about....everyone loves images
4 easy nuts to remove if the studs come out with the nuts no big deal they'll go back on the same way.
View of the Throttle body from the intake manifold's point of view.
wow colour coded....("colour" yes I'm Canadian...lol)
Red arrows = Air Flow
Blue Circle = IACS, Idle Air Control Screw
Yellow Circle = IACV air ducts/ports/holes......whatever you want to call them!
Green Circles = FITV air ducts/ports/holes...etc!
The area around the (Blue)Idle Air Control Screw, this is fed directly from IACV port in the throttle body, it does not go threw the IAC Valve. This is were the majority of the carbon and oil ends up gathering Remove the IAC Screw and clean this out with a pipe cleaner
The following image shows (top yellow circle)where the air comes in threw the throttle body into the manifold and on threw to the IACV. The lower yellow circle shows where the air is finaly passed into the manifold from the IACV.
Nice and clean looking eh?....NOT! This is where major improvements can be made in the general performance of an older vehicle. every little thing counts.
Hope this helps!
Cheers
NOTE: [i]To avaoid any confusion I must state that the Throttle Body & Intake Manifold in my images above have not been cleaned. Do not base how clean they should be on these images, they are only for visual reference of parts to be cleaned.[i]
Modified by GhostAccord at 6:50 AM 4/17/2007
CD5 "Ghost" F22B2 ITB Blog
My H-T Build Thread
Cheers!
GhostAccord is offline Report Post   Reply With Quote
Old 04-12-2007, 10:08 PM   #28
AJ06
AJ06's Avatar
Send a message via AIM to AJ06
Wait.... what?
AJ06 is offline Report Post   Reply With Quote
Old 04-12-2007, 10:39 PM   #29
Shay91Racer
Shay91Racer's Avatar
Send a message via AIM to Shay91Racer
Default Re: Cleaning IACV, FITV and TB (accord2021)
a toothbrush and starter fluid huh? alrighty then... i'll give it a go. does it have to be starter fluid or could i jus use the carb cleaner since i have it lying around the house?
Shay wuz H3re
Shay91Racer is offline Report Post   Reply With Quote
Old 04-13-2007, 05:39 AM   #30
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: (GhostAccord)
haha, oops. Thanks for correcting me
TouringAccord is offline Report Post   Reply With Quote
Old 04-13-2007, 05:41 AM   #31
TouringAccord
H-T Order of Merit
Originally Posted by Shay91Racer
...could i jus use the carb cleaner...
yes, carb cleaner should be just fine.
Old 04-13-2007, 06:32 AM   #32
chibiko
chibiko's Avatar
Default Re: Cleaning IACV, FITV and TB (mtnwkr)
Do I need to drain the coolent first? Another question is the IACV is behind my intake manifold, so the space to loose it is really tight and I cannot put a socket wrentch there. How do you guys do?
chibiko is offline Report Post   Reply With Quote
Old 04-13-2007, 07:08 AM   #33
GhostAccord
Default Re: Cleaning IACV, FITV and TB (chibiko)
No You do not need to drain the coolant, just make sure that you have a rag or a drip pan under your car as there is a bit of coolant in the lines.... maybe 100ml that's about it.
I have the same problem with my 96 Accord, I use a wrench to crack both of the bolts then after that you can usually turn them by hand.
My H-T Build Thread
Cheers!
Old 04-15-2007, 11:18 PM   #34
syler
syler's Avatar
nice writeup, I think im gonna do this on my day off...
syler is offline Report Post   Reply With Quote
Old 04-16-2007, 07:24 PM   #35
syler
syler's Avatar
hi peeps, i just cleaned my IACV this morning, it was so easy as 123, but I havent got time for the FITV, maybe on friday. I have a question though, will cleaning the FITV or the IACV fix my rev problem? it goes a little like this:
even though the engine is already on the operating temp, whenever I rev, and let go, rpm goes down as if the engine will want to stall, but its catching its breath, what can be the cause of this?
Old 04-16-2007, 09:43 PM   #36
JimBlake
JimBlake's Avatar
Default Re: (syler)
Originally Posted by syler
... whenever I rev, and let go, rpm goes down as if the engine will want to stall, but its catching its breath, what can be the cause of this?
