Go Back   Honda-Tech > Community Forums > General Discussion and Debate > Electronics, Gaming & Photography
Old 12-14-2006, 06:12 PM   #1
FalkenSiR
FalkenSiR's Avatar
shpongled357 SeekerOfOneness
Send a message via AIM to FalkenSiR
Default Speedfan Q: What is "remote temperature"?
I run speedfan in one of my computers and one of the measurements it senses is "remote temperature"
What is that? because it's always overheating. The little flame icon is next to it while local temp and my 2 hd's have a green check mark, indicating that their temperature is fine.
If you think you know, but you don't do, you don't know.
FalkenSiR is offline   Reply With Quote
Old 12-16-2006, 09:36 PM   #2
hapexamendios 2.0
R.I.P.
2002 Lamborghini Gallardo
hapexamendios 2.0's Avatar
Default Re: Speedfan Q: What is "remote temperature"? (J.MONEY)
on my brand new system Speedfan and another app read my CPU temp at 71 degrees all the time (which is way fawking hot) but its actually at 31-32 according to the BIOS... if that helps
“Life is like a movie, if you've sat through more than half of it and it’s sucked every second so far... No one should blame you for walking out early.”
hapexamendios 2.0 is offline   Reply With Quote
Old 12-17-2006, 12:39 AM   #3
FalkenSiR
FalkenSiR's Avatar
Default Re: Speedfan Q: What is "remote temperature"? (honda 3300)
Ok, I was doing some searching on some boards and I think I got the temp issue under control. However, both my HD's are "in flames" My 250 gb brand new hd is at like 98% just idling (scary) and the other one (old- 30 gb) around 80% temp
Why is this? is the case too small? its a micro ATX I think. The comp is a hp pavillion 531w.
How do I go about adding a fan? I couldn't find any info on it. How do I know what fits my computer and what size should I get?
Old 12-17-2006, 12:44 AM   #4
Frozen E
H-T White Ops
2008 Honda Element
Frozen E's Avatar
Rig up some kind of a fan setup on those hard drives. Those suckers spin at 5400-10,000 RPM. Heat is their enemy. I have 4 hard drives in my computer and they stay at about room temperature because I have a big *** 120mm fan sucking air across them all the time. Cheap insurance that will more than likely extend the life of your drives.
A $5 fan might keep your priceless data safe.
Frozen E is offline   Reply With Quote
Old 12-17-2006, 12:47 AM   #5
Frozen E
H-T White Ops
2008 Honda Element
Frozen E's Avatar
Here's my fan setup. The black plastic is a piece of a DVD case I cut out to make sure that the air being sucked over the hard drives is coming from outside the case, and not just recirculated air from inside the case that's a hell of a lot warmer than my room. Works like a charm
With the air diverter in place
"Air diverter" off
Old 12-24-2006, 04:05 AM   #6
uNF$@#!
uNF$@#!'s Avatar
Default Re: (IslandSi)
the antec sonata is a sucky case to be overclocking with anyhow...
the vent in front is useless.....
$$ MOOLA - fun game competition for their ad money $$
Hows it work - They give you $0.01 free for joining. (free registration)
Each time you win a game, they double your money.
uNF$@#! is offline   Reply With Quote
Old 12-24-2006, 09:27 AM   #7
Frozen E
H-T White Ops
2008 Honda Element
Frozen E's Avatar
Default Re: (uNF$@#!)
Uhmm, how do you figure? The "vent" in the front s an air inlet. The big *** 120 in the back has to pull air from somewhere. Works out great. As the exhaust fan is pulling air out of the case, the air coming into the case is getting pulled over the hard drives, cooling them down as well.
Cold air comes in the bottom, over the hard drives, padded the CPU heat sink and out the back. Doesn't really get any more efficient than that if you ask me.
128c, bios, computer, fan, flame, pc, remote, speed, speedfan, sppedfan, temp, temperature, viewer, what, whats
