2002 Civic A/C Light comes on when heater is switched to windshield defrost.
Old 11-09-2006, 07:57 AM
jlukins's Avatar
Default 2002 Civic A/C Light comes on when heater is switched to windshield defrost.
My 2002 Civic A/C Light comes on when I turn the heater switched to windshiled defrost.
In this position, I cannot get the A/C turned off.
I have to turn the heater switch from defrost to floor heat - then I can press the A/C button & it goes off.
Maybe I could just pull the A/C fuse.
Any suggestions would be appreciated.
John Lukins
Old 11-09-2006, 08:00 AM
flipmoderacer02's Avatar
its normal, A/C light is suppose to come on when you have the windshield defrost on
Old 11-09-2006, 08:13 AM
jlukins's Avatar
Default Re: (flipmoderacer02)
Thanks for the quick reply.
Is this unique to Honda.
Usually you turn on the A/C and the condensor motor kicks in & you fuel economy goes to the floor.
Not the case with Honda?
John
Old 11-09-2006, 08:23 AM
Rennen's Avatar
1) Have the car turned off.
2) Turn the "air condition position" **** to the left all the way (counter-clock-wise).
3) Hold the "air-recirculation button" and the "A/C" button "DOWN". (don't touch the "defrost" button)
4) Start the car with the "BUTTONS" held down, and wait for 7 seconds.
5) All done. You can turn the "A/C" off and on now.
P.S. To turn the original feature back on, repeat all steps, but for "STEP 2", turn the **** all the way to the "right" (clock-wise).
Old 11-09-2006, 09:24 AM
jlukins's Avatar
Default Re: (Rennen)
Thanks - but didn't work.
Attached is a (URL Link to) a JPG of my heater console.
Does your solution work for this model?
http://www.q5systems.com/temp/pb090002.jpg
Old 11-09-2006, 09:26 AM
Sanji
toyomatt84's Avatar
This is in the OLD FAQ's:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="4">DIY: Turn Off Automatic A/C Turn-On</FONT>
What you will need: Two Fingers
Time Needed: 10 seconds.
Annoyed with how you can't turn off the A/C when you turn to defog? Here's the override (realize that A/C expediates the defog process).
These steps are taken from a discussion thread on 2k1civic.com
1. Turn Car Off
2. Turn Temperature **** To Full Blue (All the way to the left - Counter-Clock Wise)
3. Turn Vent **** To Off (All the way to the left - Counter-Clock Wise)
4. Hold Down Air Recirculation Button As Well As A/C Button
5. Keep Both Buttons Depressed and Start Car
6. Keep Both Buttons Depressed for 7 Seconds
7. *AC LIGHT SHOULD BLINK*
You will now have control of your A/C regardless of what setting you are in, to revert back, simply repeat the procedue.
~Credit goes to: Ghosty's Tutorial.
( http://madstatic.com/2k1civic/diy/acdisable/ )</TD></TR></TABLE>
Old 11-09-2006, 09:38 AM
jlukins's Avatar
Default Re: (toyomatt84)
That did it - it worked !!!!!
Thanks for your help.
Old 11-09-2006, 10:06 AM
fventura03's Avatar
i dont think it changes anything, i did it, but it still acted the same...
Charlie Moua
05-02-2008 02:11 PM
apexi_eg6
01-28-2006 06:32 PM
kin_8
Honda S2000
07-11-2004 04:24 AM
SHORT AND STACKED
02-27-2004 07:36 PM
Chaze*R
06-02-2002 11:50 AM
Quick Reply: 2002 Civic A/C Light comes on when heater is switched to windshield defrost.