That might be your base idle is off. So I'll add to this cool thread since that's sorta related...
First, check for vacuum leaks and get rid of any air in your cooling system. Clean your TB like those pictures above. Or maybe CLEANER than the pics in GhostAccord's post.
The throttle cable should have a little slack, and the mechanical stop for the throttle must not hold it open. Only just barely enough to prevent it from wedging stuck closed.
Then you can set your base idle. That's not the operating idle, but the base idle is a LOW idle speed you set with the IACV unplugged. Look up the "BASE" idle speed for your year/model. It's usually around 500 or 600, and it's NOT the rpm listed on the sticker under the hood (that's the operating idle).
Find the idle air bypass screw about 11 oclock in this picture (thanks GhostAccord).
1 - Warm up the engine, turn off all electrical loads.
2 - Jumper the SCS connector (prevent ECU from messing with spark timing).
3 - Unplug the IACV - idle rpm will drop - try to keep it running.
4 - Adjust idle with idle air bypass screw to set your base idle rpm.
5 - Shut off, plug IACV back in, cool down, RESET ECU.
6 - Start engine without touching gas pedal.
7 - Let it idle to warm up without touching gas pedal. This allows the ECU to learn the behaviour of the idle system after it's all cleaned & adjusted.
JimBlake
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline Report Post   Reply With Quote
Old 04-16-2007, 09:59 PM   #37
syler
syler's Avatar
Default Re: (JimBlake)
Thanks for the post Jim,
have a few question though if you have time.
I am not sure of the "Base idle" of my d16z6 engine, i dont have the manual anymore,. hope someone can answer that?
"2 - Jumper the SCS connector" > sorry but what is scs? is it the airbag? my car does not have one. :D so i gez i have to bypass that.
"3 - Unplug the IACV - idle rpm will drop - try to keep it running." > do you mean while the engine is running, il unplug or remove the IACV? and adjust the base idle?
again, thanks for helping me man... its great to be here...
Old 04-16-2007, 10:42 PM   #38
JimBlake
JimBlake's Avatar
Default Re: (syler)
I Don't know your base idle...
The service check system (SCS) connector is the same plug that you jumper when you're reading ECU error codes. Blue plastic plug, 2 wires. I think in a Civic (D16?) it's tucked up between the glovebox & the right kick panel.
When you unplug the electical connector from the IACV, the idle speed will drop. Maybe it'll want to die, so you may need to baby it with the throttle to keep it running. Use the idle air screw so it runs when you let go of the throttle. Then carefully adjust it back down to base rpm.
Part of the problem is when there's idle problems, it's tempting to simply go for the idle air adjust screw, without going thru the proper procedure. If the original problem was a dirty IACV, and someone tried to 'fix' it by just turning the idle screw, or tightening the throttle cable; then it gets all messed up.
JimBlake
Old 04-17-2007, 12:28 AM   #39
syler
syler's Avatar
Thanks again Jim, yes, now I know what the scs mean,and I found it.
I will do the procedure you mentioned and keep this thread up until I get my problem solved. I did not reset my ECU this morning that is why maybe its still messed up.
Old 04-17-2007, 02:45 AM   #40
GhostAccord
Yeah this is one that I just took apart, I'll post up some before and after shots when I get this one cleaned up right!.... I have made note of this fact on my images. Thanks Jim
NP
My H-T Build Thread
Cheers!
Old 04-17-2007, 11:28 AM   #41
chibiko
chibiko's Avatar
Default Re: Cleaning IACV, FITV and TB (GhostAccord)
Thanks for the information. Things are exactly as you said. I have cleaned my IACV and FITV. It took my car several minutes to adjust to the change and after that it works great. A question is that when I wait for the temperature to increase to normal, I heard some clicking sound from the position of FITV or just around it. The sound is similar as that of the cylinder valves. After driving it for a short test, the clicking is gone. Don't know what the sound is and if it is normal. My car is old, maybe some electrical devices are bad. Here we know how to clean those valves, is there a way to check their functionality easily?
Old 04-17-2007, 08:40 PM   #42
JimBlake
JimBlake's Avatar
Yeah, I know those are before pictures, I was just teasing you for fun.
