is there any way to clean a catalytic converter? need to pass tomorrow
Old 12-20-2006, 06:53 PM
HondaHeddie's Avatar
Default is there any way to clean a catalytic converter? need to pass tomorrow
I know about the guaranteed to pass stuff, but don't have time to run 2 tanks through my car
I need to pass tomorrow
I will replace it asap, but need to pass smog now so I can keep working to earn the bucks for it
I have read of the cat cleaner fluids
or will alcohol work if my cat is getting old(what would max ratio of gas to alcohol be?)
which it is I am sure,
I believe it is the orig, that would make it 250Kmi old
Old 12-21-2006, 07:07 AM
Default Re: is there any way to clean a catalytic converter? need to pass tomorrow (HondaHeddie)
off to try alcohol
will seafoam revive a sick cat?
puuuuuuuuuurrrrrrrrrrr
Old 12-21-2006, 07:36 AM
thesmogman's Avatar
Sorry to say but there is on reviving method for cats. If you need to pass spend the $100 bucks on a stock replacement cat.
The best thing to do for a cat is to run it for ten or twenty minutes at 3-4000 rpm.
That will burn off any contaminates but that is it as far as I know.
When you get the smog check and you fail you can go to the DMV for an 30 day extension. You need the failed smog check report (VIR)
Old 12-21-2006, 08:17 AM
Default Re: is there any way to clean a catalytic converter? need to pass tomorrow (thesmogman)
thank you man
I have about 40% mix denat alcohol in the tank now
if that dont work I will need to figure out how to get the cat
I cant get the ext, I have a ticket for driving w/ exp tag now
I have till dec 30, but need to have it reg'd today for work reasons
dtran002
11-22-2011 11:00 PM
nek9
05-25-2006 09:02 PM
SiRII_Izzy
21
08-24-2004 07:06 PM
HBCthugg
05-03-2002 11:50 PM
Quick Reply: is there any way to clean a catalytic converter? need to pass tomorrow
