JDM h22a Accord Vacuum Hose diagram....need a little help
Old 11-29-2006, 12:33 PM
jdm94accord's Avatar
Default JDM h22a Accord Vacuum Hose diagram....need a little help
just installed my jdm h22a into my 94 accord ex, just need to know if anyone has the vacuum hose diagram for this swap or if someone can kinda diagram it out yourself if you have the swap please let me know asap!!!!
Old 11-29-2006, 06:03 PM
Default Re: JDM h22a Accord Vacuum Hose diagram....need a little help (jdm94accord)
bump
Old 11-29-2006, 08:39 PM
momstaxi's Avatar
look at your vaccum diagram under the hood. should be identical to the h22. everything except the iab will be listed.
Old 11-30-2006, 04:08 AM
H-T Order of Merit
TouringAccord's Avatar
Old 11-30-2006, 08:05 AM
Default Re: JDM h22a Accord Vacuum Hose diagram....need a little help (TouringAccord)
Can someone post a close up of there h22a engine bay so i can take a look at the vacuum lines please!!!!!!!!
Old 11-30-2006, 09:11 AM
H-T Order of Merit
that diagram didn't help? What specific area are you looking for?
Old 11-30-2006, 12:08 PM
i havent even used it yet cause my car is in a different state, going there tomarrow, it will most likely be helpful but im just trying to get as many sources as possible
Old 12-01-2006, 06:18 AM
H-T Order of Merit
so are you looking for just general pictures of the whole vacuum line system or a specific area your working on?
I'll see if I can find any more pictures. But I think that diagram above is probably going to be your best bet other than a service manual.
Old 12-01-2006, 07:18 AM
i got a free service manual off another site....free service manuals....WOOOO hooking up the lines today, hopefully i get some luck!
Modified by jdm94accord at 9:37 AM 12/1/2006
Old 12-01-2006, 08:10 AM
H-T Order of Merit
umm... you may want to remove that website from your posts. It's against the rules to post those sites. Just letting you know.
hope you get those vacuum lines hooked up
hpwdhatch
11-14-2006 12:17 AM
r1de4life
01-23-2006 08:58 AM
Stoich EG2
12-09-2004 08:17 AM
Quick Reply: JDM h22a Accord Vacuum Hose diagram....need a little help