Another thing... I just answered a post about this for a newer Accord. Beginning about '96 or so there are no more FITV. (Anyone know what year?) On newer cars the function of the FITV is built into the IACV. Just in case someone with a 2001 Accord is all confused because they can't find their FITV.
Cheers.
JimBlake
Old 04-17-2007, 09:15 PM   #43
lowered94accord
lowered94accord's Avatar
Send a message via AIM to lowered94accord
OK I have a quick question..I cleaned my FITV and IACV like 2 weeks ago and friday im gonna adjust the idle screw...can I reset my ecu just by pulling the radio back up fuse for a minute or so?..i think I read that somewhere before but I cant remember...thanks
Life's simple, you make choices and you don't look back.
Who you choose to be around you lets you know who you are.
lowered94accord is offline Report Post   Reply With Quote
Old 04-17-2007, 10:02 PM   #44
racerstodeath
racerstodeath's Avatar
thanks
racerstodeath is offline Report Post   Reply With Quote
Old 04-18-2007, 05:18 AM   #45
JimBlake
JimBlake's Avatar
Default Re: (lowered94accord)
Originally Posted by lowered94accord
...can I reset my ecu just by pulling the radio back up fuse for a minute or so?...
I'm not real sure on a '94, but you're probably correct. Unless the ECU has it's own backup fuse & doesn't share the radio's.
... a bunch of people in this thread, different year cars, etc. The ECU fuse isn't always the same fuse # in the same fuse box, and it doesn't always maintain the stereo security.
JimBlake
Old 04-18-2007, 12:20 PM   #46
syler
syler's Avatar
can someone answer this? im about to clean my fitv this friday
Old 04-18-2007, 01:30 PM   #47
GhostAccord
Default Re: Cleaning IACV, FITV and TB (syler)
There is a way to test your FIT Valve while you have it off your throttle body for cleaning.
When the FITV is at air temperature/cold it will allow air to pass throught. I clean mine off and just blow into the side with the spring visable and it should come out the opening with the cream/white seal, I always take the hands on approach....lol
Notice the position of the spring in the above image you can see a coil or two.
Now to perform the test all you need is a tap running hot water. With just enough water to pass through the FITV hold it under the hot water flow for at least 2-3 min.
After a few minutes you should notice that the spring will tighten as shown in the image below (if the FITV is working) To test simply try to pass air throught the openings again. If the seals are good and the FITV is working properly no air should pass through.
Note: This is a FIT Valve off of a D15b. Not all FITV will appear exactly as shown, but they will allow for the water to flow through in a similar matter.
My H-T Build Thread
Cheers!
Old 04-18-2007, 02:26 PM   #48
JimBlake
JimBlake's Avatar
How about a functional test installed in the car.
FITV's job is to provide a fast-idle when the engine's cold.
If the idle is high & slows down properly as it warms up, the FITV is doing it's job.
There should be no suction from the FITV port after it's warmed up.
IACV's job is to hold a steady idle when other stuff turns on & off.
After it's warmed up, the idle should be steady when you turn anything on & off.
- AC, headlights, wipers, defogger, seat heaters, whatever.
In other words, if you have a nice happy idle when you're done with all this stuff, then both IACV & FITV are OK.
JimBlake
Old 04-18-2007, 02:45 PM   #49
syler
syler's Avatar
Default Re: Cleaning IACV, FITV and TB (JimBlake)
oh man, i just cant wait until tomorrow, im gonna clean the FITV, I still have a problem with my idle and my A/C. The problems is that im at a normal idle at 1k rpm, when i turn on my a/c, it is fine. But when I go to a stop, my rpm goes down as it wants to stall, then my A/C auto shuts off and im worried my a/c might break down due to constant shut off's.
Old 04-18-2007, 03:02 PM   #50
GhostAccord
The FITV port is the bottom port in the Throttle body and the IACV port is the top port.
And don't be affraid to stick your thumb over it to check for vacuum, it's not like it's going to suck you into the motor or anything
My H-T Build Thread
Cheers!
Bookmarks
1990, 92, accord, air, civic, clean, cleaning, control, fast, fitv, honda, iacv, idle, thermo, valve
