Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 05-09-2002, 08:49 PM   #1
Turbo Powa
Default How much air is supposed to be in the tires?
How much air is supposed to be in the tires for a 17 rim? I have a Honda Civic with new HP Racing Rims. I just want to know whats the normal tire pressure?
Turbo Powa is offline   Reply With Quote
Old 05-09-2002, 09:13 PM   #2
dirtySOHC's
dirtySOHC's's Avatar
Default Re: How much air is supposed to be in the tires? (Civic LX 29)
it is stated on the tire *shaking my head* Click the image to open in full size.
dirtySOHC's is offline   Reply With Quote
Old 05-10-2002, 02:57 AM   #3
Chiovnidca
Chiovnidca's Avatar
Default Re: How much air is supposed to be in the tires? (dirtySOHC's)
it is stated on the tire Click the image to open in full size.
The tire manufacturers maximum tire presure is listed on the tire. *shaking my head* Click the image to open in full size.
http://www.honda-tech.com/zerothread?id=1010778
400+hp d16z6 11.0@137
Chiovnidca is offline   Reply With Quote
Old 05-10-2002, 08:21 AM   #4
Turbo Powa
Default Re: How much air is supposed to be in the tires? (Chiovnidca)
So how much is supposed to be in it? Is it the normal pressure for stock tires? How much am I suppose to put in?
Old 05-10-2002, 09:27 AM   #5
HumanResource
Honda Civic 4dr or 2Dr? What model EX. LX. DX??? What Tire Size?
please don't say "they're 17's!"
or "Um They're 40's series"
HumanResource is offline   Reply With Quote
Old 05-10-2002, 09:35 AM   #6
Crazydave
Crazydave's Avatar
Default Re: How much air is supposed to be in the tires? (Chris90STD)
enough to support the vehicle
for a subarban towing a 10,000 pound trailer... 90psi
for a formula ford 15 psi
for my civic 28 front 26 rear
Crazydave is offline   Reply With Quote
Old 05-10-2002, 10:17 AM   #7
GoLowDrew
GoLowDrew's Avatar
What I would do is put about 1-2 psi below the max psi listed on the tire. I don't have 17s, but that's what I do on mine. The stock spec psi is no longer apply anymore.
GoLowDrew is offline   Reply With Quote
Old 05-10-2002, 01:52 PM   #8
speedymon
speedymon's Avatar
Send a message via AIM to speedymon
Default Re: How much air is supposed to be in the tires? (GoLowDrew)
I heard that the tire's psi will go up an average of 4 psi once driven normally. So i just keep it around 4-5 psi below max. I am curious also.
Rockin the 2k Audi S4
speedymon is offline   Reply With Quote
Old 05-10-2002, 01:52 PM   #9
Turbo Powa
Thanks GoLowDrew, You helped me the best out of everyone else Click the image to open in full size.
Old 05-11-2002, 10:33 PM   #10
hondacivic4g
hondacivic4g's Avatar
Send a message via AIM to hondacivic4g
I work for Discount tire we run 32 psi for all cars , unless the customer requests other wise. Just remember that your tire pressure changes depending on wether they are hot or not.So when we first mount a tire (it's cold) the air pressure is set @32 psi. After you have been driving on them a while the air heats up and expands,changing the air pressure to 3-5 psi more.
hondacivic4g is offline   Reply With Quote
Old 05-12-2002, 01:50 PM   #11
Turbo Powa
Default Re: How much air is supposed to be in the tires? (hondacivic4g)
Whats going to happen if I run the wheels at the normal psi? Will that hurt tire performance? When I have the tires at 32 psi there too hard and when I go over bumps its pretty loud. If I put it at normal psi which is I think 29 in the front and 28 in the rear... it isnt as loud when I run over bumps. What should I do? Leave it at 32 psi? Do i need to gte coilovers?
Old 05-12-2002, 08:32 PM   #12
94GSRRacer2
Send a message via ICQ to 94GSRRacer2 Send a message via AIM to 94GSRRacer2
Default Re: How much air is supposed to be in the tires? (Crazydave)
jsut put that freaking ammount on the side of the tire in.. ****. or in your case, 2 psi should be enuf..... Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. but honestly just put 5 psi under the maximum number in.
