Go Back   Honda-Tech > Honda and Acura Technical Forums > Wheel and Tire
Old 11-28-2006, 08:36 PM   #1
jiggatone
jiggatone's Avatar
papaT0NE
Default widest rim to run on ek?
well yeah im jus wondering whats the widest with the lowest offset i can go on a 96 ek hatch.cuz damn ive been see'in these cars with crazy offset majority of em from "Phaze 2" and yeah.whats the max i can run without rolling fenders or rubbing?cars like these on HT i kind of wanna do the same thing.im on stock shocks and skunk2 coilovers.also does anyone know these guys wheel specs?i dont remember whos cars these are but i did get them from here.
vouches=bio.soulfresh.
Originally Posted by wamba
im trying to put a d16z6 head on a b20 bottom end.has anyone done this before?if so any advise would be great.i think this build will be fresh.
jiggatone is offline   Reply With Quote
Old 11-28-2006, 09:28 PM   #2
nsxtasy
H-T Order of Merit
Default Re: widest rim to run on ek? (tonEK)
I'll assume this is for street tires, not for track tires.
Don't start out with step 5. You need to make your decisions in this order:
1. Decide on what diameter wheel to get (15", 16", etc).
2. Find out what the best tire size is for that size rim on your '96 Hatchback, which is:
15" rims - 195/50-15
16" rims - 205/40-16
3. Decide on what kind of tires you want to get.
4. Look up what rim widths are approved for the tire and size you're getting.
Most 195/50-15 tires are approved for rims 5.5-7.0 inches wide, and I recommend 15x6.
Most 205/40-16 tires are approved for rims 7.0-8.0 inches wide, and I recommend 16x7.
5. Decide what rim width to get, based on what's approved for your tires and what's available for the rims you like.
nsxtasy is offline   Reply With Quote
Old 11-28-2006, 09:35 PM   #3
r.wright
2006 BMW 5-Series
iTrader Rating: (58)
Default Re: widest rim to run on ek? (nsxtasy)
the pics of the cars up above are using negative camber ,stretched tires and have rolled fenders. i would look into a better coilover and/or strut setup(more stiff) if you wanna avoid harsh rubbing
r.wright is offline   Reply With Quote
Old 11-29-2006, 03:06 PM   #4
dvp
dvp's Avatar
Default Re: widest rim to run on ek? (mrrlx)
The tire is the limiting factor on most Hondas. The widest tire that will fit being as close to possible with the stock OD is a 225 45 15. And with that you wont need a wheel any wider than an 8". Let alone the fact you won't be able to fit it without flaring the fenders and then you'll have to get an oversized tire to fit the rim....ugh.
dvp is offline   Reply With Quote
Old 12-05-2006, 07:22 PM   #5
integraboi2626
integraboi2626's Avatar
Default Re: widest rim to run on ek? (dvp)
what kind of rims are those?
integraboi2626 is offline   Reply With Quote
Old 12-05-2006, 09:03 PM   #6
Wendys or Bust
Wendys or Bust's Avatar
Send a message via AIM to Wendys or Bust
yup, I was wondering the same thing. If I cant find a good 20-30 offset wheel, I'll be picking up a set of 16x7 +33 FN01R-C's. I'll mount them on a 205/45 Spt and see how they sit. I want my wheels sticking 3-5mm out from the fender. I'll get longer arp studs and a spacer if I need to.
And I want to roll my fenders a bit too, I've always really liked wide low stances.
Fernando Alonso Nut/Cawk- Rider Crew Member #02
Wendys or Bust is offline   Reply With Quote
Old 12-05-2006, 11:06 PM   #7
vtecsi00
vtecsi00's Avatar
Default Re: (Wendys or Bust)
i believe they are running a 15x8 with a 20mm offset with rolled fenders...but can't think of what wheels they are...there was a thread of someone selling that type of whel i believe
vtecsi00 is offline   Reply With Quote
Old 12-06-2006, 06:24 AM   #8
Wendys or Bust
Default Re: (vtecsi00)
oh. you are thinking about another wheel. You are thinking about http://www.honda-tech.com/zerothread?id=1802720
Old 12-12-2006, 08:12 AM   #9
Hazesus
Hazesus's Avatar
http://honda-tech.com/zerothread?id=1789832&page=1
http://www.Dimanatti.com
Hazesus is offline   Reply With Quote
Old 12-12-2006, 03:55 PM   #10
kangaroo
kangaroo's Avatar
I also like the looks of the wide wheels with the deeper lips.
Question about rolled fender.
Can you keep the plastic wheel well cover under the fender???
or
When you roll you fender you can't have that plastic peice anymore.
Because that plastic peice is connected to the outer part of the fender that you will roll.
I was going to roll my fender but didn't want to lose that plastic peice because then I would get dirt and crap all under my hood.
UPS is the Color.....
kangaroo is offline   Reply With Quote
Old 12-12-2006, 04:21 PM   #11
nsxtasy
H-T Order of Merit
Default Re: (kangaroo)
The bigger problem with losing the fender liners is that they protect the inside of the fenders from gravel and other objects kicked up by the tires. Without them, the fenders can easily get "dinged" (dented) from underneath.
Old 12-12-2006, 04:42 PM   #12
kangaroo
kangaroo's Avatar
Default Re: (nsxtasy)
So I can't roll my fender without losing the fender liner?? Click the image to open in full size.
16x7, ek, ek9, fender, fenders, honda, rim, rims, rolled, run, size, tire, tires, wheel, widest
