Brake Question.
Old 12-06-2006, 02:13 PM
C_H_A_D's Avatar
Default Brake Question.
This is not a Honda question. It pertains to my 92 Mazda B2200.
It is pulling hard to the left when I brake. The alignment is fine because I can let go of the wheel and I will continue to go straight. I am thinking I have a bad passenger side caliper. Does this sound accurate?
Old 12-06-2006, 02:42 PM
jimjonez
Guest
Posts: n/a
Default Re: Brake Question. (NINJASWORD)
check both driver and passenger-side brake pad and rotor. if the driver side is noticabley more worn than the passenger- try adjusting your passenger-side brake pressure (10mm nut on caliper)!!! if no difference you might have a fualty caliper. (this happen to me before)
Old 12-06-2006, 03:27 PM
civicboisi's Avatar
Default Re: Brake Question. (jimjonez)
Check the Caliper, Caliper slides, brake hose.
Old 12-06-2006, 06:37 PM
C_H_A_D's Avatar
Default Re: Brake Question. (civicboisi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi &raquo;</TD></TR><TR><TD CLASS="quote">Check the Caliper, Caliper slides, brake hose.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimjonez &raquo;</TD></TR><TR><TD CLASS="quote">check both driver and passenger-side brake pad and rotor. if the driver side is noticabley more worn than the passenger- try adjusting your passenger-side brake pressure (10mm nut on caliper)!!! if no difference you might have a fualty caliper. (this happen to me before) </TD></TR></TABLE>
Thanks guys, I will check tomorrow. I have owned this vehicle for a year and the only thing I have done is replaced the belt. That was easy No a/c no P/S.
About a month ago I hit a deer. The truck is super light so it does not take much to stop it. When I hit the deer I locked up the brakes and I am guessing that is why is caused the caliper problem. I know I did not have this problem before I hit the deer.
https://honda-tech.com/zerothread?id=1792416
Thanks again I will post my results.
zhan28
04-24-2008 06:29 PM
proudcss
Honda Civic (2001 - 2005)
12-27-2007 07:42 AM
nonvtec92
03-18-2007 03:32 PM
underrated
03-27-2006 06:41 PM
IntegraAlteeza
07-23-2005 11:07 AM
Quick Reply: Brake Question.
