Can you tell if your car is misfiring without pulling any codes?
Old 11-04-2006, 10:21 AM
phanatic's Avatar
Default Can you tell if your car is misfiring without pulling any codes?
What are signs of misfiring? My car seems sluggish sometimes. I'll just try to pull the codes tomorrow but i just wanted to ask first.
also...How can you tell if your valves come in contact with your pistons? Would you feel it through the pedal or would you hear it?
Old 11-04-2006, 10:51 AM
fasthatchb18c1's Avatar
Default Re: Can you tell if your car is misfiring without pulling any codes? (phanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phanatic &raquo;</TD></TR><TR><TD CLASS="quote">What are signs of misfiring? My car seems sluggish sometimes. I'll just try to pull the codes tomorrow but i just wanted to ask first.
also...How can you tell if your valves come in contact with your pistons? Would you feel it through the pedal or would you hear it?</TD></TR></TABLE>
Depends on the misfire. Its either a lean, rich, or desity misfire.
You might be having lean misfire's or even worse detination. The only way I can think to see it would be hook up a five gas anilizer. You would have to go to a shop to get someone with one, so your codes will be read anyway(im guessing your OBDII and not lazy).
If your valves came into contact with your pistons you wouldnt be able to have compression and you car most likely wouldnt even start. This you would hear then the car would just shut off.
Flava
08-03-2006 04:36 PM
kobeRy_si
Honda S2000
03-29-2006 12:35 PM
Eluzion
06-18-2004 10:27 AM
Hoodwinked
11-13-2003 08:20 PM
goalieman81
06-15-2003 01:13 PM
Quick Reply: Can you tell if your car is misfiring without pulling any codes?