God damn newbies
94 GSR, sold...
1998 White Prelude SH
JDM Blue H22A valve cover
AEM Blue Short Ram intake
MSD 6A Ignition system
MSD Blaster 2 Coil
MSD 8.5 MM Wires
NGK Iridium Plugs
Apex-i VAFC
Autometer 2 guage pod
Autometer Phantom A/F meter
Autometer Phantom Water Temp guage
minor dress up mods....
[url="http://hondaprelude.com/setups/setupsdsply.asp?id=18054"]http://hondaprelude.com/setups/setupsdsply.asp?id=18054[/url]
94GSRRacer2 is offline   Reply With Quote
Old 05-12-2002, 08:36 PM   #13
94GSRRacer2
NEWBIES!!!!!!!!!!!!!!!!!!! ****
hahaha if you don't know about air in your tires, do yourself and the world a favor and don't drive
you belong in a sinking boat with that other newbie MRVTEC.
94 GSR, sold...
MSD Blaster 2 Coil
MSD 8.5 MM Wires
NGK Iridium Plugs
Apex-i VAFC
Old 05-13-2002, 12:31 AM   #14
Kamin
Kamin's Avatar
Send a message via AIM to Kamin
Default Re: How much air is supposed to be in the tires? (94GSRRacer2)
hey ******* everyone started to learn at some time
im sure you came out of the womb with a helms in one hand and a torque wrench in the other, right?
Click the image to open in full size. im sure theres alot of things you dont know smart ***.
dont diss on him because he dosent know much about cars.
[Modified by KAMiN, 1:31 AM 5/13/2002]
Kamin is offline   Reply With Quote
Old 05-13-2002, 07:59 AM   #15
2K2CivicEx
Send a message via AIM to 2K2CivicEx
Default Re: How much air is supposed to be in the tires? (KAMiN)
You need to check the max pressure on the side of your tires. If you have 17's then you most likely also have low profile tires too. Many low profile tires require more presure then normal tires, especially to maintain the high speed rating of the tires.
For example, my BF Goodrich Scorcher T/A's can run on anything from about 40-50. But to keep the 150MPH rating of the tire the have to have 50 psi.
If you want the the exact right amount of pressure, try this. Fill your tires to about 5 psi below max. pressure. Then take a piece of chalk and make 4 marks on each tire going from the sidewall to the tread. Take your car for a spin, and try to take a few hard turns. If the chalk has been rubbed off on the sidewalls, you need to add more air. If the chalk is still on the tread you need less air. Try this several times until the chalk only rubbs off the tread and non of the sidewall.
Also do not run different tire pressures on the same axel. It's ok to have different amounts of pressure in the front then the rear, but not different amount from one side to the other.
2K2CivicEx is offline   Reply With Quote
Old 05-13-2002, 08:06 AM   #16
GoLowDrew
GoLowDrew's Avatar
With 17s you can no long run at stock psi or you will be rolling on rim. I don't have 17s, but I believe it will be somethng like 45psi. The above post is a good guide.
As for being "stiff" rolling on low 17s will be stiff. And because it's wide, it will generate a lot more tire noise. You can't avoid it. That's why I got 15s instead. If you have not gotten wheels, think about it. It's ok for some, but not for all.
No you don't need coil overs. That's another post. Are you going to lower your car? Get 17X7 wheels if all possible. Most are 17X7.5. But 17X7 will give you more room to avoid rub.
With 17s, I recommend H&R OE Sport at .75 drop. I would go no lower than Sport Springs at 1.75/1.5. There will be some minor rub at certain situation. Again, it depends on what you are willing to live with as a trade off.
Old 05-13-2002, 12:48 PM   #17
Turbo Powa
Thanks 2K2CivicEx!! As for the comment from 94GSRRacer2.... U can go suck a fat **** u gay *** Fuc* Nice contribution to the post. You just talk trash about people. You prolly dont know jack sheit. Just want to look like you know everything. If you going to talk about poeple.... back it up with some useful info. Dont just talk trash cuz that proves to me and everyone else you dont know anything. Thanks for the back up KAMiN. And everyone else who had some useful info... thank you! Click the image to open in full size.
02, 2001, accord, air, back, civic, front, honda, pressure, put, suppose, supposed, tire, tires, tyres
