key won't come out of the ignition
Old 12-09-2006, 12:59 PM
jimjonez
Guest
Posts: n/a
Default key won't come out of the ignition
guys first off i have a 1990 honda accord dx with an automatic tranny. about 2 weeks ago i had a stereo system put it in my car, not only that but since then the weather has been terribly cold. i notice that my key will not come out of the ignition when i'm ready to get out of my car. there is no problem putting the key in and the car starts just fine.... also if i leave my key in the ignition for about 5-10 minutes and then try to take it out it come out just fine? any one ever have this problem? what could be the problem?
Old 12-09-2006, 01:02 PM
hondadude's Avatar
Default Re: key won't come out of the ignition (jimjonez)
aftermarket key?
Old 12-09-2006, 01:26 PM
jimjonez
Guest
Posts: n/a
Default Re: key won't come out of the ignition (hondadude)
no dude they are the original keys..... i have a master key and 2 valet keys.... i was told by the previous owner that there was some work done to the ignition module..... i've had this car for about a month and a half this problem started occuring about a week ago when the weather got really cold
Old 12-09-2006, 02:03 PM
Hcivic88's Avatar
hmm, sounds almost like the car is thinking that its not in park, which would make the keys unable to come out. Is the key shutting off fine, just not pulling out of the ignition? or do you even have trouble shutting the car off?
Old 12-09-2006, 02:31 PM
jimjonez
Guest
Posts: n/a
Default Re: key won't come out of the ignition (Hcivic88)
no dude, the car shuts off just fine.... you know what, i think that might be the problem... what you suggested about the car thinking that it is not in park.... if that were the case what could i do about it????
Old 12-09-2006, 02:35 PM
Honda4lyf's Avatar
No thats not the problem, I have a 92 M/T and same thing happens to me a few times. You jut gotta play around with it when that happens, like turning it more, pushing it in, etc. I'm not sure what causes that.
Old 12-09-2006, 02:37 PM
Chiovnidca's Avatar
If it's an issue with the park switch the "P" light on the dash wont be on when the problem is acting up.
Old 12-09-2006, 06:52 PM
BlkChryKord's Avatar
Jiggle the shifter when its in park. Mine does this every now and then on my 98.
Old 12-10-2006, 10:19 AM
jimjonez
Guest
Posts: n/a
Default Re: (BlkChryKord)
yea i got it figured out thanx guys
Old 12-10-2006, 04:25 PM
mrhonda2u's Avatar
Default Re: (jimjonez)
ITS EITHER THE SHIFTER CABLE NEEDS ADJUSTED OR REPLACED. OTHERWISE SHIFT INTERLOCK SWITCH COULD BE ISSUE? JUST SOME IDEAS.
Old 12-10-2006, 05:20 PM
He knows where you live!
TheMuffinMan's Avatar
did you not read what he just wrote haha?
Old 12-10-2006, 07:09 PM
Persian Virgin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimjonez &raquo;</TD></TR><TR><TD CLASS="quote"> yea i got it figured out thanx guys
Old 12-12-2006, 04:55 AM
CBL9's Avatar
Simple movment of the shifter in park does it, happens in my 1993 auto all the time. That and the drivers door lock key hole has not worked in a couple years. Sucks walking around to the other side, but its an excuse to open a chicks door first, and then see if shes the one
Old 12-12-2006, 11:26 AM
fleetmack's Avatar
Default Re: (CBL9)
happened to my 95lx 2 weeks ago, i panicked ... turned out the steering wheel was locked, it was just being stubborn and wouldn't unlock. i blame it on the 0 degree weather we were having and the fact that i was parked at 10,000 feet
Old 12-12-2006, 08:54 PM
sk84emerica's Avatar
Default Re: (mrhonda2u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrhonda2u &raquo;</TD></TR><TR><TD CLASS="quote">ITS EITHER THE SHIFTER CABLE NEEDS ADJUSTED OR REPLACED. OTHERWISE SHIFT INTERLOCK SWITCH COULD BE ISSUE? JUST SOME IDEAS.</TD></TR></TABLE>
my mom's 98 honda accord transmission was replaced and the next day she was unable to turn the key off and sometimes unable to shift in or out of park. Could this be related to the new transmission being installed? Does this affect the shifter cable or the shift interlock switch?
Old 12-13-2006, 02:52 AM
Chiovnidca's Avatar
Default Re: (sk84emerica)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk84emerica &raquo;</TD></TR><TR><TD CLASS="quote">my mom's 98 honda accord transmission was replaced and the next day she was unable to turn the key off and sometimes unable to shift in or out of park. Could this be related to the new transmission being installed? Does this affect the shifter cable or the shift interlock switch?</TD></TR></TABLE>
Yes, yes
S33
11-17-2014 11:43 AM
Outlaw-Hondaz
03-18-2011 12:24 PM
exz0n-.-
10-23-2008 04:57 PM
b20acura
11-05-2006 09:36 PM
Quick Reply: key won't come out of the ignition
