HELP; misfire on all four cylinder
Old 12-01-2006, 01:03 PM
turbocivic7901's Avatar
Default HELP; misfire on all four cylinder
I keep getting a check engine light stating that I'm misfiring on all four cylinders. My car drives fine though with no sign of it. I have an MSD 6al and SS blaster coil. I called MSD and asked if maybe I needed a tach adapter but the guy said it wasn't necessary. What are possible problems. I thought it could be ECU related or that maybe the plug wires I'm using could be interfering with it. Has this happened to anyone else?
Old 12-01-2006, 06:55 PM
gripnotdrift's Avatar
Default Re: HELP; misfire on all four cylinder (turbocivic7901)
did u check ur plugs?
if not then your wires.
if not then you might have a bad coil?
Old 12-02-2006, 06:09 AM
Default Re: HELP; misfire on all four cylinder (gripnotdrift)
Thanks for the response. I was thinking it might not be the coil because I just got it about a month ago after my blaster 2 had gone bad. I'm going to check out the plugs though.
Old 12-02-2006, 09:30 AM
ive seen a couple coils go bad fairly early. good luck bud
Old 12-02-2006, 10:15 AM
ekfkn9's Avatar
i got msd on my ek and i got a misfire on cylinder 1 and 3...i thought it was the plugs or a bad connection then i checked resistance at the wires and it was very high....so i just repalced my wires then it was all g from there... check out the resistnace...its a shot...kdens
HatchBlakKidd
06-30-2011 09:29 AM
bigtom388
06-10-2008 11:53 AM
JDM_EK4_Coupe
04-17-2007 08:25 AM
CivicSiRracer69
11-27-2004 12:30 PM
Opie
09-29-2003 08:43 AM
Quick Reply: HELP; misfire on all four cylinder
