#1 | |||||
2005 Evolution VIII. 372 Mustang Dyno wheel HP 11.56 in the 1/4 2000 Acura Integra Type R #1382 SOLD 5 years of fun. Destroyed by the second owner in less than 5 months |
#2 |
Matt,
Wouldn't just this work? I just looped the input/output lines. I don't understand why you would need the "breather" part. So is your rack very low on fluid then? [Modified by TodaSi, 9:06 PM 5/12/2002]
Chad (aka TodaSi) 2005 Acura TSX 6 speed http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emsmile.gif 2007 Scion tC (wife's car) 1992 Civic CX (kids car) |
#3 | |
Yes that will work fine. However it will require less effort if you add a breather. I had mine set-up like that to try it. But because it is a sealed system you are fighting the fluid and air pressure. The rack is low on fluid but it is only in there as a lubricant. Mattj [Modified by Dropspeed, 10:45 PM 5/12/2002]
#4 |
Why not just be really lazy and loop the lines that come off the pump? That way the tank stays there to keep thh rack lubed properly and it only takes like 5 minutes to do
Contact me for tuning anywhere in the world. DENT Sport Garage Mechanical, fabrication, and dyno tuning. http://picperformance.com Tune with Crome! |
#5 |
this will help alot, over removing power steering pump....?
like comparing turning effort
| Pneumatic VACUUM line Kit | |
#6 | |
Mattj
#7 |
could you try tof ind a pic of the "Barb" fitting, im gonna try this, it shoudl shed weight and help me
#8 |
oh nice. Thats almost exactly what I've been working on for a long time now as an idea for the system.
Now this is one of the best H-T ideas/threads I've come across now!
Dynospot Racing ...for dyno tuning, engine building, installs and service of Japanese & European imports |
#9 |
I did what TodaSi did and just looped it with the rack still FULL of fluid. I haven't had any problems in the 3 years I've had it like that.
-Alan
1995 Milano Red Acura Integra LS/VTEC (long gone) 2003 Black Mica Mazdaspeed Protege #226 (r.i.p.) 2003 Honda Zumakus - 70cc 2-StrokePoke |
#10 |
yeah he's not saying that doing that is bad. In fact he does the same thing to his setup, yet he also adds on a breather to make the steering feel a lot looser and easier to turn rather then just looping the two holes.
#11 | |
ps I updated with pictures and additional part info. Feel free to use this info/how-to on web-sites and what not, just give me credit DISCLAIMER, Do this at you own risk, if your not comfortable, don't do it.Mattj [Modified by Dropspeed, 12:56 AM 5/13/2002] [Modified by Dropspeed, 1:02 AM 5/13/2002]
#12 |
Some more pics to help illustrate. The brass fitting I picked up at NAPA, $ .50 or so. I do not know the part # or the size
Here is my Si giving birth. [Modified by TodaSi, 1:45 AM 5/13/2002] Modified by TodaSi at 9:57 PM 8/9/2004
#13 |
Why T into the thin metal line? Can't you just T into the rubber hose that you just looped in and run the breather from there? It just seem easier to T into a rubber hose rather than into a metal pipe.
2007 ASM Acura TL (SOLD)2004 Cobb Stg. 2 WRX Best ET: 13.991@96.05; 1.830 60ft (Close to stock) (SOLD)2000 FBP Civic Si Best ET: 14.644@94.34mph NA; 2.272 60ft |
#14 |
I'm sure you could, I just copied the Realtime cars. They have been running like this for 5+ years (and winning) My "guess" is that you want the rack to breath and that is a direct port.
Mattj
#15 |
I shoot brides
arigato matt-san
![]() y shi - who b00kmarx dis thred fo lata use
Stable: 00 ITR #234 (banned on CA streets )00 CRV LX AWD 07 CRV EX-L |
#16 |
What is the difference is steering effort between:
A. Removing PS belt B. Removing PS belt, pump and looping hose C. Setup outlined here with reservoir I have A and was thinking of doing B. Is the difference between B and C significant? Also, how much do the PS pump and lines weigh? Is the PS pump the majority of this weight? [Modified by norice, 11:15 AM 5/13/2002]
#00-0463 Sold Selling: Comptech cat-back exhaust for ITR or 2000+ GSR. SF bay Area pick up only: $350. |
#17 | |
#18 | ||
Thanks in advance for the response, and good write up.
2007 Fiji Blue Pearl Civic Si Sedan / 1992 Frost White Integra GSR: 149.6HP, 105.0TQ FOR SALE (CLICK HERE) B16A & B17A DOHC VTEC parts, DA Gauge Clusters...and more! |
#19 | |
[Modified by nfn15037, 12:55 PM 5/13/2002]
#20 |
It is still not clear to me how removing the pump and connecting its input and output hoses together is in practice any different from the elaborate setup outlined here (apart from the weight of the hoses). Does the stock reservoir not also act as a breather?
#21 | |
There is no right or wrong way to do this just different ways.
"As for the "drain pan" can you describe this in a little more detail?" I was just saying Drain it into a pan, bottle, or the floor. All your doing is letting the fluid run out of the system. Quote:
Yes digging around behind the rack is a pain in the butt, Going from you step b-c is a noticable difference, And yes my face went when the fluid shot up.Mattj [Modified by Dropspeed, 4:54 PM 5/13/2002]
#22 | |
SUPER smartERATOR
open your mind. -NEMO ME IMPUNE LACESSIT- |
#23 |
Good write-up.
Question: Will the rack half full of p.s. fluid retain its lubricating properties as if the pump remained intact? I'm concerned about the long-term reliability with this set up. I've also been looking for an alternative to the cx/dx rack. I used to have an 89 crx si and miss the "feel" of a manual rack. j
97 GSR "The Wraith" |
#24 |
That's a nice setup! I'm thinking about trying that out, but I'm still confused about the purpose for the breather.
I don't think the rack & pinion gear actually get lubricated from the PS fluid. If in fact the rack & pinion don't get lubrication from the PS fluid, what is the PS fluid lubricating? I know Realtime must have done that for a reason. Please correct me if I'm interpreting this wrong. I've never taken this assembly out so I'm just going by the info from the diagrams... The 'fluid flow diagram' from the helms service manual doesn't indicate any PS fluid going to the rack & pinion gear. (See pg 17-4) It just flows through the reservoir/pump assembly, the valve body unit, and the power cylinder. It looks like the rack & pinions gears are completely isolated. I don't have a scanner so I can't post the picture. Can anyone post it for me? Also if you look at the first picture on page 17-8 of the Helms, you'll notice that part of the teeth from the rack stick out of the assembly. It's probably hidden underneath the rubber boot. How is this part of the rack sealed if there is actually PS fluid on the other side of the seal? Could I get away with just doing the following and get the same results? -> Looping the hoses from the PS pump assembly and draining 50-75% of the PS fluid? Less fluid=less resistance. [Modified by R8dR, 2:46 AM 6/2/2002]
http://images.zeroforum.com/smile/emarrow_right.gif e http://images.zeroforum.com/smile/emarrow_left.gif ITR 98-160 |
#25 | |
Good info.
Save yourself a few bucks. [Modified by qtiger, 12:25 PM 5/20/2002] |
| Bookmarks |
| Tags |
| 92, 95, belt, civic, hondaacura, hose, integra, ls, lubrication, power, rack, remove, replace, replacement, steering, tsx |
